    Membro Avatar de ZaRgON
    Asus Ati Radeon X600 Xt
    Alguem sabe dizer se isso presta?
    Equivale a qual placa? 9800pro? 9800xt?
    More Info & Product Specification
    Part # EAX600XTTD128
    Cable/Adaptor Bundled; TV-Out adapter, DVI-to-2nd VGA output adaptor. Software Bundled; Free CD Case, Deus Ex: Invisible War, ASUS DVD XP, Power Director 3, Media Show, ASUS Driver and Utilities
    Powered by the world’s powerful PCI-E VPU – ATI Radeon X600 XT VPU
    Native PCI Express: full 16 lane support with 8GB/sec bidirectional peak bandwidth support
    Uses 0.13 micron with low k to bring a robust low power high performance DX9 solution.
    SMARTSHADER™ and VIDEOSHADER™: provides superior programmability and performance, by implementing Microsoft DirectX9.0-level shaders at full precision at all times.
    4 full precision pipelines: over double what the competition can offer to provide over 2 GigaPixels/sec of unmatched shader power.
    One slot solutions which output less heat
    Microsoft® DirectX 9 and OpenGL 1.5 support
    PCI-Express x16 lanes native support
    ASUS GameFace Live is the world's first multiplayer audio and video chatting solution for PC gamers
    ASUS VideoSecurity Online builds your own security system on PC
    ASUS OnscreenDisplay adjusts your display settings while playing PC games.
    ASUS SmartDoctor for optimum PC performance and safety features.
    ASUS SmartCooling dynamically adjusts your VGA fan speed for a quiet computing environment.
    ASUS HyperDrive provides 3 ways to dynamically boost graphics card power.
    High-quality TV output for big screen gaming or presentations
    Video input supports real time video captures, high quality video compression and vide editing
    DVI output for easy connectivity to digital flat panel display
    Diversified displays connectivity (HDTV / Video-In / DVI-I / TV-Out )
    Graphics Engine ATI Radeon X600XT
    Video Memory 128 MB DDR
    Engine Clock 503MHz
    Memory Clock 736MHzHz(368MHz DDR)
    RAMDAC 400MHz
    Bus Standard 16 lanes PCI Express
    Memory Interface 128-bit DDR
    Max Resolution 2048x1536
    VGA Output Standard 15-pin D-sub
    TV-out put S-VHS & Composite
    DVI Output DVI-I
    2nd VGA Output Yes
    One Year Warranty
    Pictures are for illustration purposes only.
    4ppl...
    128bits...
    Deve ser um pouco melhor que a 9600xt...
    Originalmente enviada por JSM Again
    4ppl...
    128bits...
    Po q bosta entao... lançar uma placa com nome diferente e desempenho pareceido...
    Membro Avatar de duferrari
    Equivale a Radeon 9600XT com PCI-Express... Concorrente da PCX5700 (5700 Ultra com PCI-Express)
    Ela é pouca coisa melhor que uma 9600XT
    Ainda essa porra deve ser caro.
    Originalmente enviada por Richard Fortus
    Não deve custar muito mais que uma R9600xt...
