    6745 no 3dmark2001SE numa mx 440
    System Configuration
    Operating System Microsoft Windows XP
    DirectX Version 8.1
    Mobo Manufacturer MICRO-STAR INTERNATIONAL CO., LTD
    Mobo Model MS-6570
    AGP Rates (Current/Available) 4x / 1x 2x 4x
    CPU Unknown 2005 MHz
    FSB 133 MHz
    Memory 512 MB
    Graphics Chipset NVIDIA GeForce4 MX 440
    Driver Name NVIDIA GeForce4 MX 440
    Driver Version 6.14.10.4403
    Video Memory 64 MB
    Program Version 3DMark2001 SE
    Resolution 1024x768 32bit
    Texture Format Compressed
    FSAA Disabled
    Z-Buffer Depth 24bit
    Frame Buffer Double
    Rendering Pipeline D3D Pure Hardware T&L
    Detailed Test Results
    3DMark Score 6745 3D marks
    Game 1 Car Chase - Low Detail 123.8 FPS
    Game 1 Car Chase - High Detail 51.6 FPS
    Game 2 Dragothic - Low Detail 117.3 FPS
    Game 2 Dragothic - High Detail 51.7 FPS
    Game 3 Lobby - Low Detail 115.8 FPS
    Game 3 Lobby - High Detail 55.6 FPS
    Game 4 Nature No hardware support
    Fill Rate (Single-Texturing) 485.9 MTexels/s
    Fill Rate (Multi-Texturing) 926.1 MTexels/s
    High Polygon Count (1 light) 34.3 MTriangels/s
    High Polygon Count (8 lights) 6.9 MTriangels/s
    Environment Bump Mapping No hardware support
    DOT3 Bump Mapping 82.5 FPS
    Vertex Shader 43.2 FPS
    Pixel Shader No hardware support
    Advanced Pixel Shader No hardware support
    Point Sprite 10.6 MSprites/s
    ae pessoal blz??
    esse score ta bom?
    meu pc eh
    athlon xp 2400+ (funfando a fsb 133)
    k7n2 delta L
    2x 256 dual channel ddr 400 GEIL ( funfando a 166(333))
    gf 4 mx 440 prolink 64 ddr
    como deu pau aqui, fexaram a conta do kitnet, coloquei o resoltado assim..
    oq posso fazer pra melhorar?
    to querendo colocar o fsb do proc pra 200
    Membro Avatar de Lestat Dane
    Tá muito bom cara!
    Muito mesmo!!!!
    consegui a mema coisa com uma soyo p4x400 + p4 2.0
    uma msi mx440 128bits 64mb DDR ( vendendo por 195 reais )
    isso tah mais do que bom velho!
    fiz um clockzinho nela agora,
    core clock tinha deixado 300 e o memory clock 500...
    mas ai começo a aparecer artefato entao deixei o core 300mhz e o memory 480 mhz...
    rodei o 3dmark dinovo, deu 7025
    ps: com esse overclock eh mto perigoso queimar a minha mxzinha?
    com esse clock soh aumentou alguns fps, nao mudo mta coisa.. acho q vo dar uma diminuida se aparecer algum artefato !
    agora imagina se fosse uma Ti4200, seria o dobro ehehe...
    Mas pra uma MX440 tá bom sim...
    Membro Avatar de rapz
    pqp...
    eu tenho uma dessas ae eu fiz soh 4000 ponto..
    tenho uma abit nf7-s em stock
    2200 +
    512 stock
    qual as config de oc q vc tah dexandu pra conseguir tantos pontos??
    a sua eh da xfx?
    a minh eh SE.. dah pra pegar regular ela pra quanto num oczinho?
    ta menos q minha gf4 se com xp 1.8
    eu tenho aqui uma XFX GF4 440MX e consegui 8750 no 3DMark2001 com uma A7V8X-X XP2400+, sem over
    11!
    Opa
    tem como vc deixar o seu sistema bem mais rápido sem fazer overclock nele.
    Ligue o computador e entre na BIOS (fique apertando DEL logo depois do apito do boot)
    Vai em Frequency/Voltage Configuration (ou algo parecido)
    Selecione o multiplicador 10x
    depois ajuste o FSB de 133 para 200.
    vc vai ter o mesmo clock final do seu processador, mas o seus sistema vai ficar mais rápido.
    mas isso com qto de FSB??
    fiz com 133, com 140 ja deu uma boa diferença, com 200 entao, deve chegar uns 8000 tbm
    soh nao da pra aumentar mais o fsb por causa dessa fonte satelite vagabunda
    olha aqui outro teste q fiz depois com fsb 140
    http://service.futuremark.com/compare?2k1=7067698
    Opa
    eu sei...
    soh nao passo dos 140 aqui por causa da fonte, qdo coloco 142 ja nao da boot ai tenho q mexer nos jumpers pra volta...
    semana q vem vo pega uma maxxtro, ou nao sei se espero ateh guardar dinheiro pra pegar uma fonte top, ai vo coloca o fsb em 200
    e as minhas geil kit dual channel tbm vao funcionar com fsb 200(400) (elas tao funcionando a 333)
    11!
    Originalmente enviada por Sc0uTTer SP
    Vc não está entendendo.
    Vc não vai aumentar a velocidade final do seu processador.
    o seu XP é um 2400+ certo?
    A velocidade real dele é 2000MHz
    Como vc está usando o FSB em 133 o multiplicador que está ajustado para ele é o 15 (15 x 133 = 2000)
    Se vc aumentar o seu FSB para 200 e abaixar o seu multiplicador para 10 vc vai continuar com os mesmos 2000 de velocidade final (10 x 200 = 2000), só que o seu sistema vai ficar mais rápido e a sua fonte tb não vai chiar.
    Se vc aumentar o seu FSB para 200 e abaixar o seu multiplicador para 10 vc vai continuar com os mesmos 2000 de velocidade final (10 x 200 = 2000), só que o seu sistema vai ficar mais rápido.
    eu entendi sim
    eu escrevi aquela mensagem pro walkovyr q falo q consegui mais de 8mil....
    eu sei...
    11!
    15 x 142 = 2130MHz
    Já é um belo over que o seu processador provavelmente não aguenta sem que vc aumente a tensão de alimentação dele.
    Faz o que eu te falei ae em cima que a sua fonte aguenta sem problemas o tranco, já que a velocidade final do seu processador não vai mudar.
    CONSEGUI 5700 :) OC de 333/500 na GF4 mx 440
    Ae galera !!
    EU nao consegui um resultado tao bom = o do cara q crio o topico .. mais acho q jah deu uma grande fiderenca !!
    de 3500 pulo pra 5700
    SYSTEM INFO
    System Info Version 2.0
    Installation ID 0x4b04ed0f
    OEM ID
    CPU INFO
    CENTRAL PROCESSING UNITS
    Manufacturer AMD
    Family unknown
    Internal Clock 2.04GHz
    Internal Clock Maximum 2.04GHz
    External Clock 166MHz
    Socket Designation Socket A
    RESULTS
    3DMark Score 5678
    Game 1 - Car Chase - Low Detail 96.4 fps
    Game 1 - Car Chase - High Detail 47.0 fps
    Game 2 - Dragothic - Low Detail 89.6 fps
    Game 2 - Dragothic - High Detail 45.3 fps
    Game 3 - Lobby - Low Detail 94.9 fps
    Game 3 - Lobby - High Detail 51.2 fps
    Game 4 - Nature Not supported by hardware
    Fill Rate (Single-Texturing) 389.5 MTexels/s
    Fill Rate (Multi-Texturing) 718.7 MTexels/s
    High Polygon Count (1 Light) 34.2 MTriangles/s
    High Polygon Count (8 Lights) 7.8 MTriangles/s
    Environment Bump Mapping Not supported by hardware
    DOT3 Bump Mapping 48.0 fps
    Vertex Shader 41.5 fps
    Pixel Shader Not supported by hardware
    Point Sprites 9.3 MSprites/s
    DIRECTX INFO
    DirectX Version 8.0
    DRIVE DA GEFORCE 44.03
    Acho q da pra melhora esses Pontos
    Bah ta bom pra caralho!
    15 x 142 = 2130MHz
    eu ja testei mas nao consegui...
    fui ateh 142, sem aumentar o vcore pq eu ainda nao tenho mta noçao de OC..
    mas acho q vo pega pelo menos uma maxxtro 500w antes, vai q essa fonte satelite porcaria estraga, queima alguma coisa do pc..
    mas valeu pelo esclarecimento ae Thunder..
    me passa seu icq ae , vai q eu precise de ajuda em alguma coisa
    ou pega o meu ae, 122530483
    flw
    11!
    flw
    De nada
    ICQ tá no meu perfil
    só clicar lá.
    Membro Avatar de ViperDucks
    SE ajudar... aí vai:
    Athlon XP 1700 @ 1840Mhz, clock GF4 MX440 => 315/531 estável
    Marca VGZ Inno3d MX 440 64 MB
    3DMark2001 7735 pontos
    http://service.futuremark.com/compare?2k1=6496836
    Membro Avatar de SkyHakuu
    1600+ 256 pc 133
    com uma mx 440 se 4x memo 64bits com OC no max eu fazia 4.5k
    axo q sua pontuação ta boa.
    sem mudar o pc so coloquei uma 8500 retail e faço 8k agora.
    sua pontuação vai fica travada pela mx pq o resto do pc ta mtbom
    Originalmente enviada por ViperDucks
    aa cara .. sei lah pq eu nao consigo mais PONTOS !!
    meu pc eh bem melhor q o desse cara q conseguiu 7500 pontos !!
    soh se a MX dele for o ultimo modelo !! pq nao tem explicacao pra da mais pontos !!!
    minha vga eh da MSI Gf4 mx 440 ddr
    HUMM .. jah sei oq pode ser o pc dessa cara q tah fazendo diferença!!
    EH ESSA ABIT FODONA AE !!
    eu tenho esssa config
    MSI K7N2 Delta - L
    512 DDR 400mhz .. 2 256 Samsung --> DUAL
    Athlon XP 2800+ Barton
    Aero 7+
    GF4 MX 440 MSI
    Live 5.1 MP3
    Tah sem OC o pc .. mais o clock original eh 2094Mhz
    AE DESCOBRI PQ DA BASTANTE PONTOS !!
    GF4 128bits 8X AINDA IUAHHA
    a minha eh 64bits .. nem 8x eh iuahhua
    eh a primerona q SAIU pra vende !!
    TOH FELIZ COM 5700 pontos com ela AIUHAUa
    mais o teu tah bom pra caralho tb pqp
    8000pontos com gf4 mx neh MOLE NAO hehe
    mas olha o clock do kra, puta clock MSI Geforce4 MX440 8x 128mb @381/576
    q q eh? WC na placa?
