    Membro Avatar de NoOne
    R420 vs NV40 (450MHz) - iXBT
    Membro Avatar de TM99
    q merda eu to TOTALMENTE sem conexão com o exterior hJ
    q q ta havendo com essa bosta de Brasil telecom..
    MaxPayne2 completamente travado pelo CPU.. Scores em todas resoluções e PVs travados em 150FPS..
    Mas queria saber COMO ELES RODARAM A 1600x1200.... o Need for Speed Underground.. :/
    Até hoje nunca consegui
    Membro Avatar de Guy # spfc
    comédia a montagen
    mas o cra da ATi podia ta no chão
    Originalmente enviada por |° Guy °|
    comédia a montagen
    Tu leu a conclusão!? leu o Review ?!
    Ou apenas viu alguns gráficos ?!
    Ha ha ha,
    CONCLUSIONS
    Increased frequency makes no great difference.
    In some aspects, it enables NV40 to equalise with R420, but in general, the latter remains the champion.
    Several shortcomings evidently not related to hardware, were eliminated in the new drivers.
    In other words, even 450 MHz can't ensure NV40's victory in synthetic tests.
    Tio, por favor, o q houve agora ???
    *****edited*****
    Ainda tem mais, como bater em bebo
    Conclusions
    An up-to-450MHz core frequency increase doesn't guarantee the victory to GeForce 6800 Ultra. Many tests (especially those based on recent games) showed that RADEON X800 XT is still better than the accelerated NV40.
    Abs
    Originalmente enviada por M4luco-RJ
    Ha ha ha,
    CONCLUSIONS
    drivers?
    drivers?
    Driver NVIDIA 61.11
    It should be installed either on a CLEAR OS or after the previous version is uninstalled and the register is cleared, but not OVER older versions. If these conditions are fulfilled, 61.11 works all right.
    There are problems with the control panel. You can increase frequencies but you can't bring them back to the default level. In spite of our repeated attempts to remove overclocking, the driver sets increased frequencies all the same. You can only get back to default if you remove the driver and reinstall it.
    Our research revealed no visible cheats in 61.11, although we can't guarantee that this will be the case in all games. Thus, all performance increases were the result of real and useful optimisations. It should be repeated that when we say "harmful cheats" we mean an artificial performance growth at the expense of quality.
    As for FarCry and the quality in it, it is patch 1.1 that is to blame (we won't discuss who was behind all this as we have no evidence). The picture looks very much like a lowered shader execution precision.
    The new 61.11 version was very useful for GeForce 6800 Ultra and ensured some gains for the accelerator without using "harmful cheats". Hopefully, FarCry developers will improve the terrible NVxx quality in patch 1.2. Then the comparison will be more objective.
    Concerning work in 3DMark03, the benchmark authors themselves admitted that 60.72 is a good driver version for NV40, from their point of view, and 61.11 has little difference from it in this respect.
    Mais uma série de benchmarks, que comprovam um ligeira vantagem da ATI nos jogos de hj, se não for OpenGL!!!. Nos sintéticos, quando ligados os filtros a ATI tb ganha, só perde quando a nVidia é overclockada.
    Que dilema, qual placa pegar ?
    A nVidia por ter uma tecnologia nova, não deveria ser a vencedora ? Não, ainda não...ainda tem que se esperar os patchs nos jogos para se ver se realmente vai melhorar alguma coisa.
    E se melhorar, a ATI dançou, pq com esse R420 (R360 nos esteróides), não haverá o que fazer, a não ser aguardar nova geração com suporte ao DX9c...
    E se não melhorar pro lado da nVidia, com a implantação do PS3.0, todo esse marketing...ihhhh...fudeu!
    Ainda temos que esperar...
    PS.: Vcs viram a diferença no Painkiller com tudo no máximo em 1024x768 ??? 232.5fps da ATI contra 151,1fps da nVidia...o_0.
    Agora, fala sério...mais de 100fps com tudo no máx, já não tá baun não ?!?
    E a qualidade oh:
    Abs.
    O que ficou muito claro pra mim é a diferença de enfase dada pelas placas..
    Uma hora a ATI se sai com performance superior, depois a NVIDIA vira o jogo e se da melhor. O mais interessante é que não tem uma ganhadora absoluta.. e por tratar-se de uma fase de transição de APIs, existem muitas variáveis que afetam atualmente e podem afetar futuramente o desempenho das placas.
    Lembram das FX5200 com DX9 mas performance ridicula?! Poisé.. hoje.. com o DX9 praticamente aplicado.. ainda podemos dizer que ela é uma escolha mais certa que a sua concorrente?!
    NoOne
    E a qualidade oh:
    http://www.fastreview.kit.net/fastre...ns/imagem1.jpg
    Abs.
    nao vou nem perguntar se leu, pq ja tenho a certeza.
    entao volta lá, e dá uma olhada no que tá embaixo.
    ok ?
    o Arraso já falou milhares de vezes do pq disso.
    falar na qualidade de imagens, depois q tive uma R8500 e uma R7500 eu passei a paga pau pra imagem da ATI
    Holt, mesmo com tudo isso.. imagina agora rodando em 24/32bits de precisao.. pra quanto vai cair a performance!? Isso que ja foi pior que a Radeon
    Originalmente enviada por Holt
    ok ?
    nao importa o por que. importa que quem comprar essa vga vai ver essa coisa falhada na tela.
    como eu disse, vá ler o review.
    Esse é um bug que acontece no Far Cry.
    Olha só :
    Quality Issues Tests:
    Colin McRae Rally04 : The screenshots below show that there are no significant differences in quality.
    Max Payne 2 : Both products showed similar pictures in terms of quality, and in general, the cards are equal too.
    Painkiller : As you can see, there are no differences in quality.
    Need For Speed: Underground : As for the quality, there is no difference between the rivals.
    Pirates of the Carribean : As we see, the rivals showed identical qualities with no artefacts.
    Vietcong : no difference between R420 and NV40.
    entao. eu acho que a NV40 deveria fazer imagem mais bonita.
    e mesmo assim faz igual ou pior.
    eu sei que esses jogos nao usam nada de novo que ela pode fazer. mais..
    Na realidade, a NV40 veio melhorar a qualidade em relação a NV3x que era bem tosca, devido ao péssimo suporte ao PS2.0.
    Quem sabe, quando sair o patch pro Farcry, poderemos realmente ver algo de novo...
    eta porra ,ja ta a Nvidea tomando porrada dinovo ! eles não aprendem ! HUAEHoiuAHEouhAIOhiAE
    LONG LIFE TO ATI !!!!!
    mTs
    mTs está offline
    Membro Avatar de mTs
    Jesus te ama
    Só quero ver quando sair a proxima geração da ATI com suporte a PS 3.0.
    Adeus nvidia
    BOMsoMITO 2018!
    Membro Avatar de Cardone
    Originalmente enviada por mTs
    Adeus nvidia
    Adeus nvidia nao! Se uma das duas morrer, quem se fode somos nós!
    Que sobrevivam juntas por muito tempo!
    Caiam na real..
    nao vai ser 10FPS.. nem 100Mhz que vai quebrar uma empresa..
    Tem muita coisa por tras disso tudo..
    NoOn
    Caiam na real..
    NoOn
    hehhehe
    os caras viajam....
    zZzZzZzZzZzzz
    Tanto fez, quem comprar uma das duas placas vai ficar com elas um bom tempo...
