    Qual serie do mobile voce pegaria ?
    Pessoal eu acho que essa semana deve chegar o mobile ( uffa ) so que tem um problema , eu nao to lembrando a serie que eu peguei ..
    É alguma das duas abaixo , isso eu sei
    Qual dos 2 , é o melhor ?
    *http://www.excaliberpc.com/product_i...oducts_id=3552
    *http://www.excaliberpc.com/product_i...oducts_id=3637
    Ps: Eu to achando que peguei o 0348
    Valeus
    Membro Avatar de NIex
    apl525 here
    Dá um look aqui depois.
    http://www.ocforums.com/forumdisplay.php?forumid=3
    LIST OF REPORTED MOBILE BARTON 2600+ STEPPINGS
    IQYHA 0401 UMPW (1)
    IQYHA 0401 UPMW (5)
    IQYHA 0348 SPMW (2)
    IQYHA 0346 TPMW (3)
    IQYHA 0346 MPMW (1)
    AQYHA 0346 XPMW (2)
    AQYHA 0346 XPW (1)
    MOBILE BARTON 2600+ REPORTED RESULTS LIST
    (A * marking means Prime95 stability has been reported)
    IQYHA 0401 UMPW
    (Air, Wildcard_QS) (SLK 947U, Tt SFII)
    2400 Mhz at 1.625 volts
    2605 MHz at 1.8 volts
    IQYHA 0401 UPMW
    (Water, badge51) (Corsair Hydrocool) (2 chips)
    Chip # 1
    * 2670 MHz at 2.0 volts, 41C load
    Posts 2800 Mhz
    Chip # 2
    * 2600 MHz at 2.0 volts
    Posts 2800 Mhz
    IQYHA 0401 UPMW
    (gplracer)
    * 2508 MHz at 1.7 volts
    IQYHA 0401 UPMW
    (Air, TheFlons) (AX7, 80mm Tornado)
    2616 MHz
    IQYHA 0401 UPMW
    (Water, crimedog) (RBX, Mag 3)
    2683 MHz at 1.85 volts
    IQYHA 0401 UPMW
    (Air, frodoski) (SLK 900, 92mm fan)
    * 2553 MHz at 1.7 volts, 38C load
    IQYHA 0348 SPMW
    (Larethus)
    2700 MHz at 1.95 volts
    2640 MHz at 1.88 volts
    2500 MHz at 1.75 volts
    2400 MHz at 1.65 volts
    IQYHA 0348 SPMW
    (Air, Timzak) (SLK 900A, Tornado)
    * 2410 Mhz at 1.675 volts, 46C load
    * 2510 Mhz at 1.775 volts, 52C load
    2600 MHz at 1.9 volts
    IQYHA 0346 TPMW
    (Rabbi)
    * 2200 MHz at 1.5 volts
    * 2300 MHz at 1.55 volts
    * 2400 MHz at 1.675 volts
    IQYHA 0346 TPMW
    (Water, d4mon) (Koolance EXOS-AL)
    2500 MHz at 1.76 volts, 44C load
    2615 MHz at 1.9 volts, 52C load
    IQYHA 0346 TPMW
    (Air, blkgti) (Thermalright SP-97, 92mm Panaflo U1A)
    * 2600 MHz at 1.79 volts (board undervolts Vcore), 45C load
    IQYHA 0346 TPMW
    (Air, marc999) (Thermalright SP-97, 80mm PAnaflo L1A)
    * 2400 MHz at 1.625 volts
    2500 MHz at 1.7 volts
    IQYHA 0346 MPMW
    (Water, goldie) (Polarflo Water Block, Eheim 1250)
    * 2674 MHz at 1.86 volts
    AQYHA 0346 XPMW
    (jpm804)
    2631 MHz at 1.725 volts
    AQYHA 0346 XPMW
    (Air, medar) (Thermalright SP-97, Tt SF II)
    No detailed results yet
    AQYHA 0346 XPW
    (Air, axhed) (SLK-800A, 32cfm fan)
    2500 MHz at 1.725 volts
    O bicho deve ser o novo 2400+ de 1.35v.
    Eu pretendo comprar um mais se for garantido 2600mhz com ~ 1.8v.
    Eu acho fake mais.
    2724mhz com 1.63 volts, aff esse passar dos 3400mhz com water, se for verade
    IQYHA r0x...
    IAQXA 28392893 IAQIXIAIEOQEIS 1930347588AUQIEIA
    bah, tnc, monte de série complicada esses XP.
    sou mais os P4 de 5 caracteres so: SL6WF, SL6Z3, SL6Z5, Sl6WJ
    Niex ,
    "O bicho deve ser o novo 2400+ de 1.35v."
    isso e errado , pois os "novos" nao sao novos hee .. os 2400+ de 1.35v foram os primeiros mobiles a sairem , e na sua grande maioria na europa , nada de newegg hehe
    portanto acho mto dificil voce comprar os "novos" ehhe ...
    t+
    Ps: eu ja inha olhado essa lista, mais nao achei o 0348 TPMW ..
    AHsuAHsuAHsuHASuAHsu esse higherox... PQP HuahuHsuAshuashaush
    aheuaheua pow.. falo mermo! to mentindo?
    HhuHAEUhAEU .. vai vira floodagem
    Originalmente enviada por ra faeL | rLz
    =[ achei q vc nao brigasse mais blz..
    ja postei minha opniao AeAHUEUHAEUaUHe
    pegaria o AIQXA @#$*@()$&*@&$*)#)XCJAIJDOAUE#()*(
    to bringando nao
    e so pra no fica mto xeio ehuAEH ...
    to bringando nao
    ok :P
    nossa rafa, q incrivel, vc organizo sua assinatura pqp eaehAHUEAHUE
    ok
    Pra voce ver.. antes tava meio estranho . fico bunitim agora ?
    ps: ninguem mais sabe sobre as series
    segundo meus calculos profeticos
    vc pego o IQYHA
    uiaehuieah
    Originalmente enviada por [ e1.tr ]
    vc pego o IQYHA
    uiaehuieah
    tb to achando que foi ele eehuihiaeiuhauei .. ele e dos bons .. eu sei que so testando mais..
    Jul 2000
    o meu é um IQYHA q comprei do Hempp, tá aqui a 2685Mhz com 1.88V e com um slk900U, ele roda legal tb a 2695, e o máximo que eu coloquei foi a 2707 mas fica bem instável.
    Infelizmente minha placa mãe só vai até esta voltagem... se eu conseguisse 2V ia a 2750-2800 tranquilo...
    Membro Avatar de Sapporo
    porra meu, tu tem um sistema topzao.... vai troca de mobo
    Jul 2000
    No momento prefiro trocar de memória, pois com memória que me permita uma latência baixa e/ou um fsb maior já terei um ótima performance... futuramente trocarei de mobo, mas prometi pra mim mesmo dar um tempo na gastança que fiz nos últimos meses eheheheh
    Mas qdo chegar a memória me avisa!!!
    qual a serie toda do seu mobile
    Jul 2000
    do meu?
    já me perguntaram isso e respondi a mesma coisa....
    preguiça de tirar o cooler (slk900U aparafusado na mobo) pra ver...
    tem algum programa q mostre a série toda dele com precisão? acho q não né?
    Bom to pensando em hoje a noite colocar pasta térmica nova no processador, se eu fizer isso daí eu vejo a série dele...
    fico lindo :P :E
    do meu?
    demorow.. eheh postaia pramatar a curiosidade
    higherøx
    iqzfa eh melhor acho.
    Jul 2000
    tá aí a série completa do meu:
    IQYHA0408RPMW
