    Membro Avatar de POLAR
    Lançada Artic Silver 5
    Isso acabaram de lançar a Artic Silver 5, e pelo visto ta excelente ai vai um review:
    http://www.overklokking.no/annet/arc..._5/eindex.html
    Membro Avatar de Alexandre_POA
    Mephisto_POA
    poizeh , mas nao publicaram o k/w dela...
    Originalmente enviada por Mephisto_POA
    Tirado do próprio site da articsilver:
    Specifications:
    Thermal Conductance:
    >300,000W/m2 °C (0.001 inch layer)
    Thermal Resistance:
    <0.005°C-in2/Watt (0.001 inch layer)
    Average Particle Size:
    <0.49 microns <0.000020 inch
    Extended Temperature Limits:
    Peak: –50°C to >180°C Long-Term: –50°C to 130°C
    Performance:
    3 to 12 degrees centigrade lower CPU full load core temperatures than standard thermal compounds or thermal pads when measured with a calibrated thermal diode imbedded in the CPU core.
