    Doom3 rodará somente até 60fps
    At a recent NVIDIA Editors' Day, id Software CEO Todd Hollenshed announced that DOOM 3 will be capped to 60 frames per second in the rendering engine.
    We checked with John Carmack himself about why DOOM 3 will be hard-capped at 60fps in the renderer, and he had this to say:
    "The game tic simulation, including player movement, runs at 60hz, so if it rendered any faster, it would just be rendering identical frames. A fixed tic rate removes issues like Quake 3 had, where some jumps could only be made at certain framerates. In Doom, the same player inputs will produce the same motions, no matter what the framerate is."
    => http://pc.ign.com/articles/456/456054p1.html?fromint=1
    Pfff... na boa, só pra deixar os cara que pagam R$200,00 a mais para ter um monitor com 10Hz a mais em 1024x768 com raiva!
    Comédia isso... primeiro que para Doom3 tem que ver que placa consegue rodar com pelo menos 60hz 1024x768 com filtros tudo on! Hehehe
    Abraço
