    Mental Ray 3.3 shaders agora tem aceleração por Hardware Nvidia
    NAB 2004, Las Vegas, NV (April 19, 2004) mental images®, a global leader in the fast-growing market for high-end 3D visualization software, today announced the release of version 3.3 of mental ray®, its rendering software. mental ray is used both for cutting-edge visual effects in major motion pictures and for the computer-based design of industrial products. This software further blurs the line between reality and computer generated images, even when rendering the most difficult real-world features, including hair, fur and human skin.
    mental images developed mental ray 3.3 in close cooperation with NVIDIA Corporation (Nasdaq: NVDA), to utilize the new line of NVIDIA QuadroFX 4000 boards and its Cg programming language. The resulting software takes full advantage of the unprecedented processing power and programmability of NVIDIA's hardware technology. For the first time, extremely complex visual effects can be fully executed on this graphics hardware, reducing rendering times from hours to minutes.
    ``NVIDIA is committed to working closely with mental images to ensure that the most cutting-edge software technology, like mental ray 3.3, works seamlessly with our hardware, and fully leverages the speed, precision and power of NVIDIA's new GPU architecture,'' said Jen-Hsun Huang, President and CEO of NVIDIA. ``We value our strategic partnership with mental images and look forward to continuing our successful working relationship as our two companies continue to push the boundaries between reality and what is possible to replicate on a computer.''
    The mental ray technology is an integral part of the world's leading 3D content creation tools, such as Maya® from Alias Systems, 3ds max® from Discreet, a division of Autodesk, and SOFTIMAGE®|XSI® from Softimage Co., a subsidiary of Avid Technology, Inc. (Nasdaq: AVID). mental ray 3.3 is already included in SOFTIMAGE|XSI 4.0 and Maya 6.0, both released at NAB. These products take full advantage of the new feature set of mental ray 3.3 and leverage the performance enhancements, allowing for faster rendering both interactive and off-line.
    ``The deep integration of mental ray within SOFTIMAGE|XSI gives us a huge competitive advantage in the 3-D industry,'' said Marc Stevens, Director of R&D for Softimage. ``We have worked with mental images for over a decade to build 3-D animation tools that meet the needs of our customers, and the latest versions of XSI and mental ray significantly increase our customers' productivity and their ability to rapidly create the most realistic computer generated images.''
    A number of key direct customers of mental images, including Buf Compagnie, DreamWorks, ESC Entertainment, and Industrial Light & Magic have also contributed substantially to the specification of the extended feature set of mental ray 3.3.
    ``The power of the human mind is largely a reflection of the three dimensionality of the world that we live in. At mental images we create 3D technology that makes it easy for people to fully explore their creative potential,'' said Rolf Herken, CEO and CTO of mental images. ``We are extremely excited to be working closely with established leaders in the 3D field like Alias, Discreet, NVIDIA and Softimage and will continue, as partners, to drive the transition to 3D computing.''
    About mental ray 3.3
    In addition to significant performance improvements, especially when rendering scenes that contain hair or fur geometry, additional features include the following:
    * Accelerated graphics hardware rendering: Exploitation of available graphics hardware for high quality rendering, including support for OpenGL, NVIDIA's Cg 1.2 higher level language, phenomena and shade trees where hardware shaders are available. Automatic combination of hardware and software generated elements. Support for displacement mapping, order independent transparency, hair geometry, volumes, and high quality anti-aliasing
    * Detail shadowmaps: Combination of shadowmap and ray traced shadow algorithms for more realistic shadows
    * Subsurface scattering: Powerful, physically correct simulation of subsurface scattering effects, according to actual local geometric and optic properties
    * State shaders: Tighter integration with animation packages and a more powerful interface between mental ray and front ends, resulting in better control of application-specific rendering effects and phenomena
    * Conditional rendering of scene files: For improved selection and control of processing scene contents
    * OpenEXR image file format: Support of the OpenEXR high dynamic range image file format developed at Industrial Light & Magic, for texture and image output
    Explicando em termos leigos é mais ou menos assim vc vai poder ter no viewport uma renderização quase que em tempo real dos shaders do MR isso para o animador e modelador vai ser muito bom pois ele pode visualizar diversos efeitos antes do render final, sem contar que no render final a placa de video vai ajudar no processamento tb.
    Vale lembrar que o Mental Ray é utilizado nos principais pacotes de modelagem e animação do mercado, pacotes como Maya, Sotimage XSI, 3D Studio Max, Houdini, Catia etc etc.
    Bem para quem não sabe o que é Mental Ray veja onde ele foi usado.
    Asy
    Asy está offline
    Membro Avatar de Asy
    NinaAgdal>All
    rodando a 2 fps ?
    BOMsoMITO 2018!
    Quer dizer q se eu comprar uma nvidia vou poder fazer o meu Yoda Azul e ficar milionario ??
    Isso quer dizer que para o Modelador/Animador, isso facilita muito pois ele vai poder ver e analizar muito melhor seu modelo/animação no viewport, em vez de renderizar pequenos trecho para ver o aspecto final.
    E Doug esquece vc é do time vermelho, lembre-se pessoal do sabre vermelho = lado negro da força.
    BOMsoMITO 2018!
    Originalmente enviada por Cat-Ham
    Vou ter q fazer o Conde Dokou ou o Sith entao !
    Poxa , queria fazer o Yoda Azul !
    Membro Avatar de TM99
    rodando a 2 fps ?
    Melhor do que 50 spf
    (segundos por frame ¬¬)
