Página 2 de 2 Primeira 1 2
    Originalmente enviada por Sharkk
    Agora num sei mais nada:
    No TomsHardware:
    Card
    GeForce FX 5200
    Chip
    NVIDIA NV34
    Generation
    DX9
    Chipclock
    250
    Memoryclock
    400
    Buswidth
    128-bit
    Pipes
    4x1
    No Riva Tuner:
    $ffffffffff NVIDIA specific display adapter information
    $ffffffffff ---------------------------------------------------
    $0100000000 Graphics core : NV34 revision A3
    $0100000001 Hardwired ID : 0322
    $0100000002 Memory bus : 64-bit
    $0100000003 Memory type : DDR (RAM configuration 07)
    $0100000004 Memory amount : 131072KB
    $0100000005 Core clock : 249.750MHz
    $0100000006 Memory clock : 165.375MHz (330.750MHz effective)
    $0100000007 Reference clock : 27.000MHz
    Quem ta certo?!?
    No Fabricante:
    Overview
    The NVIDIA® GeForce™ FX 5200 GPU takes your graphics experiences to a new level. GeForce FX 5200 delivers not only unprecedented 3D graphics performance, the revolutionary new NVIDIA CineFX™ engine of it also introduces cinematic-quality special effects and studio-quality color to the OC for the first time. When combined with NVIDIA's rock-solid drivers, wide developer support and unique software featuresm you have a GPU that has redefined the limits of graphics engineering, performance, and visual quality.
    Features
    Memory Architecture
    - High-speed 128MB DDR Video Memory
    Hardware Specification
    - GPU Core: 250MHz
    - 63 million vertices/sec
    - 1.0 billion texels/sec fill rate
    - Up to 533 million transferfs/sec. data
    - Sideband Address (SBA) transfers rate of AGP 8X with 2.1GB/sec bandwidth
    - AGP 8X with Fast Writes
    - Architected for Cg
    CineFX Shading Architecture
    - Support for DX 9.0 Pixel Shader 2.0+
    - Support for DX 9.0 Vertex Shader 2.0+
    - Z-correct bump-mapping
    High-Performance, High-Precision 3D Redenering Engine
    - 4-pixel per clock rendering engine
    - Microsoft DirectX® and S3TC® texture compression
    - 128bits, studio-quality floating point precision through the entire graphics pipeline
    Advanced Display Pipeline with Full NView Capabilities
    - Dual 350MHz RAMDACs for display resolutions up to and including 2048 x [email protected] 75Hz
    - Video Mixing Renderer (VMR) supports multiple video windows with full quality and features in each window
    - High-quality HDTV/DVD playback
    - Integrated full hardware MPEG II decoder delivers full-frame rate, full-screen MPEG-2 video on your desktop
    Digital Vibrance Control (DVC) 3.0
    - DVC color and image sharpening control
    nView Technology
    - Support Dual VGA Out via DVI-I to VGA Adaptor
    I/O Interface
    - On board TV-Out support 1024 x 768 resolution
    - On board DVI support 1600 x 1200 resolution
    Compatibility
    - API support: Complete DirectX Support, including DirectX 9.0 and lower, and Full OpenGL 1.4 and lower support
    - Support operation system under Windows® XP/2000/ME/98
    Package Contents
    - Siluro FX5200 DT 3D Graphics Accelerator Card
    - CD Driver & SiluroDVD 4 Software
    - Adapter for S-Video to RCA TV-out Cable
    - S-Video Extended Cable
    Se Riva disse q eh 64bits, eh pq eh
    Eu tinha certeza disso. Tenho uma aqui e o score eh isso mesmo.
    Mar 2001
    sobre as memorias:
    SAMSUNG 346
    K4D551638D-TC45
    so num achei os ms.
    wkk
    wkk está offline
    quando eu compro uma placa de video já falo c nao for 128bit eu vou devolver, troca isso kra
    wkk
    wkk está offline
    vc tem o direito de trocar c nao gostar do produto em 7 dias kra
    vc não precisa alegar nada
    Mar 2001
    mas ta muita divergencia com isso.
    um fala que é 64 outro que é 128...
    existe fx5200 128bits??
    Existe duas Gf FX 5200
    As de 64bits e as de 128bits.
    A q a Toms Hardware testou eh 128bits
    A sua eh 64bits
    Entendeu agora ?
    Mar 2001
    Mar 2001
    A sua eh 64bits
    Entendeu agora ?
    Sim tudo bem, mas eu num vi ainda no mercado uma de 128 bits.
    Uma coisa que reparei é que a minha é larga e as de 64bits msm são mais fininhas.
    sinto muito em lhe informar, mas a sua eh 64bits.
    Eu tenho essa placa.
    Pra Quake3 ela roda perfeitamente com tudo q vc quiser.
    Battlefield 1942 roda com tudo no high sem problemas.
    Far Cry nunca joguei mas creio que seja do nível de BF Vietnam os gráficos...aí ela já começa a apresentar dificuldades pra rodar, a minha eu deixo os gráficos no médio e roda legal, mas as vezes fica um pouquinho lento (isso no BFVietnam).
    Mas creio que essa placa é insuficiente para rodar legal o que vem aí, como HL2, DOOM3 e mesmo BFVietnam (usando AA)...
    Mas pra CS, BF1942, WAR3 e isso q vc encontra em lan house atualmente essa placa consegue rodar tranquilo.
    Eu to querendo trocar a minha por uma Radeon 9800Pro...pois estou com meus instintos nerds aflorados e preciso de uma placa melhor.
    putz q droga amigo pela foto q vc postou e 64 bits
  13. #37
    Mar 2001
    Peguei no site a Nvidia:
  14. #38
    Membro Avatar de BIGX333
    Isso eh o projeto deles os fabricantes compram o chip e colocam da maneira q quiserem. Se apareceu no riva q a sua placa eh 64bits ela eh 64bits.
  15. #39
    Mar 2001
    não me conformo
    A caixinha diz que é 128 bits....o Riva 64 bits...
    Varios sites dizem que é 128 bits. O 3dmark01 deu 5284 com OC de 295/400. Vendo o rank do 3dmark01 na net so algumas placas ficaram acima (sendo o mesmo proc , memoria e vga).
    Em suma, não existe FX5200 com 128 bit!?
  16. #40
    Olha por essa foto vc ja ver q é 64btis ! Está vendo 4 espaços vasios na placa, esses espaços serian para colocar + 64btis ! cada chip é 16 btis ! 4 x 16 = 64...
  17. #41
    a minha eh 128 bits, ela pega 8.2 no 3dmark
  18. #42
    Mar 2001
    Originalmente enviada por The Mano
    qual é a sua?
  19. #43
    Re: não me conformo
    Aff velho
    postando de novo ?
    jah expliquei porrada de vez. Para de ser teimoso.
  20. #44
    Membro Avatar de renatods
    Se a sua for igual a da foto, eh 64 bits mesmo
  21. #45
    Mar 2001
    Bom...paciencia...
    Agora vo tenta troca por outra na PlugUse.
    A Placa de Vídeo AGP 64MB GeForce3 TI200 DDR - Daytona é bem melhor que a minha Fx5200?
  22. #46
    qual é a sua?
    ela eh da prolink...
  23. #47
    Bom...paciencia...
    Não.
