Página 2 de 2 Primeira 1 2
    Jun 2001
    Pessoal, postei na HardBR uma lista de Reviews e Previews!!
    http://www.hardbr.org/modules.php?na...rder=0&thold=0
    NoOne
    Vlw ai NoOne
    Só tinha lido da anand e da toms, as 2 são completamente diferentes, tem que ler mais pra ver qual que é mesmo da placa
    Mas não dá pra negar que a diferença de performace da antiga geração de vgas ATI e Nvidia pra esta nova é absurda, eu não lembro de ter visto algo assim antes.
    Originalmente enviada por DekerBSB
    eahieauhiueahieauheaiuheaiuheaiueahiueahiaeuheaiuh
    sabia que vc iria aparecer hauah demorow huauaau
    Diesel ta quieto aqui mas la ta soltando o verbo huauhau
    Originalmente enviada por Pacote-san
    So paar complementar o HOLT
    Extreme Tech
    If made to choose between the two, we give a slight nod to ATI. At the $500 price-point, the Radeon X800 XT does hold a slight overall performance advantage, particularly at very high resolutions. The lower power-draw requirement appeals to us, though most hardcore gamers, often already have an adequate power supply. NVidia does have Shader Model 3.0 support, although we're taking a wait-and-see attitude about how prevalent games that use it become over the next 12 months. Shader Model 3 support is an interesting feature, and it's clear that the 6800 lays the groundwork for future generations. Truth is, either of these GPUs is going to haul ass, and neither will leave you wanting for performance.
    yeah
    That said, ATI still holds a small advantage at the1600x1200 race between the 6800 Ultra and the Radeon X800 XT. NVidia does gain a small performance lead with the "Ultra Extreme", though the price of shipping cards at this point is anyone's guess.
    NVidia's 6800 GT is the winner when stacked against the X800 Pro, but again, it's a close race.
    source: extremetech again
    Jan 2001
    o q me da raiva eh a performance da ati em opengl, akilo sim foi surra : /
    se o pixelshader3 eh bem implementado ou nao na nv40 ( se vai rodar satisfatoriamente que eu kero dizer ) far cry vai nos dizer...
    eu vou enrolar e mto ate comprar 1 dessas ae, pra ter mta certeza. Pra mim eh empate tecnico sei la...
    Soh achei mto estranho os testes sinteticos, Nvidia na frente em Pixelshader 2.0 : o na frente no aquamark etc... em jogos umas nvidia leva outras ati...
    BOMsoMITO 2018!
    Originalmente enviada por insect-by
    Lembrando q a nvidia ta em PS 1.1
    Membro Avatar de Arraso
    Apr 1999
    nVidia usa PS2.0 no FarCry 1.1... Mas com FP16.
    DIZENDO PELA 666ª VEZ: O JOGO AINDA DETECTA NV40 COMO SE FOSSE NV3x, então roda com FP16 ao invés do FP32.
    A CryTek diz que o patch adiciona suporte a NV40 e PS3.0... mentira!
    Aliás, sabiam que a polícia alemã foi 3x nos escritórios da CryTek pra apreender PC's? Hee empresa pilantra que usa softwares piratas.
    Membro Avatar de WolfwooD
    ahn, ninguem reparou q a ATi conseguiu esses resultados com drive BETA?
    Membro Avatar de NoOne
    Originalmente enviada por WolfwooD
    Having installed the driver supplied together with the graphics cards, we saw at once that it is not marked as the final driver: the Options page indicated that it was CTALYST BETA DRIVER, and the Version field stated “6.14.10.6444”. Besides that there were no other differenced from the Catalyst 4.4 driver: all the pages and control panels of the new driver were absolutely the same as those of the catalyst 4.4.
    Fonte:
    http://www.xbitlabs.com/articles/vid...y/r420_25.html
    Originalmente enviada por RetardadoMental
    haeuhaueh daki a pouco ele vem
    to postando no topico onde tem os benchs da 6800 @ 450 mhz.
    Nao vou perder meu tempo escrevendo sobre platinum 520mhz contra 6800 de 400mhz .. dexa os caras comemorarem q a Ati conseguiu chegar perto da pior NvUltra com 2 "samples" da platinum
    BOMsoMITO 2018!
    A nvidia ja lancou a 6850ultra mega Gold platinum Atomic edition ????? Vai precisar de q ?? 3 molex ?? Poxa q pena hein !
    definitivamente não entendo...
    Quando alguém argumentava que o processador AMD ganhava do Intel com clock menor diziam que não interessava... que o que interessa é o resultado e ponto final.
    e agora usam o mesmo argumento ( que diziam ser inválido ) para justificar uma possível derrota da nVidia...
    A pergunta é: será que a nVidia vai conseguir aumentar o clock da sua GPU consideravelmente ? será que assim como a AMD a arquitetura utilizada pela nVidia não limita o clock mais do que a arquitetura da ATI ?
    Eu prefiro não trabalhar com suposições, vou esperar lançarem os próximos modelos pra ver...
  13. #37
    Membro Avatar de Rubra
    Originalmente enviada por SocioColorado
    Como que será os resultados de uma 6800ultra com 525mhz de clock brigando com a platinum que tem o mesmo clock?
    Pra mim a nvidia tá fazendo muito com pouco....
    mesma coisa quando a ati lançou a 9700pro e a nvidia com suas placas... a ati fazia muito mais com menos....
    esqueceram?
  14. #38
    Originalmente enviada por Rubra
    esqueceram?
    Só um detalhe..
    Pra ela alcançar 525Mhz ela precisaria iria consumir mais energia.. mais iria esquentar e menor seriam as chances de overclock.
    É mais ou menos como o Socio falou.. se tu pensar assim.. imagina um Athlon64FX a 4.4GHz como os P4.. entendeu !? Imaginar é uma coisa.. o problema que fisicamente a tecnologia não é capaz de chegar a tal frequencia.. pois sao arquiteturas diferentes..
  15. #39
    Asy
    Asy está offline
    Membro Avatar de Asy
    NinaAgdal>All
    nussa, nem eu esperava por essa :|
  16. #40
    Feb 1999
    "(...)With ATI's performance on par in older games and slightly ahead in newer games, the beefy power supply requirement, two slot solution, and sheer heat generated by NV40 may be too much for most people to take the NVIDIA plunge. The bottom line is the consumer here, and its good news all around. "
    http://www.anandtech.com/video/showdoc.html?i=2044&p=22
  17. #41
    Membro Avatar de andrepmrj
    o legal de quando e drive beta da nvidia..... e tudo cheat....roubo e kct.......
    mas com a ati ninguem fala ne........
    porem a gerra da foda mesmo...... vamo ver que mente mais..ops digo mostra mais.....
  18. #42
    Só um detalhe..
    Falou tudo NoOne.
    E vamos combinar que se a nVidia ja tivesse em mãos tecnologia suficiente pra largar uma placa totalmente estável rodando a 525Mhz já teria feito isso... ela pode até chegar lá, mas até lá a ATI tb pode melhorar a sua placa, e aí já estamos fazendo mais outra suposição, enfim... a discussão não acabaria nunca, prefiro comentar sobre o que já foi lançado, testado, etc...
  19. #43
    3 molex + Volcano 11 na gpu
