    Membro Avatar de POLAR
    Saiu Nforce Forceware Driver ver.4.24
    http://www.nvidia.com/object/nforce_udp_winxp_4.24
    Audio driver 4.31 (WHQL)
    Audio utilities 4.31
    Ethernet driver 4.16 (WHQL)
    GART driver 3.77 (WHQL)
    Memory controller driver 3.38 (WHQL)
    SMBus driver 4.04 (WHQL)
    Installer 4.38
    IDE NVIDIA driver 4.12
    Installation Notes
    Windows XP users must install Service Pack 1 prior to attempting to install this package. Failure to do so will result in the inability to support USB 2.0.
    Audio drivers will not install on the following nForce2 products: Chaintech 7NJS. Please use the drivers that come with these products to enable audio functionality.
    Installation of DirectX 9.0 or higher is required in order to use NVMixer.
    Release Notes
    WHQL certified kit
    Unified drivers with support for nForce, nForce2, and nForce3 products. This package does not include support for dual-processor systems.
    General compatibility fixes
    Audio Driver Improvements
    Introduced NVMixer – replaces SoundStorm Control Panel for all audio configuration tasks. Note that NVMixer operates best when run at 1024x768 16-bit color
    Introduced improved AC ’97 / Soft Audio driver – adds EQ, speaker cloning, and speaker wizard support
    Introduced Speaker Wizard – incorporates all NVSwap features, ensures correct speaker setup on analog or digital speaker systems
    Introduced Cinesurround – virtual 5.1 mixdown to headphones or 2 speakers
    Introduced new Environments – simple, preset driven sound environments
    Enhanced ASIO support and added support for AC ’97 / Soft Audio systems
    Added user adjustable “rear channel creation” support – adds off, clone, reverb and delay
    Added support for Realtek ALC655 codecs, Realtek ALC658 codecs, and 7.1 support for Realtek ALC850 codecs
    Added support for WMV-HD audio streams and WaveFormatExtensible calls
    Improved playback of mono content
    Addressed audio issues in numerous games and applications
    Storage Driver Improvements:
    Support for Serial ATA controllers
    Full NVIDIA RAID functionality on supported platforms
    Improved compatibility with 3rd-party drive management, CD ripping and recording software.
    Automatic DMA-mode fall-back when data errors are present due to poor cabling
    Improved handling of various storage devices
    Windows XP Driver Versions
    Alguem ja testou?
    dcli 101
    To baixando agora
    Jájá posto as impressões
    Membro Avatar de Peleyer
    Gostei, jah vem com nvmixer, e aparentemente nao deu problema nenhum aqui...
    Yen
    Yen está offline
    Originalmente enviada por peleyer
    aki tb
    dcli 101
    Já instalei
    Tudo funcionando bem
    Notei que o FarCry levou menos tempo pra carregar, será que deram uma boa melhorada no driver IDE ou é só impressão minha?
    Membro Avatar de Skitter
    ae galera como q eu vejo a versão q eu to usando? me digam aonde ir certinho, onde clicar e talz, pq só indo no "aida 32" ñ to achando...
    Originalmente enviada por WarLocK
    Já instalei
    Ficou MUITO mais rapido abrir o aplicativo do XP de instalação/desinstalação de softwares....
    Parece q o IDE ta bem melhor mesmo!!!
    DT
    Feb 1999
    Como vocês fizeram a instalação desse aí? Só desinstalarm o antigo ou passaram o DriverCleaner (sempre faço aqui, pelo menos)?
    Pra instalar esse eh soh desinstalar o Nvidia System Utility e instalar esse arquivo de 20Mb? Isso serve pra qualquer mobo com nforce2? (no meu caso nforce2 400)
    Feb 1999
    Tu estás perguntando ou afirmando? Hehe. Eu usei sempre o DriverCleaner aqui, mas tou querendo saber se dó dando Uninstall já resolve, pois não tou com saco de fazer todo o procedimento do DC.
    To perguntando, viu a interrogação ñ?
    Mas me responde, q q eu tenho q desinstalar? Ou eu posso instalar por cima de uma vez? Se for pra desinstalar é aquilo q eu falei q ta na lista dos adicionar/remover programas? (nvidia system utility?)
    up to afim disso eheh
    ae instalei de boa por cima do q tava... parece q fico mais rapido ou eh impressão minha?
    Feb 1999
    Vi a interrogação sim.
    Membro Avatar de NoOne
    to rodando..
    ta melhor do que aquele remix rebirth?
    Membro Avatar de Arraso
    Apr 1999
    Estes drivers nem são novos
    Os drivers IDE e de som já tinham sido "lançados" há quase 2 meses.
    Os drivers Ethernet, SMBus e GART foram liberados para as fabricantes do nForce3 250 - sendo que tudo foi "posto" na Internet pela MSI há 20 dias. Já o Memory Controller é do ano passado.
    Ou seja, é novo só pelo fato de estarem reunidos num único pacote. Pra quem já mantinha tudo atualizado (e atualizando manualmente driver por driver), não há nada de novidade.
    Engraçado que notei perda de performance no IDE, de acordo com os testes...
    Feb 1999
    Aqui a Ethernet não funcionava com esse pacote da MSI. Agora funcionou.
    O que vocês estão falando é do Windows XP - Unified Driver mas lá no site da nvidia.com tem outra opção na parte de nForce Drivers chamado NVIDIA System Utility, isso não é importante também?
    Originalmente enviada por Fenomeno
    Esse utilitário é para overclock no Windows, mas são poucas as placas 100% compatíveis com ele.
    Isso é só para OverClock? Nada mais?
    Então nem vou pegar.
    Membro Avatar de Quetzacoalt
    entao é so tacar por cima do antigo?
    ninguem respondeu....
    Esse nforce começou a dar uma travada muito estranha em jogos aqui, voltei pro bom e velho 2.45 e parou de travar... =o
