    Membro Avatar de Gung@
    Gunga
    Lançada a Audigy 2 ZS
    http://www.soundblaster.com/products...ro/welcome.asp
    E as caixas para acompanhar
    http://www.creative.com/speakers/series/inspire/
    Signal-to-Noise Ratio with AES17 filter (A-Weighted)
    2V Rated Output 1V Rated Output
    Stereo Output 108dB 102dB
    Front and Rear Channels 108dB 102dB
    Center, Subwoofer and Rear Center 108dB 102dB
    Total Harmonic Distortion + Noise at 1kHz (AES17) = 0.004% (1V, 2V Rated Output)
    Frequency Response (+/-3dB, 24-bit/96kHz input ) = <10Hz to 46kHz (1V, 2V Rated Output)
    High Definition Audio Quality for Playback and Recording
    24-bit Digital-to-Analog conversion during playback with sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz in 7.1 mode and up to 192kHz in stereo mode
    24-bit Analog to Digital conversion during recording in 8, 16 or 24-bit at sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz
    SPDIF (Sony/Philips Digital Interface) input at up to 24-bit/ 96kHz quality
    SPDIF output up to 24-bit at 48 or 96kHz
    ASIO 2.0 drivers for low latency (as low as 2ms) multi-track playback and recording at 16-bit/48kHz or 24-bit/96kHz
    Wave-Table Synthesis and Midi Features
    Creative Hardware synthesizer (2x16 Channels) with 64-voice polyphony featuring E-MU®'s patented 8-point interpolation technology for accurate sample reproduction
    Creative Software synthesizer - multi timbral wave-table (16 Channels)
    2 MIDI I/O ports (2x16 channels) (gameport adapter required for MIDI I/O 2)
    FireWire® (IEEE®1394) Connectivity
    FireWire® (IEEE®1394) / i-Link® compatible interface with up to 400Mbps transfer rate
    Sound Blaster Audigy 2 ZS Platinum Pro On-Board Connectors
    Line level out (Front / Side / Rear / Center / Subwoofer)
    Digital CD Audio in
    Aux Audio in
    AD_LINK 1 and AD_LINK 2 Connectors
    Power Connector
    15-pin MIDI/ Joystick port extension header
    Sound Blaster Audigy 2 ZS Platinum Pro External I/O Hub Front/Rear Panel Connectors
    Headphone Out (1/4" Stereo Jack)
    Line In 1 (1/4" Stereo Jack , shared with Microphone In with Gain Control)
    Line In 2 (1/4" Stereo Jack)
    Line In 3 (2x RCA Jack)
    Optical SPDIF In/Out
    Coaxial SPDIF In/Out
    Digital Out for 5.1 support (6-channel SPDIF Output to Creative digital speakers)
    2x FireWire® (IEEE®1394) ports
    MIDI In / Out
    Infra-red Receiver
    AD_LINK 1 and AD_LINK 2 co
    Membro Avatar de Mitsu
    Re: Lançada a Audigy 2 ZS
    Se for o mesmo tipo de saida otica da Audigy2, entao continua sendo um conector inutil.
    Agora, se essa saida tiver conexao pra caixas 5.1 Doulby, opa, ja to comprando isso. (duuuuvido q tenha)
    meu topico sobre saidas oticas da Creative
    http://forum.hardmob.com.br/showthre...hreadid=241515
