Página 2 de 2 Primeira 1 2
    num pci 133........
    pode ate existir mas "seria capaz de operar a 600 gigaflops" kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkk
    aewww eu sou um power ranger.....e serio....
    o processador eh realmente veridico... look
    Breaking News - Platforms:
    ClearSpeed Announces CS301 Multi-Threaded Array Processor
    ClearSpeed Technology, a leading provider of high performance, low power chip-based solutions, announced the ClearSpeed CS301, a multi-threaded array processor that enables dramatic improvements in performance and power consumption for intensive floating point applications. At over 25 GFLOPS peak performance, the new chip provides more than twice the processing speed of competitive products. At 10 GFLOPS per Watt, power consumption is also 20 times more efficient. As a result, the CS301 delivers up to a ninety percent reduction in purchase price and running costs, making high performance computing affordable and available to companies of all sizes.
    "With conventional processor design, increasing performance has tended to come with real penalties in power consumption and heat dissipation, to the point where computing cannot keep up with the demands of today's emerging applications and rapidly increasing volumes of data," said Tom Beese, CEO of ClearSpeed Technology. "The CS301 is designed specifically to meet those needs with high performance, power efficiency and full programmability in C combined into a single chip. The CS301 is the first in a family of ClearSpeed microprocessors that we believe will challenge present day thinking by creating a world where scientists, bio-informaticians, engineers and content creators alike can have access to high performance computing anywhere, anytime."
    The CS301 is based on a multi-threaded array processing (MTAP) architecture and includes 64 processing elements, 384KB of on-chip SRAM and I/O ports interconnecting through ClearSpeed's ClearConnect bus. Each processing element has its own floating point units, local memory and I/O capability, making the CS301 ideally suited for applications which have high processing or bandwidth requirements. The ClearConnect bus is a packet switched network that provides high bandwidth and low power consumption, supporting multiple concurrent transfers giving even higher aggregate bandwidth.
    As a result, complex mathematically based applications such as, computational biology and drug discovery, digital content creation, nanotechnology development, scientific research and financial modelling can now be executed in a fraction of the time.
    "We are gratified to see the immediate high level of interest displayed by OEM's in the overall system improvements enabled by the CS301," said Mike Calise, president of ClearSpeed U.S. "The dual benefit of performance and efficiency is empowering companies to accelerate existing applications as well as inspiring them to explore new applications that were previously inaccessible."
    The CS301 can serve either as a co-processor alongside an Intel or AMD CPU within a high performance workstation, blade server or cluster configuration, or as a standalone processor for embedded DSP applications like radar pulse compression or image processing. In applications where the CS301 is acting as a co-processor, dynamic libraries offload an application's inner loops to the CS301. Although these inner loops only make up a small portion of the source code, these loops are responsible for the vast majority of the application's running time. By offloading the inner loops, the CS301 can bypass the traditional bottleneck caused by a CPU's limited mathematical capability, executing the core of the application more than twice as fast as anything else in the marketplace.
    "To deliver such high levels of performance with full programmability and outstanding gains in power efficiency is a very significant achievement," said Chris Piercy, president and chairman of the Northern California Nanotechnology Initiative. "We believe this technology will accelerate the development of nanotechnology and its applications across various industries by making high performance computing more accessible and scalable than ever before."
    The ClearSpeed CS301 is fully programmable in high-level languages and its software development kit is available now with a C compiler, graphical debugger and a full suite of supporting tools and libraries.
    Originalmente enviada por -YokasHi-
    Eu acredito mais no futuro do processador quântico do que nisso dae....
    sem dúvida...mas isso está muito longe. O processador quântico ainda não foi idealizado matematicamente pois existem vários problemas de concepção física com a matemática...mas pelo menos calcularam o fatorial de 5...mas as unidades mais complexas vão demorar. É uma aposta de loooongo prazo!
    Membro Avatar de DeatH
    GETTUDA CHOPPAH
    Dec 1999
    mais pro futuro ainda eh o computador celular em q o processador escolhe a melhor forma de processar por afinidade quimica/eletronica
    UmK
    UmK está offline
    Originalmente enviada por Kampf
    hummmm.. sei la...
    Esse negocio de placa PCI q c falo, foi so de exemplo ou eh PCI mesmo... pq tava pensando...
    O slot PCI nao ia ter banda pra isso nao ueh.. se quser saber nem um slog "AGP 16X" hehhehehe
    Tipo... alguem tem alguma noticia sobre PCI Master ?? Qual a banda dakele baguhlo ???
    vga tbem faz um estrago num slot agp... aumenta trocentas vezes a performace 3d
    pq esse nao faria no pci express?
    eu n sei... mas pode ser q seja util
    Originalmente enviada por UmK
    mas roda uma vga fudida em AGP 1x!! Fica um lixo.
    a Performance só aumenta pq o AGP lhe fornece a possibilidade.
    O processador pode até fazer um puta process, mas o problema é na hr de transferir dados.. PCI é muito baixo pra chegar a comparar q o pc vai virar um supercomput.
    Originalmente enviada por bobinhu
    agora voce imagina a temperatura dessa porra! voce tem que por na geladeira debaixo de nitrogenio liquido pra poder usar.... nao vai dar certo uEHuE
    le o topico todo, ele gasta 2 wats... cara, isso é MUITO menos que qq processador. Um duron 850 por exemplo usa 55w. Nem cooler precisa, so um dissipadorzim...
    O PCI que eles dizem não deve ser o PCI comun, fica meio dificil de acreditar ser o PCI puro mesmo...
    No minimo o PCI-Express
    mas pra chegar a tal performance, teria q ser um PCI express com uma taxa de transferencia bem alta...tal como o AGP.... ne naum?
    mas o pci express vai ser o dobro da banda do agp8x e ainda por cima nao vai dividir o barramento...
    Originalmente enviada por Thelord
    ai sim...pode até ser...mas é o tal negocio...vai ter q lançar muito rapidão esse pci pra os caras poder lançar esse processador na espectativa deles..
