    Qual a melhor memória destas aki??
    Mushkin Blue Line 184 Pin 512MB DDR PC-3200
    Specification:
    Manufacturer: Mushkin
    Speed: DDR400(PC3200)
    Type: 184 Pin DDR SDRAM
    Error Checking: Non-ECC
    Registered/Unbuffered: Unbuffered
    Cas Latency: 2.5-4-4
    Support Voltage: 2.6V
    Bandwidth: 3.2GB/s
    Organization: 64M x 64 -Bit
    Warranty: Lifetime
    Model# 990992
    U$ 89,00
    como seriam 2 pentes ficaria U$ 178,00
    ou
    Mushkin 184 Pin 1GB(512MBx2) DDR PC-3200 Level One Dual Pack Specification
    Cas Latency: 2-3-2
    Support Voltage: 2.5V-2.75V
    Bandwidth: 3.2GB/s
    Organization: two 64M x 64 -Bit
    Warranty: Lifetime
    Model# 991089
    U$ 182,00
    ou
    Kingston ValueRAM Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200
    Specification
    Manufacturer: Kingston
    Cas Latency: 3
    Bandwidth: 3.2GB/s
    Warranty: Lifetime
    U$ 162,00
    ou
    Geil Golden Dragon Dual Channel 184 Pin 1GB(512MBx2) DDR PC-3200
    Specification
    Manufacturer: Geil
    Cas Latency: 2 6-3-3 1T
    Support Voltage: 2.55V-2.95V
    Bandwidth: 3.2GB/s
    Special Features: Wafer Level Chip Scale Package
    Warranty: Lifetime
    Model# GD3200-1000DC
    Item# N82E16820144603
    U$ 199,00
    ou
    Corsair Valur Select Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200
    Specification
    Manufacturer: Corsair
    Cas Latency: 3
    Bandwidth: 3.2GB/s
    Warranty: Lifetime
    Model# VS1GBKIT400C3
    Item# N82E16820145480
    U$ 155,00
    ou
    Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200
    Specification
    Cas Latency: 2-3-3-6 T1
    Bandwidth: 3.2GB/s
    Special Features: With Platinum Heat Spreader
    Warranty: Lifetime
    Model# TWINX1024-3200C2PT
    Item# N82E16820145450
    U$ 208,00
    qual destas eh a melhor em desempenho??
    valeuz
    ah, minha placa mãe eh uma Abit NF7-S Rev 2.0
    up
    Corsair e Kingston eu sei que são memórias mtoo boas, as outras eu não conheço mtoo bem. E pelo que eu sei as Corsairs superam as Kingstons. Tem uns modelos de Corsair com dissipador de cobra e talz, mtooo rulez... Eu pegaria se fosse vc Corsair.
    A primeira e a ultima
    vale mais a pena comprar 2 pentes da primeira mushkin ou a segunda mushkin q ja vem com 2 pentes?
    n entendi
    tipo quanto mais baixo o CAS eh melhor n eh?
    Membro Avatar de ferA_
    BEIJINHO NO OMBRO.
    Originalmente enviada por lqmotorbreath
    n entendi
    Independente da marca pegue o kit pronto que eh certeza que vai funfar em dual channel agora a respeito eu ia nessa aki ..
    Twin Corsair XMS LLPT c2 pc3500 1gb com o chipset winbound bh-5
    Twin = gemeos
    LL = Low lantecy
    PT = disspadores de platinum (acho que eh isso(
    c2 = cas2
    tem que ser esse chip que eh otimo pra oc.. + nau mtenho certeza se a corsair trabalha com esse tipo de chip..
    ou se naum uma otima opçao eh essa aki..
    Mushkin level2 Dual pack c2 pc3500 1gb com chip bh-5
    qualquer uma dessas 2 estaria otimamente servido para um oc cabuloso ..pode acreditar ..
    Ps : Achu que 512Mb resolve + se vc quiser gastar dinheiro ou se preparar pro futuro o que acho desnecessario pegue um 1gb.
    essas memos de 512mb taum saindo por volta de 550 a corsair e 600 a mushkin + vc consegue por mais barato com importadores como trem..soliman..A1 etc!
