    Membro Avatar de Turco-Gyn
    Novo Firmware p/ Grav. DVD LG GSA4081 Gravar em Dual-Layer !
    Nossa fantastico isso !
    Ele atualiza pra versao A104, jah atualizei aki mas nao testei ainda.
    Quem testar diz ae como ficou !?
    O arquivo readme tah em alemao, mas ele basicamente fala :
    To update the firmware of the GSA-4081B please refer to the following instructions:
    Note: Not following the subsequent update instructions explicitly will result in
    permanent damage to your drive, for which LG will not be responsible.
    This firmware update is for drives with original firmware versions below A100.
    The drives must be original LG branded drives with the DVD Writer
    model number GSA-4081B(no OEM units).
    If you have an OEM unit, branded with another manufacturers name,
    please contact that manufacturer for support and firmware updates.
    This firmware update is for use only on PC¡¯s with Windows XP, Windows 2000,
    Windows Millennium Edition (ME), or Windows 98.
    Critical Instructions: (to be followed carefully)
    1. Connect the drive as ¡°master¡± by it self, on the secondary IDE controller
    with no other device on the same IDE cable, making note to set the jumper
    on the back of the drive to the ¡°master¡± position.
    2. Download the file GSA-4081BA1041.zip to a folder of your choice.
    This download includes this ¡°Read me(ew)¡± text file, as well as the GSA-4081BA1041.EXE program,
    which will auto-update your drive¡¯s firmware.
    3. Close all other programs including: screen saver, antivirus and/or power-down programs.
    (If these programs are not closed, they will try to engage the PC, during the update process,
    thus interrupting the update and damaging the drive).
    4. Check the drive to ensure that there is no disk in the tray before you start the update procedure.
    5. Go into the folder with the update file and double click the GSA4081B.EXE program
    and click the ¡°update¡± button (red). Once the update is complete,
    you will see ¡°Firmware Update Complete¡± and the button will become green
    and advise you to reboot the system.
    You will need to reboot your PC.
    The update will be complete, after you reboot your system.
    WARNING: Do not open any programs or start any system functions during the update,
    as they will interfere with data transfer and damage the drive.
    Do not cancel the operation once it has been started or the drive will
    become permanently damaged, as a result.
    http://turco.vpg.com.br/GSA-4081BA1041.zip
    pra quem nao sabe, OEM é o mesmo produto original, porem ele é comprado por uma empresa (IBM,HP,COMPAQ ...) e jah vem montado no computador.
    [ ]´s Turco.
    Redação
    Avatar de Cadu®
    Brotherhood
    OEM
    é produto sem caixa... so isso
    PORRA, muito legal!
    Membro Avatar de Hal J.
    Originalmente enviada por Cadu®
    OEM
    OEM não é só isso não... Tá muito longe de ser só isso.
    A definição correta é a do Turco mesmo.
    Grandes fabricantes compram de outras empresas e colocam suas marcas, esse é o verdadeiro significado.
    Ae galera, nessa pagina tem tudo sobre firmware !
    http://forum.rpc1.org/portal.php
    Aproveitem !
    ps: da pra usar o firmware do gsa 4082 ( o bin 206) na GSA 4081, porem tem q usar o flash utility para dos do 4081.
    ]PF[ Red Bull, tah ae os firmware q vc pediu !
    ftp://ftp.software.ibm.com/pc/pccbbs...p3309_a113.exe
    LG/HLDS GSA-4040B
    http://de.lgservice.com/jsp/common/d...p&FILE_GUBUN=B
    LG/HLDS GSA-4081B
    Cuidado ao atualizar , leia o readme antes.
    Mar 2001
    Originalmente enviada por Turco-Gyn
    LG/HLDS GSA-4040B
    LG/HLDS GSA-4081B
    O que ele faz exatamente com o LG GMA-4040B? IBM multburner? O meu é o GSA-4040B, tem difereça?
    Originalmente enviada por ]PF[ Red Bull
    opa opa isso muito me interessa, rola esse update no LG GSA-4040B?????????
    Membro Avatar de Chicão
    tenho que estar com o A100???
    pq se não me engano já fiz 2 updates....mas ele tá desligado agora nem dá pra ver em que versão está.....tem como voltar p/ default?
    E ai caras, alguém já fez a troca do firmware do 4081? E testou? Alguém tem ideia de onde comprar DVDs 2 layer?
    Membro Avatar de NoOne
    Se rolar no 4040B é interessante
    Explica ai turco
    Membro Avatar de Gung@
    Gunga
    Como diria o Padre Quevedo, " Isso non ecxiste".
    O que esses novos firmwares fazem é melhorar a LEITURA de mídias Dual Layer. Gravar DL apenas o LG 84120B. E suporte futuro a isso pelos 4040b, 4081 e 4082, é pouquíssimo provável, só se alguém fizer milagre no firmware.
    Mar 2001
    Turco-Gyn
    Cara aparece para explicar melhor...
    Alguém sabe a diferênça entre essas !?
    LG HL-DT-ST GSA-4040B (GMA/GWA/GRA/GCA-4040B)
    RPC1 Firmwares based on: A302, D303, and A303
    LG/HLDS GSA-4040B -
    A101, A109, A112, A113 (OEM drives)
    A300, A301, A302, A303
    News !?
    Gunga
    RPC1 é região livre. A A303 é igual a A113, que melhora leitura de midias.
    Sabe a diferenca da OEM pra Nao OEM
    Gunga
    `Não sei, mas a versão usada nos OEM e BOX é a mesma A30X.
    tem do 4082 ????
    Membro Avatar de kernel
    up q eu tb quero saber
    =P
    To querendo comprar o modelo da LG GSA-4120BA, esse sim grava DVD-DL e DVD-RAM.
    Originalmente enviada por Chicão
    ninguem?
    Tb acho difícil update pra gravar dual layer.... onde tá escrito q esse firmware novo permite gravar dual layer?
    Jan 2004
    alguem me explica o ke se apssa?!
    Originalmente enviada por Luv Ya =*
    apssa nada
