    P4c800 DELUXE @ Qual o problema?
    Ate hj nao entedi qual o problema da Placa mae asus p4c800 deluxe
    me digam o q nao poderei usar nela?
    da pra coloca hd sata?
    up pra sabe o q ela tem d ruim
    Ela tem 2 entradas SATA e é uma ótima mobo, não vejo nada de 'ruim'.
    fonte : http://www.asus.com/prog/spec.asp?m=...eluxe&langs=01
    EU ACHO Q ELES FALAM Q O PROBLEMA EH COM
    3COM 3C940 Gigabit LAN PCI Controller supporting 10/100/1000 BASE-T Ethernet
    ALGUEM PODE AJUDAR??
    valeu
    Ter lan gigabit onboard é problema ?
    Agora tô curioso tmb :/
    Quem falou q essa mb tem algo ruim?
    Membro Avatar de duferrari
    Originalmente enviada por Kenshin
    Asus was the only board in the test field in the yellow board design (PCB) of the late 90s, if you ignore the colored RAM slots. Rather than using Intel's CSA protocol, the manufacturer has integrated a reasonably priced GBit LAN chip from 3COM-Chip (3C940 PCI), which communicates with the slow Southbridge (PCI). This is done with the sole intention of saving costs, which fans of the brand cannot understand. After all, the board costs around 280 euros, so it should still have CSA GBit LAN.
    Asus also omits the RAID controller in the Southbridge, and uses a Promise PDC20378 instead, which offers both IDE-RAID and Serial-ATA RAID. On the one hand, this saves costs of around three dollars (in quantities of 1000); on the other hand, the external chip is considerably slower than the integrated Intel ICH5 controller. Details are provided in our Storage Guide.
    alguem pode explicar que problema posso ter com a especificacao acima????
    O q eh raid?
