    RSA
    RSA está offline
    Membro Avatar de RSA
    Dec 1999
    Catalyst 4.1
    ATi has released v4.1 of it's Catalyst drivers.
    "New Features
    ATI OVERDRIVE(tm) Enhancement:
    ATI OVERDRIVE(tm) maximizes the performance of the graphic accelerator by increasing the speed of the graphics processor. This is done by constantly monitoring the temperature of the graphics processor, so that the maximum clock speed can always be maintained.
    The latest rendition of ATI OVERDRIVE(tm) now provides the user with more information on the temperature and frequency of their graphics processor. This feature is supported under the Windows XP, Windows 2000, and Windows 98/98SE and Millennium operating systems, and is supported on the following ATI RADEON(tm) products:
    -ATI RADEON(tm) 9800 XT
    -ATI RADEON(tm) 9600 XT
    OpenGL Shading Language Enhancement
    This release improves support for the OpenGL Shading Language (GLSL), a flexible, forward-looking, and hardware-independent high-level graphics programming language. The OpenGL Shading Language, defined as an open standard by the OpenGL Architecture Review Board, allows application developers to take advantage of the powerful programmable vertex and pixel processing units present in the 3D graphics system. This release includes changes to increase compliance with the final ratified GLSL specifications, adds support for projective texture sampling, and improves support for interactions between GLSL-based rendering and traditional fixed-function vertex and pixel processing. Developers who are interested in using the OpenGL Shading Language should visit our website http://www.ati.com/developer for more details and documentation."
    http://www.ati.com/support/driver.html
    Quem testou o que achou ?
    to usando o omega 3.9
    Po, esse overdriver é só para as Xt, q droga, na minha 9700 num rola
    Membro Avatar de edsonmassao
    +15 anos de hardMOB
    naum notei diferenças...
    continuo com o problema da tela ficar toda escura qdo uso motion blur
    alguem sabe o pq disso? tow com o patch 1.3.0 do jogo...
    edit: o jogo é nfsu
    Originalmente enviada por edsonmassao
    edit: o jogo é nfsu
    isso e problema do patch com o filtro AA
    e problema do jogo nao e do driver não !
    todo mundo da ATi e ate alguns da Nvidea q atualizaram pra 1.3 ta tendo isso, eu resolvi com um excencial
    desliga o AA
    nenhuma diferenca aqui
    ( e pra varia, tinha formatado 1 ontem )
    Membro Avatar de NoOne
    Denovo... hahahahaha!
    Ainda não baixei.. vo baixar agora e depois posto novidades.
    Quero ver se resolve as travadinhas no NFS Underground
    +15 anos de hardMOB
    Originalmente enviada por U-235
    desliga o AA
    po, aqui o AA fica em preferência do aplicativo e aniso deixo em 16x...
    antes do patch 1.3 naum dava isso =/
    esse driver eh pra XTs (9600 e 9800) se a sua placa n eh nenhuma dessas 2 n vai dar diferença mesmo né
    Apr 2000
    A7N8X-X
    R8500
    Testei de tudo!! Catalixo 3.9 e 3.10
    Omega 2.5.04
    AA ligado e desligado
    Aniso ligado e desligado
    Patch 1.3 e 1.4
    nForce 1.0 // 2.75 // 3.10
    Testei todas as combinações possíveis dos drivers acima e com todos eles o BM escurece.
    A única coisa que resolveu foi voltar com o need pra versão original do CD, 1.0.
    A boa é que para mudar entre 1.0 e 1.4 basta sobrescrever o "speed.exe", então se vou jogar na net mudo pra 1.4. Vou jogar sozinho volto pra 1.0...
    dcli 101
    Aqui não resolvou.. Continuou na mesma.
    Originalmente enviada por WarLocK
    Bom, segue as travadinhas..
    Mas achei o meu PC mais parelho agora.. parece que ficou mais redondo...
    Jan 2001
    alguem sabe se instala no 2003 Server ? Ontem mesmo formatei e coloquei, nao deu, descompactei e fiz a instalacao no manual e nao deu. Acabei voltando para o 2000pro formatando tudo bonitim hj, para depois q instalo o 3.9 da omega vejo q lancaram o 4.1 :/
    Ninguém de 9600xt ou 9800xt, para fazer o teste?
    pra mim pareceu que a qualidade da imagem melhorou.
    e o 3dmark ficou igual.
    Jul 2000
    eu uso o 3.10 sem problemas no 2003 enterprise server, quando chegar hoje em casa tento este 4.1.
    Para instalar o 3.10 bastou usar o modo de compatibilidade com o xp na instalação, está funcionando perfeito(3.10). Acredito que dê para fazer o mesmo com o 4.1
    Outra coisa, me desculpe o pessoal que formata todo mês (muitos dos que vejo por aqui), mas vcs não sabem manter o sistema operacional rodando perfeito? Formatar por causa de driver de vídeo é o fim da picada... tô a mais de 6 meses rodando o 2003 aqui sem formatar e sem perda de performance, claro 1 ou 2 vezes por semana eu tiro um tempo para corrigir qualquer problema e fazer meus procedimentos de manutenção.
    Membro Avatar de jtedaldi
    Para o topeiras nao é so pras XT, so elas que tem essa funçao inutil ai que permite fazer overclack mostrando a temperatura (muito pragraminha faz isso). Ja to baixando o meu aqui, eu estou com problema no COD (texturas cinzas) desde o catalyst 3.10, cheguei a usar o omega e tmb nao funcionou agora to na esperança desse funfar, por isso vo rodar ate o driver cleaner aqui antes!
    PElo que li no forum do driverheaven o pessoal gostou, claro que nao todos, mas muito falaram que ta rodando bem
    Qual a vantagem do Windows 2003 perante o XP !?
    Apr 2000
    SÓ PRA VCS VEREM O QUE ACONTECE QUANDO SE INSTALA OS DRIVERS DA MOBO DEPOIS DO DRIVER DA VGA:
    Montei o pc sexta passada.... tava usando tudo numa boa, catalixo 3.9 e nForce que vem no cd (acho q 1.0).
    Ae fui e fiz atualização pro nForce 3.10, olha o que aconteceu com meu desempenho:
    http://service.futuremark.com/compare?2k1=7464294
    Acho que o nForce sobreescreveu algum arquivo do AGP que é melhor usar o específico da ATI.
    Apenas reinstalei o catalixo 3.9 e tudo voltou ao normal.....
    Agora estou experimentando o Omega e ganhei uns 100 pontos em relação ao catalixo 3.10 mas dentro dos jogos nem notei diferença.
    http://service.futuremark.com/compare?2k1=7470030
    Que diferênça em PEPS ?!
    NoOne
    Apr 2000
    Foi absurdo!!!
    Num sei se rolou isso só comigo, mas se isso é geral a nVidia/ATI deveriam alertar para o problema!!!!!
    Quem pretende jogar Wolfenstein: Enemy Territory não deve instalar essa versão de catalyst
    Significant performance loss is noticed in Wolfenstein: Enemy Territory. This issue is already resolved and a fix will be available in the next CATALYST™ driver release
    Aqui continuo com o catalyst 3.7, que além de não ter nenhum bug em jogo é o drive que tem melhor desempenho (na minha máquina)
    Apr 2000
    Originalmente enviada por Ydur
    Já testou o 3.7 com o bur motion???
    Funcionou blz???
    Se tiver funcionado vou tentar....
    Originalmente enviada por PepsBull
    Funcionou blz???
    não funciona, eu tava usando ele e nõ funfa
    Pra instalar essa nova versao eh recomendavel desinstalar a anterior? Qual software para isso?
