    Mar 2000
    ECS fabricando placas mãe com Nforce2
    hehehhe
    qto sera q custara por aki???
    tomara q seja barato ai sim dara pra montar um PC de baixo custo com desempenho legal
    Special Features
    -- nVIDIA nForce2 Ultra400 & MCP
    -- Dual DDR-400
    -- FSB 400
    -- CMI9739A wirth 6-Channel Audio
    -- Color-coded pin headers and slots
    Processor
    -- Socket 462 for AMD AthlonXP/Athlon/Duron processors
    FSB
    -- 400/333/266MHz
    Chipset
    -- nVIDIA nForce 2 Ultra400 MCP
    IDE
    -- 2 x UltraDMA 133/100/66
    Memory
    -- 3 x 184-pin DIMM sockets support 2.5V DDR SDRAMs (Dual-DDR400/333/266)
    -- Maximum: 2GB for DDR 400, 3GB for DDR333
    Expansion Slots
    -- 1 AGP 8X slot
    -- 5 PCI
    LAN
    -- VT6103L 10/100 Mbps Faster Ethernet controller (optional)
    Audio
    -- CMI 9739A 6-channel CODEC
    -- Compliant with AC97 2.2 specification
    Back Panel I/O Ports
    -- 1 x PS/2 keyboard
    -- 1 x PS/2 mouse
    -- 1 x Parallel Port
    -- 1 x Serial Port
    -- 4 x USB 2.0 Ports
    -- 1 x RJ 45 Port
    -- 1 x Audio I/O (Line-in, Line-out and Mic-in)
    Internal I/O Connectors & Header
    -- 20-pin ATX Power Supply connector
    -- 4-pin ATX 12V Power Supply connector
    -- 360K~2.88M Byte, 3 Mode FDDs or LS120
    -- 1 x USB 2.0 header support additional 2 USB Ports (USB3)
    -- 1 x S/PDIF out header, 1 x CD-in header
    -- Dual PCI IDE interfaces, 4 IDE devices
    -- 1 x USB Card Reader Header
    -- HDD LED, ACPIMSG LED, Reset Switch, Power Switch Headers
    -- CPU / Chassis/Power FAN connectors
    -- Front Panel MIC/Line-in out header
    System BIOS
    -- Award 2Mb Flash EEPROM
    -- Supports Plug and Play 1.0A, APM 1.2, Muli Boot, DMI
    -- Full support for ACPI revision 1.0 specification
    Form Factor
    -- ATX Form Factor, 305mm*244mm
    Re: ECS fabricando placas mãe com Nforce2
    se for baratin ai vai ser doido mesmo.. vou ver quanto e essa placa na minha revenda. aff.
    Apr 2000
    A ECS sempre produz placa mae boa e barata, espero q continue assim com essa!
    Membro Avatar de Cara-de-pau
    Notícia bem interessante
    Opaaa
    tomara que chegue logo na Navenet pra ver por quanto eu posso comprar
    É, esperem sentados. A L7VTA chegou mais de 6 meses depois.
    Membro Avatar de Whisky
    Mar 2001
    Huheuah uia!!
    Kd os capacitores da placa?
    Um pcb roxo e meia duzia de componentes...
    Mar 2001
    Originalmente enviada por fredlwm
    Eh o tempo deles separarem todas as refurb e mandarem pro PY para que nos tupiniquins compremos!!
    Mas eu espero os 6 meses e cancelo minha compra da Asrock K7S8X agora!
    Originalmente enviada por Whisky
    [B]Eh o tempo deles separarem todas as refurb e mandarem pro PY para que nos tupiniquins compremos!!
    Com certeza. ECS nunca mais ! Minha K7S5A 3.1 não ligava se eu a deixasse desligada muito tempo. A K7VTA3 5.0 é muito pior. Até agora sempre ligou mas tem vários problemas. ASUS e ECS deve ser mesmo tudo refurbished. Espero que essa K7S8X não seja.
    Membro Avatar de Papaleu Paes
    Eu vi o futuro
    mo trauma de pcchips ehhehe mas pelo menos pode força as outras a baixarem o preço né
