Página 1 de 6 1 2 3 ... Última
    Doom3 Benchmarks:
    eh eh , mais detalhes soon!
    A John Carmack Message
    John Carmack wanted to take a moment to talk to the gamers and hardware enthusiasts that would be reading today. He has some insight on the numbers and what they really mean as well as some thoughts for the overclockers out there.
    It should be noted that all of the modern cards play the game very well, and benchmark scores should not be the be-all-end-all decision maker. Scores will probably improve somewhat with future driver releases, and other factors like dual slots or dual power connectors can weigh against some of the high end cards.
    The benchmarking was conducted on-site, and the hardware vendors did not have access to the demo before hand, so we are confident that there is no egregious cheating going on, but it should be noted that some of the ATI cards did show a performance drop when colored mip levels were enabled, implying some fudging of the texture filtering. This has been a chronic issue for years, and almost all vendors have been guilty of it at one time or another. I hate the idea of drivers analyzing texture data and changing parameters, but it doesn't visibly impact the quality of the game unless you know exactly what to look for on a specific texture. On the other hand, the Nvidia drivers have been tuned for Doom's primary light/surface interaction fragment program, and innocuous code changes can "fall off the fast path" and cause significant performance impacts, especially on NV30 class cards.
    A note on overclocking: it is very likely that overclocked configurations that "play everything else perfectly" will start to show problems on D3 due to new usage patterns. Everyone is of course free to do whatever they want with their own hardware, but don't complain to us...
    http://www2.hardocp.com/article.html?art=NjQy
    Membro Avatar de AgileR
    Dono da Hardmob
    Ja saiu??
    Ati keria guerra com benchs de Hl2???
    ENTAO TAE A PORRA DA GUERRA!
    ID missao cumprida, liberou benchs 3 semanas antes do jogo COMO PROMETIDO.
    nem tudo esta perdido, por mais marketing q seja.
    Membro Avatar de Hot Since 82
    Don't stop the beat.
    E tá boa a taxa de frames ali
    abraco a adrenaline e bom copy paste das minhas news
    Ao q tudo indica, o jogo é realmente mais leve q o farcry.
    E o fps não cai quase nada de 1024x768 pra 1600x1200 nas 6800.
    Interessante tb a nota sobre overclock nas VGAs. Esse sim vai sugar todo o suco da VGA. hauheuiaheaie
    PS: Vc esqueceu das outras screens do bench diesel.
    Membro Avatar de DeatH
    GETTUDA CHOPPAH
    Dec 1999
    logico
    engine do farcry foi feita no joelho
    bem esperado esse score, pois a ID trabalha em opengl
    gostei mto do desempenho da GT
    Apr 1999
    Originalmente enviada por overruled
    Falei isso há alguns dias atrás, e todo mundo me zombo!
    para mim o grande vencedor é a 6800 GT.
    Com custo/benefício, hiqh quality com ótimo frame rate e não muito distante da 6800U.
    resultados dentro do esperado
    nvidia = ogl
    ati = direct3d
    Esqueci de mencionar...
    Com certeza com esse bench do doom3, a proporção de vendas da nvidia irá aumentar consideravelmente. Será uma corrida ao 6800GT.
    Mesmo se amanha sair um bench mostrando uma superioridade da ATI no HL2.
    Pelo q vi vai rodar no meu PC
    Mais leve q Far Cry ?
    Boaaaaaaaaa
    Vai rodar no meu PC então
    Membro Avatar de duferrari
    Originalmente enviada por FastMHZ
    Para efeito de direitos autorais o nome que você digitou esta sendo substituído por este texto?
    Membro Avatar de TM99
    ahhhh
    tomara que minha radeon 9500 PRO com um filtro do core arrancado rode o jogo sem problemas, e tomara q esse filtro arrancado nao va zuar minha placa justo agora q ta saindo doom3 =[
    Ja vi que vou rodar tranquilo aqui, eu APOSTO que a ATi vai correr pra melhorar os drivers de OpenGL, e o time do catalyst é foda, só olhar a progressão de performance da 8500 desde que ela nasce até seu "final de carreira"
    edit: tem que ver que eles devem estar usando os drivers atuais com OpenGL porco, na pior das hipoteses fazemos o velho truque de meter o opengl do 3.7 e somos felizes hehe
    eu acho melhor voce colocar todas as screens de bench para o pessoal comparar com aa/filtro sem aa/filtro..se bem que pelo visto ninguem vai rodar mesmo com isso uhaiuhiahiua
    o mais interessante e os bench das 9800x5950 o foda mesmo e que sao aqueles fps naquela puta maquina..
    Ae, se liga mano!
    Originalmente enviada por mackbad
    Mesmo com filtro, a X800XT PE ainda PERDE para a 6800GT !!!
    Na boa, até fiquei com dó da X800Pro.
    Apr 1999
    Se nao me engano, vi o bench com uma 5950 em AA4x com a media de 30FPS no High...
    Entao isso ai vai rodar sem filtro no High com 30FPS ate numa 5600/5700
    Creio eu neh...
    Pelo resultado do bench, supostamente não havia um boato do Doom3 ser 60fps locked ?
    Se está batendo 72fps ali no TimeDemo1 1024x768 HighQuality NoAA 8XAF...
    Nada de Benchs em 9800Pro/XT - FX5900/5950 Ultra?
    Pq pelo q tudo indica @ [email protected] vai rodar sussa com 2xAA e 4X Anisio numa boa acima de 60Fsb...
    E outra, logo logo a Ati lança drives mais evoluídos pra Opengl, mas não se esquecam q Nvidia e Carmack tem coisa o.O
    Timedemo... O comando timedemo ignora qualquer limite de fps... Exatamente pra fazer benchmark.
    PS: sobre o "Para efeito de direitos autorais o nome que você digitou esta sendo substituído por este texto?", foi por causa do "O 6800..."
