    Membro Avatar de numlock
    Jun 2001
    A7n8x-x So Ddr Dual ?
    A7N8X-X so funciona com ddr dual?
    http://www.asus.com/prog/spec.asp?m=A7N8X-X&langs=01#
    nao
    Jun 2001
    tem certeza? estou querendo compra-la para usar com
    GEIL 512MB PC-3200 (400MHz) DDR RAM, 6 Layer Ultra Low Noise Shielded PCB, 64x8 Low Density/Unbuffered, Model# GE5123200B - 184-pin, w/ Heat Spreader CAS 2.5 6-3-3 2T
    GEIL e marca boa?
