    Problema Com MemÓria E Motherboard Tem Algum Software Para Testar Esses Componentes ?
    E AE PESSOAL, ESTAVA PENSANDO ESSES DIAS POIS PEGUEI UM LOTE DE MEMÓRIAS E MOTHERBOARDS PROVAVELMENTE COM PROBLEMAS POIS ESTAVA RESETANDO OUTRA HORA TRAVAVA E ASSIM POR DIANTE, GOSTARIA DE SABER ALGUM SOFTWARE QUE PUDESSE EFETUAR ALGUM TIPO DE TESTE OU BURN-IN QUE ESTRESSASSE O EQUIPAMENTO ASSIM EU PODERIA SABER SE ESSE AQUIPAMENTO ESTARIA EM BOAS CONDIÇÕES.
    NO MOMENTO ESTOU USANDO 3DMARK E PCMARK GOSTARIA DE OUTRAS OPÇÕES..
    VALEU
