    Alguem tem essa plaquinha ? => N2U400
    http://www.ecsusa.com/products/n2u400a.html
    da ECS
    Special Features
    FSB 400
    Dual Channel DDR400
    AGP 8X
    6 Channel Audio
    Color Map
    10/100 Lan (Optional)
    Processor
    Socket 462 for AMD AthlonXP/Athlon/Duron processors
    FSB
    400/333/266/200 MHz
    Chipset
    nVIDIA nForce2 Ultra400 & MCP
    LAN
    VIA® VT6103L 10/100 Mbps Faster Ethernet controller (optional)
    IDE
    2 UltraDMA 100 / 66
    Expansion Slots
    1 AGP 8X slot
    5 PCI
    Form Factors
    ATX Form Factor, 305*244mm
    Memory
    3x184-pin DIMM sockets support two 2.5V DDR SDRAMs (Dual-DDR400/333/266/200)
    Maximum: 2 GB for DDR 400, 3GB for DDR333
    Audio
    CMI 9739A 6-channel CODEC
    Compliant with AC97 2.2 specification
    Back Panel I/O Ports
    1 x PS/2 keyboard
    1 x PS/2 mouse
    1 x Parallel Port
    1 x Serial Port
    4 x USB 2.0 Ports
    1 x RJ 45 Port
    1 x Audio I/O (Line-in, Line-out and Mic-in)
    Internal I/O Connectors & Header
    20-pin ATX Power Supply connector
    4-pin ATX 12V Power Supply connector
    Dual PCI IDE interfaces, 4 IDE devices
    360K~2.88M Byte, 3 Mode FDDs or LS120
    1 x S/PDIF out header, 1 x CD-in header
    1x USB card reader header
    1 x USB 2.0 header support additional 2 USB ports (USB3)
    HDD LED, ACPIMSG LED, Reset Switch, Power Switch headers
    CPU / Power / Chassis FAN connectors
    Front Panel MIC/Line-in out header
    BIOS
    Award 2Mb Flash EEPROM
    Supports Plug and Play 1.0A, APM 1.2, Muli Boot, DMI
    Full Support for ACPI revision 1.0 specification
    ____________________________
    Ou seja, ela tem pci lock ? dual ddr ? Por 250 reais acho que a eh a melhor opçao , ajudem agm tem ?
    tem pci lock, dual ddr
    Sim, tem PCI Lock e Dual DDR mas tem q levar algumas coisas em conta:
    PCI Lock vc usa geralmente quando tah fazendo overclock, mas em termos de overclock essa eh a unica vantagem q essa mobo apresenta pq naum tem nem ajuste multiplicador, nem vcore e nem vdiim...
    E Dual DDR em Athlon XP naum tah apresentando nenhum acréssimo consideravel na performance...
    Se for fazer overclock e naum quer gastar mto eh melhor pega uma K7S8XE 3.0 ou uma A7N8X-X ou A7V600-X q tbm taum nessa faixa de preço...mas se naum for pega essa ECS msm...
    Eh pra faze overclock sim..
    ixi.. eu tava pensando nessa k7s8x r3..
    + o chip7 nforce2 .... eh bem melhor, nao tem nenhuma bios modificada ?
    o Sis746fx (k7s8x r3) tem pci lock tbm ?
    valewwwwwwwww
    Originalmente enviada por vitor2k4
    valewwwwwwwww
    K7S8X 3.0 eh SiS746Fx mas a q to falando eh a K7S8XE 3.0 q eh SiS748 com FSB 400
    Nforce 2 ganha por pouquissima coisa em performance em relação ao SiS746FX E SiS748 e nos testes de leitura de HDs os SiS saum superiores aos Nforce 2
    Nem sei se tem PCI Lock mas tem um treco q chamaram de HybridBoost no site da AsRock, falando q proporcionava um "overclock seguro"
    HASUHuhauHAUhauAHU...embora eu nunca tenha ouvido nenhuma reclamação dela
    Tenho uma K7S8X-E..
    e um Barton 2600, fiz um overclock nela, consegui 2265MHz estáveis (11.5x197).
    Ela tem apenas um enable/disable para aumentar voltagem..
    não tem nada de pci/lock no bios, alias com o bios que ela veio nem tinha como "mexer" no vcore, tive que atualizar.
    Ah..
    to vendendo ela eheh quem quiser ICQ
    Ueh...a sua eh K7S8XE 3.0 ou mais antiga? No site da AsRock tah falando q a K7S8XE 3.0 jah tem ajuste de Vcore, multiplicador e FSB de 1 em 1Mhz com a BIOS default...
    E tipo vc naum conseguiu chega em 200 de FSB com teu Barton 2600+?
    Na placa esta escrito 3.01
    Sobre vcore, no manual em pdf que vem no cd também fala..
    só que no bios não tinha como mecher. Multiplicador da para alterar (via jumper). Porém meu proc é travado.
    Não consigui chegar 200FSB, estava com memória DDR 400 (chips samsung), ligar ela ligava, porém não carregava windows..
    Poh, + conseguir isso com uma placa desse valor ta bom né?
    Tah otimo cara, mas tipo se vc aumentar Vcore vc naum consegue botar em FSB 200? Isso com certeza eh falta do processador pq o chipset SiS748 em si jah suporta FSB 200
    Provável..
    na minha nf7-s 2.0 tb não vai 200FSB
    vou trocar ele amanhã.
    Originalmente enviada por Noopy
    Provável..
    SE EH LOKO?
    Naum eh possível cara...aumenta Vdiim, vcore sei lah cara, vai troca uma NF7-S 2.0 pra fazer overclock mais alto?
    Se uma NF7-S 2.0 naum tah chegando em 200 de FSB eh pq com certeza tem alguma coisa errada, mas dificilmente vai ser a placa
    Tipo..
    qual asrock boa..
    sis748, ou 746fx ?
    ouvi fala q a 3.0 (SEM O E NA FRENTE) com o 746fx eh melhor..
    e soh foi dela q eu achei
    http://www.asrock.com/product/product_k7s8x_r3.htm
    o sis746fx ja tem ddr400 pelo menos..
    ASRock U-COP
    FSB 333MHz
    DDR 400/333/266/200
    1 x AGP 8X/4X 1.5Volt
    Hybrid Booster - a safe overclocking feature
    fsb da pra por.. :/
    __________________
    DDR 400 Max. 1GB
    isso quer dizer que eu soh posso por 1 pente de ddr400 ? ou posso por 2 de 256 ?
    SE EH LOKO?
    o cara vai trocar ELE. ELE = processador. não elA
    GSJ
    GSJ está offline
    Jan 2001
    bah, se essa placa tivesse RAID seria a placa perfeita...
    SE EH LOKO?
    não sou louco não..
    disse q iria trocar o processador pra testar..
    entendeu a complexibilidade do meu post agora?
    Tipo..
    qual asrock boa..
    sis748, ou 746fx ?
    ASRock U-COP
    FSB 333MHz
    DDR 400/333/266/200
    fsb da pra por.. :/
    __________________
    DDR 400 Max. 1GB
    A K7S8X-E é melhor, apenas ela que utiliza o chipset SiS 748 suporta FSB de 400MHz, o 746FX é apenas 333MHz.
    fiz um over em uma K7S8X-E com um Barton 2600 (1916MHz), de 11.5x197=2265.
    Sim pode por 2 módulos de 256MB
    195 com a E, pq nao 200 ?? ? memoria limito ?
    A mas soh achei a r3, nao a E
    nem a e, nem a E+r3
    mas .... se vc aumentar os FBS e a placa nao tiver PCI Clock vc não pode ferrar a HD ?
    - vale a pena arriscar ?
    eu fiquei usando uma mobo sem pci clock e dei uma aumentada nos FBS, o micro fico rox um tempão (2 / 3 meses) depois apareceram os problemas ....
    - o micro não ligava mais se o HMA da hd tivesse ligado (painel de controle do windows)
    .. formatei o micro resetei a bios mas ... o micro só funcionava quando desligava o HMA ou os FBS da bios no normal do processador.
    resumindo to com o mesmo micro e HD até hoje em stock xp1700+ fbs 133 antes o fbs tava 147.
    Originalmente enviada por registered
    HD ACHO Q NAO tem anda a ve
    nem a e, nem a E+r3
    tipow...
    deve ter algo errado com o meu sistema, em uma nf7-s 2.0, tb nao vai legal 200fsb (vai só q tem q aumentar bastante vcore).
    a asrock suporta sim 200fsb. porém repito tem algo errado.
    a memo é DDR400 (chips samsung).
    fonte genérica.
    Barton 2600+ (AQYHA) 0409.
