    Membro Avatar de Paul Phoenix
    Pense e "monte" um computador com o máximo que o $$ pode comprar antes de clicar aqui
    Duvido que vc tenha chegado a 50% do que essa belezura é capaz de fazer...
    É inconcebível o poder desse equipamento.
    Confiram:
    - 3.8GHz* Accelerated Hyper-Threading Extreme Edition 2MB L3 Cache Intel® P4
    - 512K L2 Cache
    - Support for next-gen Pentium 5 Prescott CPU
    - 950MHz** System Bus
    - PuRam™ No System Hard Drive Configurable
    - Up to 1.000 faster than ATA/SCSI/FC HD based designs with Data Burst Speeds up to 8GB/s and I/O data requests at over 150.000 I/O sec.
    - Enhanced CacheFlow™ Technology
    - SuperBIOS™ IBPT Technology
    - 180W Sub-zero Vapor Compression Cooling
    - DDR-II Performance PC4200 533MHz Dual-Channel DDR, up to 4GB
    - Up to 16GB Total RAM with optional RamDrives.
    - Over 8.4Gb/s Memory Bandwidth
    - ATA-133 RAID, Serial ATA-150 Connectivity
    - UltraSCSI-360 & FiberChannel Expansion
    - Up to 2 Terabytes of Colossal Storage Capacity
    - Intel Performance Acceleration Technology
    - AGP Pro 8x Accelerated 256bit MemoryBus Radeon™ 9800 Pro Graphics with 8 Pixel Pipelines at 3.04Gp/s Pixel Fil rate, 21.8GB/bandwidth & Multi-monitor, High-Definition support
    - Ultra High-speed 8x DVD+/-RW Optical Drive
    - Front Panel Multi-information LCD Status Display, External removable HD Storage racks with LCD Monitoring or Multi-Optical Drives interchangeable bays
    - FireWire 400 & 800 Ports
    - Up to 8 Full-Duplex USB2 480Mb/s Ports
    - 6 Channel Digital IA Audio with Artificial Intelligence Audio-ensing Technology & S/PDIF Digital interface
    - 3COM Gigabit LAN with AI Net(Artificial Intelligence Net-Diagnosing)
    - Up to 74 32-bit or 64-bit PCI slots expandability
    - 650W VF-Speed Power Supply
    - AI Ultra-low noise Q-Fan technology
    - 802.11G Wireless LAN & Bluetooth Expansion
    - Artificial Intelligence Auto-Recovery BIOS
    - Absolutely stunning design combined high-end european critical components quality worksmanship.
    - Need more PCI slots for add-on cards for special projects and monstrous setups? Fear not! The revolutionary Mach 3.8 feature out-of-the-box, PCI expansion capabilities to up to 74 additional 32-bit or 64-bit PCI slots!
    - You will never run out of storage space again. Using either built-in RAID ATA133 and SerialATA-150, or optional UltraSCSI-360 or FiberChannel 800, the Mach 3.8 has up to 8 drive bays for up to a colossal 2 Terabytes of internal storage capacity. Three of the bays can be used as removable racks with individual LCD displays monitoring all drive parameters, and you can rest assured of long-term reliability as every drive has it's own cooling fan and heatsink, and is continuously checked for health and temperature and operation status.
    Quer colocar mais placas na placa mãe? Sem problemas. Esse computador possui um slot de expansão que vc pode conectar outra placa que suporta 74 SLOTS PCI de 32 ou 64 BITS!!!!
    Dois Terabytes de Hard Disk são suficientes para vc?
    O que achei de mais ridículo apenas foi o modem de 56K, que infelizmente é o gargalo do bichão.
    E se vc tentar adivinhar o preço tb vai errar...
    Apenas algo em torno de R$ 24.000,00
    Apesar de não ter $$ para comprar, achei que fosse muito mais caro, levando-se em conta que um INFOWAY PREMIUM está custando R$ 8350,00 e não deve fazer nem metade do que esse aqui faz...
    o q vcs acharam?
    PS: Isso não é Fake. É REAL!!!!!
    Membro Avatar de RYUDO
    VELHO JA POSTARAM AKI
    qual o tamanho do gabinete desse PC? na foto ele parece maior que o monitor, nao sei se é efeito já que esse comp. é meio "irreal"
    Membro Avatar de -|SLayerR|-
    loko!
    monitor vem junto?
    o gabinete 'e absurdamente comprido, tem um motor de geladeira dentor dakilo lol
    Membro Avatar de Skitter
    Yen
    Yen está offline
    BEM VINDO AO MÊS PASSADO
    ñ acredito q eu to vendo isso denovo
    putz...
    eh a décima vez q postam o mesmo topico... NA BOA, décima. aff
    antes de postar essas "new olds" da uma procurada no fórum pra ver se ngm ja postou isso antes....
    Jun 2001
    porra em vez de ficar falando que a noticia foi postada 100x, fica quieto e deixa o topico sumir da sua vista po
    se todo mundo jah viu, ninguem posta e o topico some em 30 minutos...
    stand up for your rise
    Nov 1999
    tudo bem que já postaram aqui .. mas ninguem é dono da verdade e sair apelando com o cara que criou esse topico ...deixa esse trabalho paa os moderadores...
    putz...
    eu acho q ja ta na hora de parar de FRESCURA NO RABO e infiar essa pistolinha no ** nao??
    pq ser agrecivo com o kra??
    meu, se vc nao tem nada de UTIL pra postar , nao fala bosta blz??
    vc nao viu o topico do FLIP FLOP , falando sobre os usuarios inuteis do hardwhat, q soh servem pra enxer o saco e atrapalhar??
    vc se encaixa mto bem nele
    entao, antes de posta essa bosta de pistolinha virada pra traz, pense bem e NAO POSTE esse tipo de merda q nao tenho menor saco de ver isso...
    sem mais viu...
    e tem mais, bando de otario
    "UHHHHH TOPICO VELHO"
    "UHH BEM VINDO À SEMANA PASSADA""
    se nao tem nada pra complementar o TOPICO, nao fale essa bosta , simplesmente CLIQUE NO VOLTAR ou NO "FORUM HARDMOB"...
    bando de sem noçao
    Membro Avatar de NIex
    apl525 here
    Faltou colocar que está disponivel a opção de HD em memória RAM 8GB/s com 0% de utilização da CPU.
    Isso ai é doidera, muita grana mesmo, mais que é bonito e rápido eh..
    Mar 2000
    Originalmente enviada por LoiZ
    tem um VAPOCHILL la dentro
    temps Negativas no processador
    gab deve ser bem maior q o monitor mesmo, ateh o Xaser II eh.
    Na minha facul tem um super servidor da SUN muito monstro, parece um frigobar, esse dai num deve fikar atras em tamanho.
    Mas tem uns negos q são burros mesmo né...
    Tá tá q o tópico foi postado 1 milhão de vezes... mais deixa o cara porra!!!!! Eu por exemplo não tinha visto esse tópico!
    Up pra vc E continue postando...
    PS.: Se alguem quiser me dar esse PC de presente, eu agradeço.
    Detalhe que nao é só nesse forum que postaram um monte de vezes
    Originalmente enviada por Razorblade
    mais mesmo assim eu não tinha visto
    =D
    eu tb nao tinha visto
    quem jah viu nem comente.. e deixe os que nao virem verem ueh!
    primeira vez que vejo também. Qual o link para estas info aì?
    eu ja tinha visto, mas meu, pq zua o kra?
    ele num tem culpa, os kras ficam falando
    "bem vindo a semana passada"
    ai o topico nao desce de jeito nenhum...
    mania desse pessoal q fica no boteco e vem pra k pra avacalhar..
    pelo visto o topico do FLIP FLOP nao ajudou mto
    meu, se eu ver essa pistolinha do skitter mais uma vez, vo clicar no "avisar moderador"...
    Jun 2001
    e eu aposto que eles fazem isso pra aparecer ta ligado
    tipo soh pra mostrar que eles sao os INFORMADOS
    Membro Avatar de Papaleu Paes
    Eu vi o futuro
    lindao esse led hein
    Se tu pensa pc nos eua é baratissimo... com menos de mil tu compra um mto bom ae nego nun tem onde gasta inventam essas merdas hehehe
    eu nunca tinha visto.
    e vão se fuder os nerds que entram em 500 foruns por dia, se liguem que tem pessoas que curtem viver o mundo REAL.
    Deixa os caras que entram aqui 2x por semana em paz.
    PS: deviam considerar posts de "é velha" ou "bem vindo à semana passada" como flood... se repetir muito é BAN...
    Originalmente enviada por Hitchhiker
    yep.
    ae, vc não errou o preço não??
    não seriam 24mil doletas americanas??
    bom se bem que ae tmb é exagero d+ ehhehe
