    [email protected] Team
    3Com Router 812 - Sem Firmware
    Código:
    Serial Port Initialized
    Initializing Timer...
    Verifying Board Type...
    Initializing LEDs...
    3Com OfficeConnect Remote 812
    -- Version X0.0.2
    Executing Application Loader
    -- Version V1.2.0
    *** NO APPLICATIONS FOUND, System Reset In Progress
    Use PCSDL to Load New Application
    Código:
    G:\OCR812CD\ocr812\Updates>pcsdl
    U.S. Robotics, Inc. (c) 1993-1995 Software Download Program Version 3.0.2
    **Error** Insufficient Number of Arguments
    Command Line Options:
    pcsdl -pPort -rRate -iIrq -vSDn.n.n -v<NA/NI>n.n.n -nSD?? -n<NA/NI>??
          [-dDirectory]
     -pPort <Required> = COM Port: 1, 2, 3 or 4
     -rRate <Required> = Baud Rate: 2400, 9600, 19200, 38400, 57600 or 115200
     -iIrq [Optional] = 3(default COM2/4), 4(default COM1/3), 5, or 7
     -vSDn.n.n <Required> = Software Download Version: n = 0-99
     -v<NA/NI>n.n.n <Required> = NAC/NIC Operation Code Version: n = 0-99
     -nSD?? <Required> = Software Download Filename Prefix: ? = ASCII
     -n<NA/NI>?? <Required> = NAC/NIC Operation Code Filename Prefix: ? = ASCII
     -dDirectory [Optional] = DOS Directory Path Name: default = current directory
     -b [Optional] = Disable Uart's Fifos
    Example:
          pcsdl -p1 -r38400 -vSD1.1.0 -vNA1.2.0 -nSDt1 -nNAst
    a parte debaixo eh o que acontece quando tento roda o programa que ele manda!
    Meu maldito modem ta dando esse erro depois que fui atualiza a firmware dele!
    Alguem da uma ajuda ae..
    to de 56k
    como vo por a firmware agora? o modem so fica resetando e no hypererminal ta esses erros
