    May 1999
    Abit AN7 (Vai substituir a NF7 ?)
    Eu ainda n tinha ouvido falar deessa placa... Pelas especificacoes não parece ter diferencas brutais em relação a NF7-s.. Abaixo segue as specs:
    CPU
    Supports AMD-K7 Socket A 266/333/400 MHz FSB CPU
    Chipset
    NVIDIA nForce2 Ultra 400 chipset with MCP-T
    Integrated 128-bit memory controller
    Supports Advanced Configuration and Power Management Interface (ACPI)
    Accelerated Graphics Port connector supports AGP 8X/4X (0.8V/1.5V)
    Memory
    Three 184-pin DIMM sockets
    Supports 3 DIMM Un-buffered DDR 266/333
    Supports 2 DIMM Un-buffered DDR 400
    ABIT Engineered
    ABIT μGuru™ Technology
    ABIT SoftMenu™ Technology
    ABIT FanEQ™ Technology
    ABIT MaxFID™ Technology
    ABIT CPU ThermalGuard™ Technology
    ABIT FlashMenu™
    SATA 150 RAID
    On board SATA PCI Controller
    Support 2 channels SATA 150 RAID 0/1
    Audio
    6-Channel AC 97 CODEC on board
    Professional digital audio interface supports optical S/P DIF In/Out
    NVIDIA SoundStormTM Technology with real-time Dolby Digital 5.1 encoder
    LAN
    On board Realtek 10/100 LAN
    IEEE 1394
    3 ports IEEE1394 Supports 400 Mb/s data transfer rate
    Internal I/O Connectors
    1 AGP 8X/4X slot, 5 PCI slots
    Floppy Port supports up to 2.88 MB
    2 x Ultra DMA 33/66/100/133 Connectors
    2 x SATA 150 Connectors
    2 x USB headers, 1 x IEEE 1394a header, 2 x CD-IN
    Back Panel I/O
    1 x PS/2 Keyboard, 1 x PS/2 mouse
    1 x Serial Port connectors, 1 x Parallel Port connector
    1 x S/P DIF Input, 1 x S/P DIF Output
    Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
    2 x USB, 1 x IEEE1394 Connector
    2 x USB, 1 x RJ-45 LAN Connector
    Miscellaneous
    245 x 305mm ATX form factor
    PUTA MERDA GENTE! Pelo que eu to vendo essa placa tem suporte a 400mhz de FSB reais!!! ou seja 800mhz dual pumped!!! CACETE!!
    Saquem só:
    * The 800MHz FSB increases bandwidth and improves overall system performance.
    * Supports up to 3GB of Single/Dual channel DIMM modules, delivering bandwidth of 6.4GB/sec.
    6.4 GB/s de banda de memória!! BRUTALL!!!!! (como bota akela carinha de boca aberta/!?!? :drool: ??)
    Iii... cara eu acho que isso eh um erro do site da ABIT heim?
    RoAk
    2o. lugar fotografia hM
    Vai sim .. só que o lançamento estava previsto para final de Outubro e já estamos no dia 12 de Novembro e nada !!
    Eu ia compra-la .. mais dai demorou pra lançar, peguei a NF7-S
    ô louco! 400 FSB REAIS?
    Meio difícil isso dae heimmm!!!!
    Vo procurar me informar melhor....
    400 fsb reais? Tá, e cadê a memória que vai rodar a 400mhz? E cadê o processador que vai rodar a 400?
    Membro Avatar de TyresSmoke
    Tá parecendo placa de P4 isso ai !
    heheheheheh
    Membro Avatar de Lestat Dane
    Não entendi????
    Cade a memoria que vai rodar a 400mhz?
    Não seria as pc3200 pra cima?
    Cade o processador que vai rodar a 400?
    Não seria o Barton 3200+ ?
    Estou errado?
    Mar 2000
    gostei dos IDE pro lado ai fika mais facil de escondelos
    W00
    W00 está offline
    Jan 2001
    Originalmente enviada por Lestat Dane
    Não entendi????
    Estou errado?
    sim, está.
    hoje as memorias pc3200 rodam em 200mhz DDR. o pessoal diz 400mhz pq o DDR dobra a taxa, mas na verdade eh 200. 400mhz DDR seria 800mhz e q eu saiba ainda nao existe memoria nem processador q rode a essa frequencia.
    Membro Avatar de NoOne
    Bom pessoal, eu acho que de duas uma:
    Ou houve um erro do site da ABIT, especificando dados de motherboard P4 que é Quad Pumped (QDR) em vez de DDR.
    Ou a ABIT está integrando na motherboard um segundo canal, transformando a mesma em QDR.
    Até onde eu percebi, o que muda é o seguinte..
    - Layout, os IDEs ficam igual a Pentium 4.
    - Tinha especulações que falavam que ela teria o chipset (southbridge) MCP-S, que possui Sata integrado, o mesmo do nForce3. Porém pelo que parece que ela não possuira esse southbridge e sim o mesmo MCP-T da NF7-S.
    - Possui chip uGuru... (acrecentei)
    Bom.. tem muita especulação e pouca divulgação de informações concretas...
    Noone
    Onde vocês leram que ela possui 400MHZ de FSB !?
    Ela fala em processador com 400Mhz de FSB, e todo mundo sabe que AMDXP Barton é DDR, ou seja, 2x200Mhz efetivos..
    Originalmente enviada por W00
    sim, está.
    Memória não precisa rodar em sincronia. Não se esqueça de que o P4 possui FSB de 800Mhz, e as memórias não rodam em 800Mhz. Pra aproveitar a banda extra do FSB, existe o dual channel!
    E em relação ao CPU, qualquer um pode trabalhar com FSB igual ao seu clock interno(teoricamente).
    O grande problema é: Onde vão arrumar um chipset que trabalha em 800Mhz de FSB???????????
    Acho que eu saquei a parada dos 800MHz e dos 6.4GB/s
    É tudo muito teórico, o négocio é o seguinte, as NF7-S de hoje em dia já suportam isso, a conta é assim:
    200MHz = FSB do Sistema
    x2 = Por ser DDR
    x2 = Usando DualDDR
    Agora façam as contas:
    200x2x2 = 800MHz = 6.4GB/s
    Resta ainda alguma dúvida?!
    Membro Avatar de Skitter
    Originalmente enviada por RoAk007
    : eek :
    sem os espaços ->
    x2 = Por ser DDR
    x2 = Usando DualDDR
    Eita
    Tios
    Olhem na página da Abit
    A banda de 6.4Gb teórica nao foi o q surpreendeu, isso eu já sabia faz tempo
    O que surpreendeu foi que tá escrito 800FSB ne descrição (podem olhar)
    Entenderam?
    E esse 800FSB ñ tem nada a ver com o dual-ddr, ou eles colocariam na NF7-S também
    Eu acho mais provável ser erro de alguem la de dentro (achou q fosse placa de P4)
    PS: Esquece. Corrigiram
    Outro Detalhe é que agora tem s/pdif IN e OUT, nas NF7-S só tinha o OUT.
    Flávio
    Sigo não vendo nenhum 800MHZ
    Eu so vejo o 6.4GB/s que ja dei a explicação do porquê la de cima
    Bom, só pra deixa bem claro..
    200Mhz FSB, multiplicados por 2.. por ser DDR (dual data rate)..
    isso resulta nos DDR400, que por ser dual channel, multiplica-se novamente por 2.. Seriam teóricos 800MHz, multiplicados por 8bits, uma bandwidth de pico de 6.4GB/s
    Porém a bandwidth do processador com o Northbridge é de 3.2GB/s..
    Entao Ninguem, como eu disse
    Como eu disse, tava na página da Abit, mas eu avisei o tech support e eles tiraram (exprimenta clicar em overview )
    Maldade malogro
    Hehehehe
    Gente vcs estao viajando....
    FSB 400 pro processador eh mole... eh 200x 2.... e pronto...
    sobre a maxima largura de banda da memoria eh simples... ps dados sao armazenados em bytes na memoria certo.. acho que todo mundo sabe disso... bom vamos la as contas.....
    o dual channel implemente usando interleave um barramento de 128 bits com a memoria (single channel eh 64 bits..)
    como estamos falando em bytes.. 128/8 = 16bytes certo?
    Bom como a memoria estara trabalhando a 400 mhz.... ela conseguira transferir teoricamente 400 x 16 = 6,4GB/s ..... gygaBYTES por segundo saca...
    Eh isso ai... qq duvida eh soh perguntar....
    A ABIT naum errou em nada no site...
