Página 2 de 2 Primeira 1 2
    uai cara a placa tem q acompanha o resto do pc senao nao da..! e eu ja tenho uma BBA , essa q to olhando nao eh pra min noa...!
    kralho! eu queria uma POWERCOLOR dessas:
    PowerColor Radeon 9800 Pro uses the special Hynix HY5DU283222AF memory chips in 144ball FBGA form factor with 2ns access time that corresponds to 500Mhz effective! This is the highest clocked DDR-I SDRAM and probably the most expensive of all. These 2ns memory chips requires 2.8V VDD and 2.8V VDDQ power supply. Through a voltmeter check, PowerColor has set to VDDQ corresponds to the reference Radeon 9800 Pro card which is 2.68V so it is actually supply lower VDDQ to the memory chips and the VDD is at 2.94V. The memory chips do get hot after some time so some RAM sinks will be most recommended.
    aki vai uma foto !
    http://www.vr-zone.com/reviews/Power...00Pro/GDDR.jpg
