    Mais um comparativo DX9 entre as melhores
    Agora usando tb o beta do Halo 1.5
    http://www.gamersdepot.com/hardware/...esktop/002.htm
    Se a NVidia não se cuidar a ATI vai dominar o segmento nos games DX9
    isso qdo sair algum jogo q use total dx9
    q ta foda :/
    eles soh pedem na instalacao, usar q eh bom...
    mas a nv tomo no bumbum :/
    hehee...
    If you’re still “stuck in the past” and think that ATI is plagued with driver issues, than go ahead and keep your head stuck in the sand like an ostrich, buy a 5900 Ultra and then start crying when your pals are smoking your ass in games like Half Life 2 and Halo because they’re running ATI hardware.
    Originalmente enviada por DekerBSB
    hehee...
    indeed
    UmK
    UmK está offline
    then, não than
    e nego paga pau mesmo pra ati heim ..
    que triste
    Essa eh pro diesel:
    Update: We emailed id Software guru, John Carmack about his experience with NV3x hardware on Pixel Shading performance, and this was his reply:
    GD: John, we've found that NVIDIA hardware seems to come to a crawl whenever Pixel Shader's are involved, namely PS 2.0..
    Have you witnessed any of this while testing under the Doom3 environment?
    "Yes. NV30 class hardware can run the ARB2 path that uses ARB_fragment_program, but it is very slow, which is why I have a separate NV30 back end that uses NV_fragment_program to specify most of the operations as 12 or 16 bit instead of 32 bit."
    John Carmack
    HAHAHAAHAHAH geforce FX eh mais rapida no Doom3 Pq roda todas a operações de shader com METADE OU ATEH MENOS DA METADE!!! Da precisao que os mesmos shaders rodam nas ATIs.
    Cara.. Ridiculo isso.. Essas FX são o maior lixo q eu ja vi
    O mais forte do universo!
    The Diesel?
    Saiu mais coisa a respeito no site da adrenaline
    Feb 1999
    Por favor, não comecem uma flame war. ATI tá melhor, não adianta, mas [b]por favor/b] não comecem
    Cade o tiu gasolina? AUIAhIHA
    (The Diesel! )
    até vejo quando o Doom III sair....
    se as Radeon ficarem na frente o DN Guest falando:
    -é pq não devemos confiar no Doom III...o lance é esperar o Quake IV...esse sim vai ser o jogo....vamos ver todo o potencial das FX.....bababa....bababa.....
    Membro Avatar de Arraso
    Apr 1999
    Realmente ATi é melhor, mas esse artigo da gamersdepot é muito tendencioso... Nossa, olha só a parte que o cara fala "chore dos seus amigos que rodam os jogos maravilhosamente bem nas Radeons", que idiota. Não pode ser assim :P
    Fora que ele também deveria pegar a opinião da nVidia sobre o assunto.
    As FX soh perdem, tah loko...
    Que Quake 4 que nada... só vai valer quando sair o PacMan 2004 otimizado para placas nvidia
