Página 2 de 2 Primeira 1 2
    Originalmente enviada por Menge
    pra mim 60fps tah de ótimo tamanho jah
    acima disso pra mim eh mais o fetiche do negócio whauhwauhwuahuau
    pow... neh legal nao tirar 250fps em q3? hehe
    mais legal ainda é cravar 333fps no q3 e fazer o pulo ponte-rail com um pulo só, como eu fiz
    tem até demo foi mt rox auauieae rlz a lot
    Membro Avatar de NoOne
    não é mais lenta não... tanto que o cara tá usando elas e não uma memória qualquer.
    Da uma lida nisso:
    ECC
    All of these memory types come in ECC and non-ECC varieties. ECC stands for Error Correcting Code, which means there's an extra chip or two on each module to store check bits. ECC memory can correct single-bit errors, and detect mode multiple-bit errors. Not all motherboard chipsets implement ECC. If you put an ECC memory module into a motherboard which doesn't implement ECC, the memory will work fine but will not correct errors.
    Because it requires extra chips it is slightly more expensive than regular memory. Is it worth it? Well, how often does memory get random bit errors? Before Silicon Valley learned to use ultra-pure materials, bit errors were fairly frequent, due to the slight radioactivity from trace impurities in the chip itself. These days that problem has been solved, and the main source of bit errors seems to be cosmic rays from outer space. Not much we can do about that, aside from putting our computers a couple miles underground. Studies on this issue estimate that cosmic rays cause bit errors maybe one or two times a year per gigabyte of memory. To me, that's easily often enough to spend a few extra bucks preventing it. On the other hand, if you run Windows and therefore are used to your machine mysteriously crashing every few days, then you probably won't even notice the few extra crashes from memory errors.
    Registered
    Some high-end motherboards require registered memory. This doesn't mean it's listed with some Memory Board of Certification. Rather, it means the memory module has registers on it, to buffer the data before it goes to the motherboard. This helps make high speed access more reliable, although it ends up being very slightly slower than non-registered memory (and substantially more expensive). If your motherboard requires registered memory then you must use it, if not then you don't want it.
    ECC e Registered coisas diferentes
    Registered acabam sendo um pouco mais que as memórias normais.. e as com ECC também.. mas nada que interfira muito..
    Ele ta usando as Corsair RE
    Da uma lida nisso:
    Que tbm tem ECC, registered é mas um uma maneira de transferência de dados mais segura de trabalhar
