    Roteador . Ajudem-me
    Alguem sabe a diferença entre TRIGGER PORT e PUBLIC PORT?
    Como sei qual é uma e qual é a outra, em games?
    NO manual do roteador está assim a explicaçao; que nao entendi:
    Setup | Advanced Settings | Special Application
    Some applications require multiple connections, such as Internet gaming, video conferencing, Internet telephony and others. These applications cannot work when Network Address Translation (NAT) is enabled. If you need to run applications that require multiple connections,-specify the port normally associated with an application in the "Trigger Port" field,select the protocol type as TCP or UDP, then enter the public ports associated with the trigger port to open them for inbound traffic.
    Example:
    ID Trigger Port Trigger Type Public Port Public Type Comment
    1 28800 UDP 2300-2400-47624 UDP MSN Game Zone
    2 28800 UDP 2300-2400-47624 TCP MSN Game Zone
    3 6112 UDP 6112 UDP Battle.net
    Obrigado
