Página 2 de 2 Primeira 1 2
    AS 5
    2o. lugar fotografia hM
    Originalmente enviada por e2k ^ terrorisT
    na minha opiniao eh isso
    a céramique eh melhor cara, se vc eh contra ceramique vc tem direito de falar q eh contra, mas eu to falando pelo caminho q todos falam
    sempre tem o do contra uahuahu
    Mais me desculpe terrorist, só que a AS5 é ceramique tb .. não é que nem as AS3 e 2 que eram de prata, então ela é uma ceramique melhorada ..
    Então acredito eu que ela é melhor que a ceramique !!
    Originalmente enviada por surfing10
    mas ela é de prata
    Contains 99.9% pure silver.
    Not Electrically Conductive:
    While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
    http://www.arcticsilver.com/as5.htm
    e agora, conduz ou não ?
    se não conduz, pq pode causar problemas ?
    alguem testaê pra gente !
    ehauEhauEhuAHEau
    M> 1 - There are only "rumors" until now abot the whereabouts of Arctic
    M> Silver 4. What is the REAL reason? It's because in Japan they associate
    M> number 4 with death (or something)? Or "Céramique" is the number 4, just
    M> renamed? I would like a "official" answer about this, just to stop those
    M> rumors =)
    M> 2 - After launching Céramique, getting back to silver makes one wonder:
    M> Why? We all seen only advantages in Céramique, such as 0% conductivity,
    M> excellent thermal conductivity, and all that. Is that because you
    M> couldn't improve the Céramique anymore than you could do with the AS? Or
    M> is there any other reason? Because speking of Brazil (ack, I hate prices
    M> here), there will be much more market for Céramique then to AS5 or even AS3.
    Malogro,
    The number 4 in the orient is like the number 13 in western society,
    hence AS5.
    While Ceramique is a superb thermal compound, you can only do so much
    with ceramic conductive fillers. The higher conductivity of silver
    gives AS5 an advantage in performance. With the high heat generated
    by modern electronic components, some of our industrial customers need
    AS5. And of course there is the overclocking market where absolute
    performance is king.
    mas e á pra usar nos SouthBridge e NBridge ???
    Jun 2001
    Originalmente enviada por brUnO_cArDi
    Nos chipsets não brinca não. Vai de ceramique que mesmo se transbordar não tem problema.
    M> rumors =)
    Malogro,
    hence AS5.
    então a Ceràmique não pode ser mais "aprimorada" ?
    foi o que eu entendi com o "you can only do so much
    with ceramic conductive fillers"
    valew´z aê !
    mas ela é de prata
    ehauEhauEhuAHEau
    Pooo pelo o que ta falando não conduz então
    é, fala q não conduz
    mas tbm fala q não pode deixar ele "ligar" duas pontes pq ele é um pouco capacitativo e poderia pontencialmente causar danos
    mas se não conduz, pq poderia causar danos ?
    sinistro, não ?
    sinistro, não ?
    Estranho !!!
    11!
    sinistro, não ?
    Hehehhe pra entender isso vcs precisam estudar um pouquinho de Engenharia Elétrica.
    Acho que todos devem saber que um capacitor não conduz corrente contínua certo? Agora quando a corrente é alternada a coisa muda de figura e o capacitor passa a cunduzir essa corrente.
    O problema é esse. Quando vc liga o pc, até o estabelecimento do regime permanente contínuo, "pulsos" de corrente contínua se propagam pelos componentes, e são justamente esses pulsos que podem causar problemas, pois a naturesa capacitiva da pasta a transforma em uma condutora desses pulsos.
    ahmmmm...
    droga droga,
    vou ver se compro a ceramic mais para frente !!!
    por enquanto deixo o NB e SB do geito original
  14. #38
    então na pratica ela conduz
  15. #39
    Usando esse mesmo tópico..
    Me tirem uma dúvida...
    Mais ou menos...é bom limpar e aplicar mais pasta térmica de quanto em quanto tempo?
    Usei uma da coolermaster que veio no meu Aero7+ faz mais ou menos uns 2 meses...será que já tá na hora de trocar?
    A temperatura ainda se mantém na mesma...desde que eu apliquei.
  16. #40
    Vamos lá... Como disse, só vou postar em tópicos inteligentes e de discussão, na HardMOB não posto mais respondendo dúvidas e etc...
    1) Sempre usei AS3 no chipset e nunca deu nada, motivos: É só saber aplicar a pasta, uma fina camada com um cartão de crédito, e sem dexair borrar nenhum contato
    2) Comprei a Ceramique de 22g... Realmente ela parece "vagabunda" em relação a AS3 que tem uma coloração prata e passa mais confiança, mas comprei a Ceramique porque realmente nos reviews ela se sai MELHOR, e além da vantagem de sair (para mim) R$45,00 o tubo de 22g, que dá para utilizar umas 100 vezes se usar direito e sem disperdício... Para mim que uso no Northbridge, Southbridge e etc, deve dá para umas 80 aplic no processador...
    3) A AS3 conduz em corrente alternada, basta testar com um multímetro (uso um Minipa E-2020A, relativamente simples, paguei uns R$125,00), e realmente se ela deslizar cobrindo uma ponte do processador, pode dar curto circuito SIM
    4) A AS5 não vale a pena ainda, preço alto para apenas 2.7g, prefiro ter uns 2ºC, não ter risco de perder algum componente/placa e ter 22g...
    Sem mais
  17. #41
    Originalmente enviada por Prozac
    A temperatura me ainda se mantém na mesma...desde que eu apliquei.
    um ano, ou dois
    depende da pasta, se ela resseca ou não, ou qt tempo leva p/ ressecar
  18. #42
    Membro Avatar de edsonmassao
    +15 anos de hardMOB
    um ano, ou dois
    aumento nas temps sem ser perda de rotação do fan pode ser um bom indicativo de q tá na hora de trocar a pastinha né?
  19. #43
    Membro Avatar de TyresSmoke
    Olha vou deixar aki a minha opinião...
    Sempre gostei muito da AS3... mas um camarada meu comprou uma Ceramic e pedi pra ele se eu podia passar no meu P4...
    Em Idle realmente não melhorou... mas em Full baixou 2.5 graus... (isso com a temp ambiente nos mesmos 20 Graus)...
    O único problema é que para passar/tirar a Ceramic é de foder... Parece chiclete...
    Eu acho que praticamente acontece um empate entre as duas... (As3 / Ceramic) cada uma tem uma vantagem ou desvantagem...
  20. #44
    a Ceramic deve ser realmente boa para passar nos bridge, pois se tem essa aparência de borracha tlz ela aguente um dissipador cortado, na vertical. Sem precisar recorrer ao super bonder
