    Membro Avatar de RubberSoul
    Mar 2001
    Melhor Mobo pra P4 com: (Só entrano pra ver)
    - Raid
    - HT (800Mhz)
    - Sata
    - AGP 8x (acho que todas as novas tem, me corrijam se estiver errado)
    -> Duvida basica: Dual Sata (2x Sata) substitui Raid?
    Acho que ABIT IS7
    Abit IC7-Max3 ou
    C/B Abit IS7 ou ASUS P4C800 (acho q é a C)
    Só SATA já substitui raid, se vc tiver 2 hd serial
    Membro Avatar de Lestat Dane
    Melhor:
    Abit IC7-Max3
    Asus P4C800-E
    Custo beneficio
    Abit IS7
    Asus P4P800 DLX
    asus p4c800 deluxe
    tem tudo isso, tem PAT que melhora a performace
    to vendendo uma novinha, se quiser ela eh soh dar um toque
    no icq da assinatura
    SOH PRA AVISAR, SOH DE BH TB, TU PODE PEGAR A MOBO PESSOALMENTE COMIGO, OU MELHOR, EU LEVO ELA NA SUA CASA
    Eu tenho a ABIT IS7-E por R$ 550,00:
    Features
    Processor
    - Supports Intel® Pentium® 4 Socket 478 processors (800/533MHz FSB)
    - Supports Intel® Hyper-Threading Technology
    Chipset
    - Intel® 865PE / ICH5
    - Supports Dual Channel DDR 400 Memory
    - Supports Advanced Configuration and Power Management Interface (ACPI)
    Memory
    - Four 184-pin DIMM sockets
    - Supports 4 DIMM Single/Dual Channel DDR 400 memory
    - Supports 4 DIMM DDR400 up to 4GB
    AGP
    - Accelerated Graphics Port connector supports AGP PRO 8X/4X (0.8V/1.5V)
    LAN
    - 3Com Gigabit Lan 10/100/1000MB
    Serial ATA
    - 2 channels Serial ATA 150MB/s data transfer rate
    USB 2.0
    - 8 ports USB 2.0 supports 480MB/s data transfer rate
    Audio
    - 6-Channel AC 97 CODEC on board
    - Professional digital audio interface supports 24-bit S/P DIF optical In/Out
    System BIOS
    - SoftMenu™ Technology to set CPU parameters
    Internal I/O Connectors
    - 1 x AGP PRO, 5 x PCI slots, 1 x Floppy Port supports up to 2.88MB
    - 2 x Ultra DMA 33/66/100 Connectors
    - 2 x Serial ATA 150 Connectors
    - 2 x USB 2.0 headers
    - 1 x CD-IN, 1 x AUX-IN
    Back Panel I/O
    - 1 x PS/2 Keyboard, 1 x PS/2 mouse, 1 x Printer Port, 1 x COM port
    - 1 x S/PDIF Out connector, 1 x S/PDIF In connector
    - 1 x Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
    - 2 x USB 2.0, 1 x RJ-45 LAN Connector
    - 2 x USB 2.0
    Miscellaneous
    - ATX form factor
    - Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
    Especificaçoes
    -Socket 478 for Intel Pentium 4/ Celeron up to 3.2 GHz+
    -Intel Hyper-Threading Technology ready
    -New power design supports Intel next generation Prescott CPU
    Chipset Intel 875P MCH
    Intel ICH5
    Front Side Bus 800/ 533 / 400 MHz
    Memory -Dual Channel Memory Architecture
    -4 x 184-pin DIMM Sockets support max. 4GB PC3200/PC2700/PC2100 ECC/Non_ECC DDR SDRAM memory
    -Intel Performance Acceleration Technology
    Expansion Slots 1 x AGP Pro/ 8X/ 4X (0.8V, 1.5V only)
    5 x PCI
    1 x ASUS WIFI Connector for optional wireless LAN upgrade
    Storage South Bridge:
    2 x UltraDMA 100
    2 x Serial ATA
    Promise 20378 RAID controller:
    1 x UltraDMA 133 support two hard drives
    2 x Serial ATA
    RAID 0, RAID 1, RAID 0+1, Multiple RAID
    AI Audio ADI AD1985 SoundMAX 6-channel CODEC
    Audio Sensing and Enumeration Technology
    support S/PDIF out interface
    AI LAN 3COM 3C940 Gigabit LAN PCI Controller supporting 10/100/1000 BASE-T Ethernet
    Virtual Cable Tester™ Net-Diagnosing Utility
    AI BIOS Feature CrashFree BIOS2, Q-Fan, Post Reporter
    AI Overclock -Intelligent CPU frequency tuner
    -ASUS JumperFree
    -CPU, Memory, and AGP voltage adjustable
    -SFS (Stepless Frequency Selection) from 100MHz up to 400MHz at 1MHz increment
    -Adjustable FSB/DDR ratio. Fixed AGP/PCI frequencies
    -ASUS C.P.R.(CPU Parameter Recall)
    IEEE 1394 VIA 1394 Controller supports 2 x 1394 ports
    USB Max. 8 USB2.0 ports
    Special Features InterVideo WinDVD Suite
    Power Loss Restart
    ASUS Q-Fan technology
    ASUS EZ Flash
    CrashFree BIOS2
    ASUS POST Reporter
    Multi-language BIOS
    Asus Instant Music
    Asus MyLogo2
    Back Panel I/O Ports 1 x Parallel
    1 x Serial
    1 x PS/2 Keyboard
    1 x PS/2 Mouse
    1 x S/PDIF Output
    1 x IEEE1394
    1 x Audio I/O
    4 x USB 2.0/1.1
    1 x RJ45
    Internal I/O Connectors 2 x USB 2.0 connector support additional 4 USB 2.0 ports
    CPU / Power / Chassis FAN connectors
    Chassis Intrusion
    S/PDIF out connector
    CD / AUX / Modem audio in
    1 x IEEE1394 ports
    Front Panel Audio connector
    COM2 connector
    GAME/MIDI connector
    20-pin ATX Power connector
    4-pin ATX 12V Power connector
    BIOS Feature 4 Mb Flash ROM,AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, Multi-language BIOS, ASUS EZ Flash, MyLogo2, ASUS C.P.R.
    Industrial Standard PCI 2.2, PCI 2.3, USB 2.0
    Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion, SM Bus
    Support CD Drivers
    ASUS PC Probe
    Trend Micro™ PC-cillin 2002 anti-virus software
    ASUS LiveUpdate Utility
    Accessories User's manual
    2 x UltraDMA 133/100/66 cable
    2 x Serial ATA cable
    1 x IDE cable
    FDD cable
    I/O shield
    Form Factor ATX Form Factor 12”x 9.6”(30.5cm x 24.5cm)
    Asus P4C800 Deluxe
    Ele pergunto a melhor e não a que vcs usam...
    Volto a repetir:
    Abit IC7-MAX3
    Asus P4C800-E
    Custo/Beneficio
    Asus P4P800 DLX
    ABIT IS7
    Mar 2001
    Bom, as placas pelo que já vi são essas mesmo, agora sobre o Sata substituir RAID? Como é isso? Quer dizer que se eu usar um HD Sata fico com as duas IDE's livres pro que eu quiser? Ou cada porta Sata dá direito a 4 componentes?
    Originalmente enviada por RubberSoul
    2x SATA não substitui RAID.
    Para se fazer RAID em stripe, mirror, etc é necessário SATA RAID.
    Sim, se vc usar HD SATA ou HD IDE com adaptador pra SATA no canal SATA, você irá ter as 2 IDEs livres.
    Que eu saiba, cada canal SATA da pra ligar 1 HD somente.
