    Warning no Sandra, Oq Fazer?
    Galera, nas informações do meu processador aparece o warning de que meus host controlers estão desabilitados e q eu devo checkar minha BIOS!!! Mas eu naum sei oq devo fazer, alguem ae pode me dar um help?
    Warning W2533 - The system has host controllers that have not been enabled by the BIOS/OS. It may be possible to obtain information by querying devices (if any) attached to these host controllers if they were to be enabled.
    Fix: Check BIOS settings and enable the host controllers. Or change Sandra options to enable them.
    E depois no ATAPI/IDE deu dois Warnings, e eu tbm naum sei resolver, os outros warnings ateh consegui, mas esses naum:
    ERRO 1 - Tip T3100 - SMART is not enabled. For safety/reliability it is best for it to be enabled. SMART monitors critical drive parameters and is able to warn you if the drive is about to fail so that you can back up the data and replace the drive. It has minimal performance impact that is offset by the security.
    Fix: Look in the BIOS settings and enable SMART monitoring for all drives.
    ERRO 2 - Warning W3104 - Current transfer mode not optimal, i.e. not highest supported. This affects drive performance. If the controller is also capable of the highest supported transfer mode, there is no reason not to use it.
    Fix: First check controller supported transfer modes. Then check the mode the driver for the controller/BIOS is set to use and modify; some default to a lower mode for compatibility. You may need to install newer drivers if the current drivers do not natively support the controller (especially for RAID). You may need to update the controller BIOS or drive firmware, if the mode does not stick. If data corruption occurs verify the cable and consider switching (if any) drives on the same channel onto other channels.
    Gostaria de q vcs pudessem me ajudar, desde jah agradeço a ajuda de vcs.
    Meu sistema está abaixo.
    Um Abraço,
