    Cooler da X800 da safire "toxic" :
    Vou comecar dizendo uma coisa:
    Eu NUNCA, JAMAIS tive nada contra coolers grandes, to poco me fudendo pra tamanho de cooler.
    Mas pra cambada de fanboy q sempre zuou os coolers da Nv:
    ENGULAM
    Pra mim, ou pra qqr pessoa q gosta de Oc, isso eh uma otima noticia, ver coolers melhores na Ati, vide q o sonho de consumo de qqr dono de 9800 eh um cooler bom. Agora parece q a Ati tera coolers diferentes dos "reference".
    Ja pros idiotas q adoravam zuar os cooler da Nv/2 Slots isso seria um topic "flamer" mass..vai ae um conselho:
    Vc so nao vao kebrar a fussa com os 2 molex por causa do Pci-Express, senao na proxima geracao da Ati vcs iam ter q engolir mais essa tbm.
    Moral da historia?
    So fale mal do q realmente eh ruim.
    Quando vc zoa so por zoar, sem base, volta tudo na sua cara.
    " The (safire) Toxic line pushes technology forward in two major ways, cooling and overclocking. The cooling is the neatest part, Sapphire worked with a major name in cooling to come out with a large diameter, low RPM cooling solution. Take a look at the heatsink and fan setup and you will see what I mean.
    Because it is fairly large, it should not spin very fast to provide more than adequate cooling. The fan casing will also be redone to be UV sensitive so it should fit in well with cases that put a priority on looks. The only down side is that a large, low RPM fan takes up two slots, but that is quite livable in most modern systems.
    The other important thing that Sapphire did with the Toxic is overclocking. ATI has rules about how fast vendors can ship their chips at, and what they can and can not do with the BIOS settings. Sapphire is meeting those rules while allowing the maximum overclockability using a technology called APE, or Automated Performance Enhancer."
    cooler bonito...gostei
    Esse vai se o cooler de referencia da ATi? caso negativo, o que tem a ver? Já tem faz tempo no mercado uma marca HI ou HS, n me recordo da marca.
    O cooler de referencia da nVidia é um monstro, porque precisa ser um monstro.
    Nada contra ATi ou nVidia, tanto que ñ sei qual vo pega, x800pro ou 6800gt.
    []`s
    jr
    []`s
    jr
    Eu nunca tinha visto uma Ati com cooler "parrudo", alias, me parece q a Safire trabalhou com a Oates nesse cooler ae, ele lembra muito uma versao refinada das Fx5800, o cooler da Abit/Oates eh bem parecido com esse.
    Sobre os coolers de referencia da Ati eu penso q eles sao "referencia" pro hemisferio norte, canada, Eua, europa..lugares frios, mas acho q eles tao se tocando q um cooler pekeno dakeles nao eh suficiente pro verao tipo no rio de janeiro por ex. e isso deve ser mudado.
    Me parece ainda q esse cooer eh baixa rotacao e low noise. Se vc nao eh um ogro q usa o primeiro slot Pci eh uma otima pedida.
    Ps. qunado uma marca zunida faz um cooler diferente eh uma coisa, mas uma saphire puxando a "moda" a tendencia eh outra
    bunito o cooler mas bem q podiam colokar azul e tals neh
    parece um VGA silencer.
    Membro Avatar de andrepmrj
    comparemos.......
    fx5800 ultra
    ou fx5800
    porem.... o da ati e maior hehehhehehheehe
    comparemos.......
    fx5800 ultra
    http://www.asus.com/products/vga/v9900ultra/v9900_l.jpg
    ou fx5800
    http://www.asus.com/products/vga/v9900/v9900_l.jpg
    Matou!
    Membro Avatar de NIex
    apl525 here
    A Sapphiretech apresentou recentemente uma versão especial e limitada da nova Radeon X800PRO, a novidade é o seu sistema de resfriamento de alta peformance, possibilitando um alto poder de overclock para usuários mais experientes e um sistema de monitoramento de temperatura via diodo.
    http://www.adrenaline.com.br/adrenal...o=news&id=6257
    Realmente grande, principalmente na parte do fan.
    Se botar isso aqui acho que bate no HD
    puta os cara ficam brigando por causa do tamanho do cooler.
    to cagando e andando pro cooler. o que importa e fica bonito no monitor.
    Redação
    Avatar de Cadu®
    Brotherhood
    comparemos.......
    fx5800 ultra
    ou fx5800
    e melhor...
    Para com essa mania de achar q todo mundo ta "brigando".
    Lembrando q esse cooler eh maior q o da 5800U mas eh pra ser silencioso
    rapaz...tem gente no mundo q naum se importa com o barulho do PC
    acho que vc intende o que quero dizer com "brigando".
    se esse cooler da toxic tiver for parecido com o VGA Silencer é bem silencioso mesmo. se nao me engano 2 opcoes de rotacao 1300 ou 2500 rpm.
    ja das FX o que incomoda é o ruido alto.
    Membro Avatar de CiB | Sid
    parece com o cooler da 9800pro hightech...
    soh axei essa imagem enorme dela...
    low RPM, low noise
    melhor do que o secador de cabelo da nvidia still.
    low RPM, low noise
    Com o dobro do tamanho tinha que ter alguma coisa de bom .
    E realmente tem muita gente que não se importa com barulho e compra o athlon mobile para dar overclock e compra um vulcano 9.
    Ja pedi para meu visinho tirar a porra do overclock que eu quero durmi caralho!
    Provavelmente vou gastar 400 reais a mais no proximo computador em um water cooler descente que pegue placa de video e processador.
    Redação
    Avatar de Cadu®
    Brotherhood
    Diesel na boa velho, ja ta começando encher o sako seus topicos...
    sempre entro neles pensando em ver alguma coisa interessante, novidades, informações , liga?
    mas tipo ultimamente estou fikando decepcionado com seus topicos...
    todos eles vc posta para de alguma maneira meter o pau na Ati ou vangloriar a Nvidia..
    Você deveria seguir o Skull Devill do forumpcs...
    o cara num se preucupa em meter o pau em uma fabrica ou vangloriar a outra.. ele se preucupa em informar a galera do forum, dar dicas, novidades e talz... ate fikei imprecionado q ele se preucupa em traduzir todas as news para q todos entendao.. agora ele virou newsposter de lah..
    ja pensou se vc usase todo seu conhecimento igual a ele?
    diesel, esse é o mesmo caso da TI 4200 ABIT Siluro...... nao precisa do cooler grande, mas optou por te-lo para uma melhor refrigeração...... tanto q esse coolerzão laranja é igualzinho à uma 9800 pro de uma marca q eu esqueci o nome....... IDENTICO......
    outra coisa..... a ATI esperou a OUTRA GERAÇÂO (x800/6800) para necessitar de um cooler maior..... mas AINDA ASSIM a X800pro ou XT NÃO É OBRIGADO A USAR COOLER GIGANTE, SE O USA É PARA MELHORIA NO OVERCLOCK
    ou seja...
    a ATI PODE escolher cooler de 1 slot ou 2 slots..... coisa q a nVidia NÃO PODE
    Obs: 1 Molex
    Originalmente enviada por RetardadoMental
    ou seja...
    Obs: 1 Molex
    vc faz jus ao nick
    vc faz jus ao nick
    poderia ser mais criativo?
    Vc quer mesmo ser levado a sério com esse nick e com os seus posts coerentes ao seu nick?
    Membro Avatar de caldas
    oficial
    Ainda bem que nao e oficial
    algum erro no meu post?
    resumindo atualmente o que temos:
    lol
