    Membro Avatar de hirohd
    Mar 1999
    prolink fx5200 128.... veja resultados no riva tuner...
    essa placa custa 69 dolares no paraguai... e vem com memoria samsung TC60
    $ffffffffff ---------------------------------------------------
    $ffffffffff Northbridge information
    $0400000000 Description : VIA KT266/333 series
    $0400000001 Vendor ID : 1106 (VIA)
    $0400000002 Device ID : 3099
    $0400000003 AGP bus : revision 2.0
    $0400000004 AGP status : enabled
    $0400000005 AGP rate : 1x 2x 4x supported, 4x selected
    $0400000006 AGP SBA : supported, enabled
    $0400000007 AGP FW : not supported
    $ffffffffff Display adapter information
    $0000000000 Description : NVIDIA GeForce FX 5200
    $0000000001 Vendor ID : 10de (NVIDIA)
    $0000000002 Device ID : 0322
    $0000000003 Location : bus 1, device 0, function 0
    $0000000004 Bus type : AGP revision 3.0 (AGP 2.0 mode)
    $0000000005 AGP status : enabled
    $0000000006 AGP rate : 1x 2x 4x supported, 4x selected
    $0000000007 AGP SBA : supported, enabled
    $0000000008 AGP FW : supported, disabled
    $0000000009 Base address 0 : e0000000 (memory range)
    $000000000a Base address 1 : d8000000 (memory range)
    $000000000b Base address 2 : none
    $000000000c Base address 3 : none
    $000000000d Base address 4 : none
    $000000000e Base address 5 : none
    $ffffffffff NVIDIA specific display adapter information
    $0100000000 Graphics core : NV34 revision A2
    $0100000001 Hardwired ID : 0322
    $0100000002 Memory bus : 128-bit
    $0100000003 Memory type : DDR (RAM configuration 07)
    $0100000004 Memory amount : 131072KB
    $0100000005 Core clock : 249.750MHz
    $0100000006 Memory clock : 165.375MHz (330.750MHz effective)
    $0100000007 Reference clock : 27.000MHz
    Comentários?
    Mar 1999
    4537 no 3dmark 2001... lixoooooo
    Originalmente enviada por EC - Hiro
    Muito provavelmente é de 64bits - no RivaTuner ainda não está implementada a detecção do bus memory das FX's, ou seja, mesmo se o bus for de 64bits ele irá informar como 128bits.
    250/230?
    Membro Avatar de edsonmassao
    +15 anos de hardMOB
    Comentários?
    vc mesmo respondeu a sua pergunta
    com certeza eh 64bits... a minha 128bits faz + de 7100... com um athlonxp 1700+ sem over e 256mb ddr333 spectek numa k7n2 delta-l
    Na moral meu score com uma MX440 64bit eh de 4851 pra uma fx ta baixo bagarai
    no meu xp1700, na ecs k7vta5 com 512 ram sansung deu 7000 pontos no 3d2k1. eh uma xfx 5200 (nao ultra)
    MacTrash, ..... a minha placa é uma ECS K7VTA3 mais athlon xp2000+, com 512 de ram e uma fx 5200 da xfx, 128 Mb (4ns)e oito modulos de memoria.... só esta dando 6400 3dmarks....o que tem de errado?
