    Membro Avatar de jtedaldi
    Ati catalyst 4.9 beta
    PLEASE READ ALL OF THIS BEFORE YOU PROCEED:
    The BETA display drivers found here are offered AS IS, without warranty of any kind, and have NOT been completely qualified by ATI. Usage of these drivers are without support of any kind, and you use them at your own risk.
    ATI does NOT recommend installing these drivers in systems used for mission critical operations or where productivity of any kind is a concern.
    Unless you are very comfortable with installing and un-installing drivers, we DO NOT recommend that you use the drivers provided here. These BETA Drivers are NOT SUPPORTED by ATI Customer Care or any other ATI department.
    Pelo que eu vi Doom 3 devera rodar melhor com isso
    Quem quiser testar => http://www.ati.com/support/infobase/4547.html
    mas nem saiu o 4.8 normal ainda
    uehuahue
    mas nem saiu o 3.8 normal ainda
    uehuahue
    Acho q vc quis dizer 4.8 hehehauhuahuah
    Originalmente enviada por yoshida
    isso isso!
    me enganei
    Membro Avatar de duferrari
    Desespero depois de ver 6800GT > X800XT hehehe
    Membro Avatar de syndragon
    acidez construtiva
    Apr 2000
    Remember that these are Beta drivers, and so are unsupported. If you want stability and good speed, please stick with the release drivers. Cat 4.8 has not been skipped, and should arrive soon.
    "Ok I just tested these drivers on my x800 [email protected]:
    Game Config
    Ultra High Quality
    Vsync Off
    1280x1024 resolution
    TIMEDEMO 1
    Catalyst 4.8b Results
    FPS: 60.2
    Catalysts 4.9b Results
    FPS 66.3
    pelo q to vendo isso ai mais me parece um "hotfix" pra doom3 do que um driver
    Originalmente enviada por Dragon
    Game Config
    Ultra High Quality
    Vsync Off
    TIMEDEMO 1
    FPS: 60.2
    FPS 66.3
    aff...
    60fps.. lol
    fiz 30 aqui com a [email protected]
    motivo: p4 sem over e memo generica 2.5 3-3-8 400mhz SINGLE CHANNEL
    303 está offline
    aff...
    60fps.. lol
    em 1280x1024 e no Ultra High Quality ?
    ta... conta outra....
    no D3 tive um ganho de 2 fps no timedemo
    q bosta.
    Nem saiu o 4.8 oficial e jah ficam lançando beta.
    Originalmente enviada por 303
    lol
    em 1024×768 no Medium, VSync a FSAA off, no driver tudo setado pra alta performance, menos o nivel de detalhe do mipmap que tá em performance.
    leia direito.. 2.4ghz stock (porco), generix 2.5 3-3-8 ddr400 SINGLE channel
    amanha chega a nova e no minimo do minimo é 3.42cghz garantido
    fora que é dual-channel, timmings melhores e mais mhz na memoria.
    ja vai dar uma PUTA diff, visto que no d3 a placa de video dá tudo oq pode.
    Originalmente enviada por Richard Fortus
    q bosta.
    eh uma bosta mesmo, mas foda-se vo testar aqui e posto conclusoes
    Eu não tenho ATi, mas vcs ainda não entenderam pq as novas versões dos drivers da ATi(principalmente OpenGL) vão melhorar bastante? pq a ATi se reestruturou, o pessoal que trabalhava no driver OpenGL trabalhava em outro departamento(na verdade, em outro país!)... aí a ATi colocou todo mundo no mesmo lugar e mandou tomarem vergonha na cara, juntou o time do hardware com o time do Catalyst e mais o time que só fazia o OpenGL... o resultado tá saindo... e não é só para o Doom3... é pra começar de novo, tentar fazer o FireGL decolar, pq em drivers OpenGL profissionais a ATi está ainda muuuuuito mais atrás...
    Não é desespero nem hotfix, essa reestruturação já foi planejada muito antes, por sorte alguns bons resultados já estão saindo...
    flw
    Realmente, isso foi desespero da ATI para cima do Doom 3.
    Legal que saiu BattleField: Vietnam e o pessoal da ATI demorou infinito (mais de 1 mês e meio) para lançar um driver descente para ele.
    Doom 3 sai oficialmente hoje e ja tem driver so para ele, hehehe. Galera da ATI deve ter ficado louca de tanto email cancelando as x800.
    Mas a minha principal dúvida é:
    Como a galera consegue mais de 60 fps no jogo se ele tem limitação a 60 fps na própria engine? Cheaters?
    PS: Alguem ja checou ai se a qualidade continua a mesma no jogo?
    A engine roda a 60fps, mas não tem limitação de fps em timedemo. Continua sendo 60 fps fixo na engine, mas é como se rederizasse o mesmo frame 2x.
    Membro Avatar de POLAR
    http://www.theinquirer.net/?article=17618
    Leiam explica bastante sobre esses drivers.
    acidez construtiva
    Apr 2000
    "I never meant to make anyone think I am a beta tester, I could be, but I don't have enough time. I do however have access to them at work, in which we have a great relationship with ATi.
    As I have said before, I haven't said anything that hasn't already been printed, you just need to know where to look. I have a hard time keeping my mouth shut but I still need to feed my family so I always double-check what I say.
    If you listen to anything I say, it should be this:
    Do not get rid of those older DX9 cards just yet, a year from now they will still do the job and you won't even believe the graphics they can pump out. The engine I am working on is (at least) on par with DOOM3 and I can play with it on my home system (listed below). Only difference is the API is DX9 as opposed to Opengl.
    ATi is just getting warmed up. And they haven't left anyone behind."
    gostei desse driver, nao percebi mudança gritante no FPS, mas nao piorou em nada, eu acho que valeu a pena ter baixado esse driver..
    a imagem esta igualzinha ou melhor, nao piorou em nada tb..
    Originalmente enviada por tr.
    Pessoal falou que doom 3 esses driver roda blz.
    Mohaa, Cod, CS (nem rodava direito antes) e outros jogos em opengl, não funcionam no 4.9.
    Apr 2000
    Eu instalei, he necessario o dx 9.0c, eu tava com o b ai nao rodava 3dmark nem war3... a pontuacao no 3dmark ficou igual ao 4.8b, no quake3 deu uma melhorada, mas nada demais uns 10 fps, fodah eh q nao tenho doom3 pra testar
    Originalmente enviada por Jota Morane
    Vc não tem doom 3 e instalou o 4.9 alpha?
    Vc tem ideia do que é um alpha? Pensou nisso antes de instalar? Os drivers normais da ATI ja bugam, os betas tem muitos problemas, os alphas??? Vc não vai querer saber dos alphas.
    Tem que fazer um ponto de restauração do sistema antes de instalar o 4.9 e o dx9.0c. Depois que vc zerar o doom 3, vc restoura de volta ao 4.8 beta ou a 4.76 final e dx 9.0b.
    Não uso driver alpha nem da nvidia!
    Membro Avatar de TM99
    mudo nada aqui do 4.8 pro 4.9
    Apr 2000
    Rapa... pro jogos q eu curto ate agora nada de problema, tb soh jogo war3 e q3 mesmo, e qnt a doom3 daqui a poco acaba o dl e quero testar, se bem q com 256 de ram eh fodah e pra completar 64 de video
    Uau hein... q medo de instalar driver... pff... q bixola !!
    Não vai explodir o pc não se o driver tiver algum bug viu... Qq coisa soh remover e instalar outro...
    E me fala uma coisa, pra q alguém vai kerer voltar pro DX9.0b se o 9.0c ja eh versão final? :O
    acidez construtiva
    Apr 2000
    Do 4.8beta pro 4.9beta só muda com as X800.
