    GSJ
    GSJ está offline
    Jan 2001
    ATI 9600NP = 9600 PRO =9600xt???
    Este texto foi inserido nos fórums da Adrenaline, como achei interessante, resolvi postar aqui na HM, que é um fórum de muito maior circulação. Não sei se é trova de gringo ... mas vale a leitura.
    Não me responsabilizo ...
    Postado p/ abubhz
    ATi Radeon 9600NP/Pro to 9600XT Flash Guide
    Hey guys, I posted in a thread yesterday saying that I was going to explain how to do this.
    The 9600Non Pro and Pro are indentical to the XT except for the clock speed difference. The 9600XT is clocked at 500/300 and is the sucessor to the 9600NP and 9600Pro based cards.
    We have showed you how to sucessfully flash your r300 based cards, now it's time for the 9600 series.
    Before you flash, make SURE that your card can handle 500/300 clocks stable. If your card cannot OC to these levels, do not flash your BIOS.
    Before you flash, make sure to uninstall your old video card drivers.
    HOW TO FLASH
    First you will need a copy of the 9600XT 128MB BIOS which can be downloaded HERE
    Once you have the BIOS you will need to have Flashrom 1.3. Flashrom is the program that you will use to flash your BIOS with.
    You can download Flashrom 1.3 HERE
    Finally, you will need a bootable disk. This will allow you to get to a DOS prompt to flash your BIOS. You can get a bootdisk from http://www.bootdisk.com , or if you need a bootable CD you can use Nero.
    Now you need to place the BIOS file and flashrom on your boot disk once it is created.
    The Flashing Procedure
    Assuming that you have your bootdisk with all files on it you can now flash. You will need to boot from the disk and do the following to flash:
    At the A:\ prompt type "FLASHROM.EXE" to run the program. A screen full of commands should load, simply press enter. Now type "FLASHROM.EXE -p 0 9600xt128.bin". Once you have completed this, it should write to the BIOS and verify it. Now you need to reboot your system and re-install your video card drivers.
    You should now have a fully functional Radeon 9600XT video card. You may also notice an increase in the memory overclock that you can obtain after flashing.
    If you have any questions you can contact me these ways:
    AIM: SaturnDS
    MSN: [email protected]
    EMail: [email protected] (I dont check email much)
    Happy benching!
    Eae? eu tenho uma R9600NP, 325/400.
    As memórias são da Samsung, 3.6ns, oque seria 550Mhz efetivo...
    É estranho ela vir a 400Mhz.
    Ao tentar rodar a essa velocidade aparecem uns pontinhos azuis na tela... não é bem aqueles artefatos que bugam toda a tela, anyway, não rodo c/ estes pontinhos p/ precaução.
    Tenho umas dúvidas, será que a Bios da R9600XT altera a voltagem da placa? pois se alterar até vale a tentativa, pois acredito que sem mais força acho que as memórias não aguentam 600Mhz.
    A GPU da NP é realmente igual a da PRO? então só não roda a 400Mhz p/ precaução? e exatamente p/ ter um dissipador e ventoinha mais fracos?
    Obrigado!
    cara
    acho q naum funciona pq as GPUS sao diferentes...
    GSJ
    GSJ está offline
    Jan 2001
    Originalmente enviada por Cracker Jack
    cara
    Ae é que ta, tu tem certeza? Pq pelo jeito o gringo ta falando que não, que é a mesma coisa...
    eu queria saber de qual fórum essa notícia saiu ... no fórum da adrenaline não mencionaram daonde saiu.
    eu queria ler mais a respeito.
    Valeu.
    GSJ
    GSJ está offline
    Jan 2001
