    Catalyst 3.8
    saiu o catalyst novo
    eu nao tenho radeon mas parece q esse tem mtas coisas novas
    pra quem tem vale a pena experimentar
    tem até review na anandtech
    Ja instalei.......
    ainda nao testei em jogos, mais na parte de configuracao ficou mais legal, mais pratico, e tem uma nova funçao, SMARTSHADER ainda nao sei para qq serve
    Apr 2000
    pelo que vi na anandtech nao melhorou tanto a performance. Mas ja to baixando! to no 3.6 ainda
    Membro Avatar de NoOne
    queria testar mas nem rola mais
    massa...agora so falta pegar e testar...postem os seus resultados...e qual placa tao usando...!!
    pra q serve mesmo esse WDM capture ??
    Originalmente enviada por Mask-BLU
    pras AIW (ALL IN WONDER)
    eheh,
    When updating to current or future CATALYST™ releases your current color control panel profiles are no longer lost
    Setting the main OpenGL slider in the ATI 3D tab to quality no longer results causes games to run in 16bpp mode
    Disabling Extended Desktop when two display adapters are connected to four Displays no longer results in corruption on one display
    Help file is now available for brightness of TV under Windows XP with a RADEON™ 9800 series card installed
    The large desktop resolution setting are no longer displayed in the Setting tab once large desktop has been disabled
    Selecting the 3D screen saver during DVD playback when the display resolution is set to 1280x1024x16bit no longer results in display corruption being noticed on the overlay Repeatedly switching between a Full Screen DOS session and the window desktop no longer results in corrupt horizontal red lines on the CRT
    Entering the screen saver tab in the display properties and selecting 3D Flying Objects followed by entering standby mode no longer results in the Windows 2000 operating system rebooting
    The ability to extend the desktop while playing an MPEG file is now resolved
    The system no longer reboots when playing NEC dvd4 after changing the display from extended mode to clone mode
    The ATI Problem Report Wizard is now functioning properly under Windows XP The ATI RADEON™ 8500 no longer suffers from a Direct 3D performance decrease when the Windows XP desktop resolution is set to 32bpp
    Setting the display resolution to 1152x864 32bpp under Windows XP and playing an MPEG or AVI file no longer results in display corruption on the TV output
    Texture banding issues under OpenGL is now resolved
    Rulz, principalmente o negocio das Radeon 8500 @ 32bits no XP...
    Puxando...
    Membro Avatar de Seu Madruga
    puxando....
    Oba!
    Tava precisando formatar o Win mesmo
    Aiuoahuaouha
    Ainda to no 3.5 ou 3.6 nao lembro ;P
    tava com uma preguica e esperando o tao falado 3.8
    Assim q chegar em casa comeco o processo hehehe
    até qm fim
    por acaso alguem com catalyst 3.8 deu "timerefresh" no cs ?
    aki desde o catalyst 3.7 tah deprimente.
    GSJ
    GSJ está offline
    Jan 2001
    Originalmente enviada por [-GPON-]Mannie
    Ja instalei.......
    Para entender o Smartshader tu pode visitar estes 2 sites
    http://mirror.ati.com/products/cs/smartshader.html
    http://www.amd-insight.de/tests/graf...ich_eng/4.html
    é bem interessante.
    Membro Avatar de Soturno
    Já saiu o Omega baseado no Cata 3.8:
    http://downloads.driverheaven.net/om...omega_2487.exe
    What's New?
    (2.4.87)
    * Based on the official Catalyst 3.8 ATI drivers. (9x/ME/2k/XP)
    * All the new ATI Control Panel features included in the Catalyst 3.8
    drivers are fully available here. (9x/ME/2k/XP)
    * Added a new intro to the ATI drivers installation. (9x/ME/2k/XP)
    * Personalized the ATI Control Panel. (Watch out for COPYCATS). (9x/ME/2k/XP)
    * Disabled 32Bit Z buffer by default in D3D for low end cards (if you need
    it, you can enable it anytime in the ATI CP). (2k/XP)
    * Incorporated the 9500/9700/9800SE MODs for Windows 9x/ME. (9x/ME)
    * Added RadClocker and Artifact Tester 5 for Windows 9x/ME. (9x/ME)
    * Added support for the Radeon 9800XT. (9x/ME/2k/XP)
    * Added suport for other Mobility cards. (9x/ME/2k/XP)
    * Updated the DirectX Control Panel to version 9.0b. (9x/ME/2k/XP)
    * Added a tweak to remove black borders from TV Overscan. (9x/ME/2k/XP)
    * Added MWV video DX hardware accelaration support. (9x/ME/2k/XP)
    Pqp o Omega esculaxando como sempre!
    Eu particularmente acho o Omega a mesma coisa que o catalyst, porém com "frescuras" a mais.. o desempenho dos dois pra mim sempre foi o mesmmo!
    tah
    quem instalou, teve alguma melhoria ?
    Que isso cara, pra quem tinha o CS Bug como eu, melhorava mto!
    Aqui eu tenho um aumento de 500 3DMark01 usando o Omega ao invés do Catalyst (isso é na versão 3.7, na 3.8 ainda não testei)
    Membro Avatar de Tcool
    Jan 2001
    Aqui a imagem ficou d+++ com esse novo catalyst ( to usando o omega ).. mas perdi 100 pontos no 3dmark 2003.. o 2001 da um crep no meio dizendo que tem erro no dx8.1 etc... mas eu to usando o 9 hauiahiauh muito estranho...
    Jun 1999
    Eu já tava querendo formatar mesmo, agora tenho um motivo...
    Membro Avatar de agontijo
    Também notei uma clara melhora na imagem!!! To impressionado! Nunca tinha visto uma diferença entre um driver e outro assim.
    Não sei se eles melhoraram ainda mais o AA, ou o Anisotropic, mas que a imagem tá sensivelmente melhor tá sim! (Pelo menos no Medal e no BF1942)
    Em termos de performance, melhorou pouca coisa pra minha 9500PRO, uns 200 pontos (stock) no 3DMark2001... Nem testei no 2003 e no AquaMark3, mas com certeza a performance está levemente superior.
    Conclusão: vale a pena!
    Um abraço,
    Alex
    Old School 2001
    O Omega é um driver semelhante ao Catalyst ou seja quase o mesmo...tem jogos que pode rodar melhor com ele ou o mesmo corrigi um bug...mas tem jogos que piora, ou não roda como no caso do Halo..
    Omega já foi sinônimo de qualidade visual... hoje, no caso dos drivers catalyst não existe diferença... eu particularmente não uso mais os omega pq estão sempre perdendo uns fps nos jogos se comparados ao catalyst.
    Outra, esses drivers 3.8 não foram um tiro n'água(pelo menos para os usuários de 9700 pro), não mudaram praticamente nada, só fizeram uma maquiagem no Painel de Controle, juntando o d3d com o OpenGL, o que na minha opinião acabou embolando as opções.
    Quando falaram de profiles, eu pensei que iriam fazer um esquema em que vc setasse as opções para cada jogo e desse o caminho do executável, aí quando clicasse no executável, ele carregaria as opções pré-definidas, mas o que fizerem foi deixar os profiles lá pra eu escolher antes de jogar.
    Não estou falando que os drivers são ruins até pq ainda não testei direito, mas a palavra REVOLUÇÃO que eles usaram pra definir os novos drivers não se aplica meeeeeeesmo!
    Fui
    Zed
    Zed está offline
    Membro Avatar de Zed
    WAT?!?! WTF !?!?!
    aqui melhoro, ganhei 180 pontos no 3d mark 2001 = 12780
