    Dual Radeon 9800 PRO
    http://www.hwupgrade.it/articoli/905/scheda_big.jpg
    fala galera nao sei c vcs sabem .. mais vi isso hj navegando pela net ... hauehueahuea
    A card Sapphire video with 2 dissipators of heat mounts to you? Of what never it will be able to be be a matter?
    Simple, of a prototype of card Radeon 9800PRO MAXX, equipped therefore of two chip R350 it mounts to you on an only operating PCB and in parallel. A so-called one "dream card", in the sense that would allow unfortunately to obtain velocistiche performances from dream but of a dream draft, not being working.
    The Sapphire technicians have tried to make to work this card, resolving vary problems of thermal nature (2 not little chip R350 to 0.15 micron of scaldano production process) but the product is not however such from far being able to be also close to the phase of commercialization.
    It remains however extremely interesting to see as Sapphire has been able to develop this type of technology, this prototype moreover makes very to hope that in a near future Sapphire can be in a position to experimenting with these solutions multichip in an only card, with the next generation of chip vidoe ATI of even wraps high, before with production process to 0.13 micron (is speaking obviously about R423).
    Interesting to notice in the skillful part superiroe the diagnostic system with led, one Firewire door, connector video out and the traditional connector of Molex feeding to 4 pin. On the frontal panel they detach 2 connectors DVI for monitor, with to the center a connector S-video for video out.
    Later, with other news from Taipei on cards mothers Athlon 64 and it arranges Barebone Minium-PC.
    vale a pena ?
    se eu ganhar na mega sena com certeza hehehe
    Membro Avatar de Tcool
    Jan 2001
    O esquema eh uma placa mae haiuahiuahaiuh !! kct.. imagina qq nao deve ser! !!
    hauehuahe nossa imagina a performance...!
    nossa senhora....! uma dessas com um Prescott + 1gb DDR 400mhz hauehauehuahe quero mais nada na vida....................
    Socorro!
    O mais forte do universo!
    The Return of Voodoo's?
    UmK
    UmK está offline
    hoax?
    Originalmente enviada por UmK
    hoax?
    talvez.. ou nao pq nem funfa essa porra
    hoax?
    parece, o segundo gpu ta muito isolado e sem trilhas na placa ao redor dele (igual a Voodoo5 6000 de demonstração, q os gpu´s não eram em linha)
    e tipow, q q eh aquele monte de conector de som nela tá atras ? (igual de cd-rom)
    Originalmente enviada por Pacote-san
    ou não MESMO
    o R350 tem suporte a multiplos chips ?
    acho que não é só ir juntando os chips na placa
    ou não MESMO
    tipow, ou sim neh ?
    agora q vi q a placa tava na Computex
    seria muito interessante
    mas as fontes tbm teriam q ser ANTEC 550W p/ cima
    edit: opz, floodei
    UmK
    UmK está offline
    esse ingreis tbem ta foda heim
    BOMsoMITO 2018!
    aqueles conectores sao do Rage Theater , VIVO etc
    Nov 1999
    Nossa q horrivel ASHEoAISEHAS
    Mto mal feita, akilo ali ou vc encaixa no slot ou encaixa no gabinete =]
    mas pow, dentro ?
    vai dizer que essa aí é uma AIW tbm ?
    nem eh, ta rulez
    só q deve gastar pouca energia
    sem falar q naum funciona
    Nov 1999
    Pra funfar ela vai vir com um cabo que vc liga direto na tomada de 220
    ehehe, e com uma tomada trifasica
    Membro Avatar de Alexandre_POA
    Mephisto_POA
    mas uma coisa vai ser, nao tem banda suficiente da memoria pra placa, pq imagina 2 canais separados de 256 bit pra cad aprocessador, uma placa com esse layout saira mais cara q 2 ou 3 9800 normais pela complexidade dela
    alem do mais, talvez façam um canal soh de 256bit pras 2 cpus, ou seja, nao vai ser 2x mais rapido e sim 1.5x mais rapida no maximo...
    IMAGINA O TAMANHO DA ALL-IN-WONDER DUAL 9800PRO????
    mas essa placa é destinada a jogos ? deve ter uma performance destruidora , no meu gabinete cabe uma placa dessa
    Originalmente enviada por Mephisto_POA
    acho que não é bem assim , r300 tem banda de memória desproporcional pra aguentar 6X FSAA sem muita perda de performance , mas se desligar o AA pode ser perfeitamente 2X mais rapida
    Mephisto_POA
    Originalmente enviada por q3fragger
    estranho q se tu poe filtro em jogos novos em resolucao de 1600x1200 fica lerdo
    Membro Avatar de masK-
    jah tem tempo pra ela ser lancada, tipo, preco correspondente?
    Pô pessoal, le a matéria, foi só um protótipo, feito com 10 layers, um absurdo... além de nunca ter funcionado...
    Mephisto_POA
    plac a de 8 layers ja eh um absurdo de cara, por isso q as 9500 sairam de producao, a placa dela era mt cara pra ser feita
    uma de 10 layers, bom , preco LAAAAAAHHHHHHHHHHH em cima
    nao justifica a performance, melhor esperar por algo optimizado em 1 processador soh
    placa de video pra 2 processadores e 2 canais de memoria tem q ser algo mt estudado, nao eh essa gambiarra q tao fazendo ai, isso n vai conseguir ter fins comerciais, soh eh pra brincadeira mesmo
    serah q vem ai uma voodoo5 6000 ou uma sli ?
