    Disabled
    [HELP]qual desses processadores é o melhor??
    Tem esse: Processador AMD XP 2500+ Barton OEM (279,00)
    Model: AMD Athlon XP 2500+
    Core: Barton
    Operating Frequency: 1.83GHz
    FSB: 333MHz
    Cache: L1/64K+64K; L2/512K
    Voltage: 1.65V
    Process: 0.13Micron
    Socket: Socket A
    Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
    Packaging: OEM(Processor Only)
    Esse: Processador AMD XP 2600+ BOX (340,00)
    Model: AMD Athlon XP 2600+
    Core: Barton
    Operating Frequency: 1.9GHz
    FSB: 333MHz
    Voltage: 1.65V
    Process: 0.13Micron
    Socket: Socket A
    Packaging: Retail Box (Heatsink and Fan included)
    Esse: Processador AMD XP 2500+ Barton BOX (299,00)
    Core: Barton
    FSB: 333MHz
    Voltage: 1.65V
    Process: 0.13Micron
    Socket: Socket A
    Esse: AMD Athlon XP 2600+ 1.91GHz 333FSB 512KB Retail (369,00)
    Core: Barton
    FSB: 333MHz
    QuantiSpeed™ Architecture
    640K Total High-Performance, Full-Speed Cache
    Advanced 333 Front-Side Bus
    3DNow!™ Professional Technology (72 instructions, full SSE compatibility)
    Support for Double Data Rate (DDR) Memory
    Established Socket A Infrastructure
    Socket: Socket A
    Item # zzfproduct
    E AE qual é o melhor modelo e qual eu poderei chegar a 3200+ sem problemas??? me ajudem!
