    uGURU da ABIT! interessante
    http://www.abit.com.tw/page/en/news/...CNO=en_0309184
    "OC Guru is a Windows-based overclocking utility that works through the ?Guru processor. With OC Guru, users can adjust CPU, AGP and memory voltage to find optimal system performance, as well as up the clock speed of the CPU by changing the front side bus speed. OC Guru also gives users the option of saving up to 3 different settings for specific applications, such as gaming, web surfing and CD burning or for 3 different users on the same system."
    UP!
    Membro Avatar de Seu Madruga
    li por cima....
    ta em desenvolvimento ainda neh? seria tipo o Forceware
    NEO
    NEO está offline
    Membro Avatar de NEO
    Dec 2000
    li por cima....
    Já eh real.... e disponível na AI7...
    ¦ÌGuru is a new microprocessor designed by the ABIT Engineers for use only on ABIT motherboards. ¦ÌGuru combines the ABIT Engineered features ABIT EQ, ABIT FanEQ, ABIT OC Guru, ABIT FlashMenu, ABIT AudioEQ and ABIT BlackBox into a user-friendly interface providing users the perfect environment with which to maximize performance and stability.
    http://www.abit-usa.com/technology/uguru.php
    mais isso ai e pra q ?
    Membro Avatar de rapz
    Originalmente enviada por Mkrafael | 2003
