    TWT
    TWT está offline
    Barton virou Duron...
    tem como checar a numeração pra saber qual é o processador?
    Eu estranhei que no 3Dmark apareceu Family Duron(tm)isso é normal?
    O que pode ter de errado? pelo amor de Deus
    Resultados sem over.
    3DMARK2001 PROJECT FILE
    PROJECT
    Name Barton 2800+
    Description A7N8X 2.0 Deluxe | Barton 2800+ | 256 DDR 333 | Flatron F700P | Xelo FX 5200 | Cooled Volcano 7 | LG 52x24x52 | Maxtor Ata 133 40Gb | Maxxtro 500W |
    Resultado 7221
    3DMark Version 330
    DISPLAY
    Platform NVIDIA GeForce FX 5200
    CPU Optimization D3D Pure Hardware T&L
    Width 1024
    Height 768
    Depth 32 bit
    Z-Buffering 24 bit
    Texture Format Compressed
    Buffering Double
    Refresh Rate 60 Hz
    FSAA Mode None
    OPTIONS
    Show Title Screens Yes
    Continuous Benchmark No
    Benchmark Run Count 1
    Demo Sounds Enabled Yes
    Continuous Demo No
    Game Sound Effects Enabled Yes
    Game Music Enabled Yes
    Game Detail Level Low
    RESULTS
    3DMark Score 7221
    Game 1 - Car Chase - Low Detail 95.7 fps
    Game 1 - Car Chase - High Detail 49.6 fps
    Game 2 - Dragothic - Low Detail 111.0 fps
    Game 2 - Dragothic - High Detail 76.9 fps
    Game 3 - Lobby - Low Detail 111.2 fps
    Game 3 - Lobby - High Detail 54.6 fps
    Game 4 - Nature 21.0 fps
    Fill Rate (Single-Texturing) 508.7 MTexels/s
    Fill Rate (Multi-Texturing) 711.4 MTexels/s
    High Polygon Count (1 Light) 31.9 MTriangles/s
    High Polygon Count (8 Lights) 4.9 MTriangles/s
    Environment Bump Mapping 69.8 fps
    DOT3 Bump Mapping 60.6 fps
    Vertex Shader 43.0 fps
    Pixel Shader 47.3 fps
    Advanced Pixel Shader 26.4 fps
    Point Sprites 9.8 MSprites/s
    CPU INFO
    CENTRAL PROCESSING UNITS
    Manufacturer AMD
    Family Duron(tm)
    Internal Clock 2.08 GHz
    Internal Clock Maximum 3 GHz
    External Clock 166 MHz
    Socket Designation Socket A
    Type <unknown>
    Upgrade ZIF Socket
    Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
    Version AMD Athlon(tm) XP
    CPUID 0x000006a0
    TWT
    TWT está offline
    ai vai a numeração.
    AMD Athlon AXDA28000KV4D 939876627 0063
    AQXCA 0311RPAW 1999
    parece estar normal para a sua fx5200
    Membro Avatar de Skitter
    Isso é bug do 3dmark... pode ficar tranquilo
    o meu tbred ele reconhece como duron tb qndo vai mostrar o processador... no pcmark a msm coisa se n me engano... eh bug msm.
    TWT
    TWT está offline
    será que atualizar o detonator para 52.16 melhora ou piora?
    meu thorton tb vira duron nos futuremarks
    normal
