    Entrem !!!! URGENTE !!! Entrem !!!
    Caras....to assustado aki..acabei de ler no jornal :
    XFX Geforce FX 5200 256 MB 128 bit 379 R$
    Vejam as especificações dela :
    Features & Benefits
    CineFX Engine
    Powers cinematic effects beyond imagination. With advanced vertex and pixel shader capabilities, stunning and complex special effects are possible. In addition, increased horsepower delivers faster and smoother gameplay.
    AGP 8X
    Provides double the bandwidth of AGP 4X—2.1GB/sec. vs. 1.1BG/sec. AGP 8X enables more complex models and detailed textures, creating richer and more lifelike environments. Uninterrupted data flow allows for smoother video streaming and faster, more seamless gameplay.
    nView Multi-display Technology
    The nView hardware and software technology combination delivers maximum flexibility for multi-display options, and provides unprecedented end-user control of the desktop experience. NVIDIA GPUs are enabled to support multi-displays, but graphics cards vary.
    Digital Vibrance Control (DVC)
    Allows the user to adjust color controls digitally to compensate for the lighting conditions of their workspace, in order to achieve accurate, bright colors in all conditions.
    Unified Driver Architecture (UDA)
    Guarantees forward and backward compatibility with software drivers. Simplifies upgrading to a new NVIDIA product because all NVIDIA products work with the same driver software.
    Microsoft® DirectX® 9.0 Optimizations and Support
    Ensures the best performance and application compatibility for all DirectX 9 applications.
    OpenGL® 1.4 Optimizations and Support
    Ensures the best performance and application compatibility for all OpenGL applications.
    Integrated TV Encoder
    Provides best-of-class TV-out functionality for resolutions up to 1024x768.
    Integrated Full Hardware MPEG-2 Decoder
    Delivers full-frame, full-screen MPEG-2 video on your desktop.
    New 64-phase Video Scaler
    Highest quality for scaling DVD and other video to full-screen HDTV resolutions.
    DVI Support
    Able to drive the industry's largest and highest resolution flat-panel displays with up to 1600x1200 resolution.
    350MHz RAMDACs
    Supports QXGA displays with ergonomic refresh rates.
    Architected for Cg
    Ensures that the newest, cutting-edge special effects in applications will run flawlessly. Speeds up content creation so game developers can get their new games out to PC users faster than ever before.
    Specifications
    System Requirements
    Pentium® III/4/Celeron™ or AMD® Athlon®/Duron®
    AGP 2.0 or later AGP slot
    128MB of system memory
    Installation software requires CD-ROM drive
    minimum 250W system power supply
    DVD playback requires DVD drive
    Recommended
    Pentium® 4 or AMD® Athlon® XP
    AGP 3.0 Slot
    Graphics controller
    NVIDIA® Geforce FX 5200
    256 bit graphics accelerator
    Memory Configuration
    256MB DDR
    Performance
    Graphics Core: 256-bit <
    Pixels Per Clock (peak): 4
    Textures per pixel (max per pass) 16
    Effective Memory Clock: 333MHz
    RAMDACs: Dual 350MHz
    Operating systems support
    Microsoft Windows 95
    Microsoft Windows 98
    Microsoft Windows 2000
    Microsoft Windows ME
    Microsoft Windows NT 4
    Microsoft Windows XP
    Linux
    Monitor support
    D-shell (15-pin) VGA connector
    Display support
    Register compatible with VGA
    DVI-Out for sharp LCD monitor output
    Video out Module enabling big-screen gaming, digital timeshifting VCR, and video-editing applications
    Features
    Warranty
    Product warranty varies depending on Geographical region. For details warranty information for this product please contact the Pine branch in your area.
    VALE A PENA ???? SERA Q COMPRO ??
    Redação
    Avatar de Cadu®
    Brotherhood
    naum vale a pena essas 256.. mas se quiser arricar... por esse valor eu pegaria uma 128mb fx5600
    PQ NUM VALE A PENA UMA 256??
    Membro Avatar de Maurivillas
    Jan 2004
    Pq as memórias são mais lentas do que as de 128 Mb.
    Se comprar, não obterá o desempenho que espera por causa disso.
    Até!!
    Originalmente enviada por Boromir
    porque quando os jogos usarem 256Mb tua placa vai tar obsoleta...tipo o que aconteceu com minha TNT2
