    problemas com detonator 53.03
    Alguem tá tendo problemas?
    com a minha ti4200 ele dá problema no direct3d
    olha soh o dxdiag
    System Information
    Time of this report: 1/8/2004, 15:24:29
    Machine name: LATANDER
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
    Language: Portuguese (Regional Setting: Portuguese)
    System Manufacturer: n/a
    System Model: n/a
    BIOS: Award Modular BIOS v6.0
    Processor: AMD Athlon(TM) XP 1800+, MMX, 3DNow, ~1.5GHz
    Memory: 512MB RAM
    Page File: 141MB used, 1109MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0b (4.09.0000.0902)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.0001.0902 32bit Unicode
    DxDiag Previously: Crashed in Direct3D (stage 2)
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: NVIDIA GeForce4 Ti 4200
    Manufacturer:
    Chip type:
    DAC type:
    Device Key: Enum\PCI\VEN_10DE&DEV_0253&SUBSYS_00000000&REV_A3
    Display Memory:
    Current Mode: 1024 x 768 (16 bit) (60Hz)
    Monitor: Philips 107S (107S2)
    Monitor Max Res:
    Driver Name:
    Driver Version: ()
    DDI Version:
    Driver Attributes: Final Retail
    Driver Date/Size: , 0 bytes
    WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
    VDD:
    Mini VDD:
    Mini VDD Date: , 0 bytes
    Device Identifier:
    Vendor ID:
    Device ID:
    SubSys ID:
    Revision ID:
    Revision ID:
    Video Accel:
    Deinterlace Caps: n/a
    Registry: OK
    DDraw Status: Disabled
    D3D Status: Not Available
    AGP Status: Not Available
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
    sempre qdo tento jogar quake3 ou algo assim o pc trava em 2 min
    alguem tah tendo esse tipo de problema?
    vlw
    ps: no detonator 43 nao dava isso
    need help.
