    Membro Avatar de NoOne
    MBM5 + DFI Motherboard
    1) Put Voltage.ini insite "MBM5\Data\"
    2) Open MBM5
    3) Go to Voltages
    4) Change Voltage Configuration to W83627HF DFI NFII Ultra Infinity
    5) Rename Core0 to vCore
    6) Rename Core1 to vAGP
    7) Rename -5v to vDimm
    8) Change Voltage8 to MBM Fixed and rename to vBat and check "Display in Hign and Low"
    9) Change Voltage9 to MBM Fixed and rename to 5VSB and check "Display in Hign and Low"
    DOWNLOAD: http://www.dfi-street.com/forum/atta...s=&postid=5732
    up q eh util
    vcore 1,65
    vagp 1,50
    vdimm 2,66
    ta bom isso?
    Originalmente enviada por ZaRgONN
    vcore 1,65
    vagp 1,50
    vdimm 2,66
    ta bom isso?
    isso vc ajusta
    aqui o vdimm tah a 3v
    vagp 1,50
    vcore 1,65
