    Membro Avatar de Morppheu
    Dec 2000
    Ajuda pra fazer VDD mod na minha 8RDA+..
    Essa semana vou fazer VDD mod na minha 8RDA+... tenho aqui um ferro de solda comum, sem ser com ponta de cerâmica, já serve?
    Eu queria algumas dicas de quem já fez... achei na net alguns guias de como fazer, mas quero saber como foi a experiência do pessoal...
    Valeu!
    eu nao faria..
    mandava pro copyman
    Originalmente enviada por Cracker Jack
    eu nao faria..
    mandava pro copyman
    ta loco. 30 pila o servico. 40 o frete de ida e volta. demora de 20 dias. eu nao. uhauh
    melhor pegar os esquema da net e levar em uma loja de eletronica.
    Nov 1999
    Oq eh esse vdd mod? =[
    modificao pra alterar a voltagem do chipset e consequentemente atingir FSB maior.
    Nov 1999
    Eita porra nunca tinha visto isso HASOIEhas
    Desinformado rlz =-o
    Só conhecia pin mod
    Membro Avatar de NIex
    apl525 here
    http://www.motherboardfaqs.com/article.php?32.255
    What you will need
    1. You will need to know how to solder. You might have heard about "grabbers", but these are a poor solution.
    2. Either a fixed or variable resistor. If you want a fixed resistor, find your resistance using the formula above and find a resistor with that value. Radio Shack sells 680 and 1000 ohm resistors on the shelf, so these are the most popular ones for this mod due to the convenience of not having to order them online.
    If you want a variable resistor, I recommend getting a 1000 ohm 15 turn trimmer, which is also available from Radio Shack. If you use a variable resistor, you will need a multi meter to check that the resistance is set to the proper value after installing it.You will also need something to mount the resistor with such as super glue or strong double sided tape, and some wire to connect the resistor to the soldering points.
    3. You'll need any other basic tools that might be useful. Wire cutters, a screwdriver, electrical tape, etc. Read through this entire guide first, and make sure you have all of the required items before attempting this.
    Membro Avatar de Skitter
    a 8rda ñ tem controle de voltagem do chipset pela bios ñ?
    Dec 2000
    Não...
    Tou com uma A7N8X-E Deluxe aqui tb... eu tive vendo na net que se colocar essa placa com FSB muito alto a BIOS corrompe, é verdade?
    se eu botar um resistor de 650 ohms da 1,8v? é isso?
    pelo calculo que tem la acho que é né?
    (176 / ohms resistance) + current vdd voltage = resulting vdd voltage
