    Redação
    Avatar de Cadu®
    Brotherhood
    2 fontes, uma vantec e outra powmax, parece q a powmax é melhor, vejam...
    POWMAX
    PowMax 500W Black Power supply Model LP6100EA5
    SPECIFICATIONS:
    Dimension 6"Wx3.6H"x6.6"D
    Material All aluminum construction
    AC Input 115/230, 10A/6A, 60Hz/50Hz
    Max Load [email protected]/30A(DA/EA),[email protected]/50A(DA/EA), [email protected], [email protected], [email protected], [email protected]
    MTBF 100K hrs at 25°C ambient conditions
    Efficiency 70% Min. at full load
    Overvoltage Protection On all outputs
    Shortage Protection On all outputs
    Cooling Temperature sensor for auto adjusting fan speed
    Noise Level Maximum of 37db at 100% system loading
    Safety UL, CB, CE, TUV, and FCC
    Vantec
    VANTEC VAN-520A (520W) Black Aluminum Power Supply
    Maximum Power: 520W
    PFC: No
    Power Good Signal: 100-500ms
    Hold-up Time: 16.6ms min
    Efficiency: 68% min.
    Over Voltage Protection: +5V 5.8-6.3V;+3.3V 3.6-4.2V;+12V 14-17V
    Overload Protection: Not specified
    Input Voltage: 95VAC ~ 132VAC or 190VAC ~ 264VAC
    Input Frequency Range: 47Hz-63Hz
    Input Current: 12A/6A
    Output: [email protected],[email protected],[email protected],[email protected],[email protected],[email protected]
    MTBF: 140K hours at 25ºC
    Approvals: UL, CSA, ICE, TUV, CE, FCC
    Q q vcs acham?
    a POWMAX custa $50 e a vantec $100
    A vantec eh melhor pq tem 20Watts a mais
    Membro Avatar de SparkS
    Os reviews sobre a Vantec não são muito bons mas a powmax não conheço.
    As amperagens da Vantec são melhores...
    Redação
    Avatar de Cadu®
    Brotherhood
    e ai gente.. qual vcs acham q vale + a pena?
    Redação
    Avatar de Cadu®
    Brotherhood
    up
