    Membro Avatar de NIex
    apl525 here
    Saiu ATi Tool 0.0.21, temps na 9800PRO c/ pcb de XT.
    ATITool - Version History
    Version 0.0.21
    Scan for Artifacts now makes a log entry every 15 minutes.
    Added and tested X800SE PCI-E overclocking support.
    When the main window is partly or completely off screen when launched, it will be moved to be visible.
    Render window requires a hw accelerator + running driver.
    Disabled maximizing/minimizing of render window.
    Moved I2C access code into kernel driver.
    Added option to set video card PCI latency
    Improved theme support (more like enabled it).
    Added option to create desktop icon after install.
    Added RV410 support.
    Added Video Memory Timings Editor (not in 0.0.21 release but in next dev. build)
    Added option to disable the tray icon (icon will always be visible while ATITool is initializing).
    Added Gamma Control
    Added experimental "Remove 9000/9200/9550/9600 clock lock"
    Trying to overwrite the default profile now gives an error msg.
    Added option to limit log file size.
    Bugfixes to the installer.
    Added fan control for X800.
    Added options to disable Direct3D error messages.
    Added shared memory, other applications can now get ATITool data.
    Fixed settings window popping up in wrong place.
    Statically linked version - distribution is now only 820 KB in size!
    Updated Kernel Mode driver - getting ready to port to 64 Bit.
    Tray icon is automatically recreated when explorer crashes
    If the tray icon can't be created (possible during windows startup, explorer is not running yet) just continue loading and create the icon as soon as explorer is ready.
    Added text field with temperature to main window.
    Added support for Radeon 9550 - these cards are overclocking locked. Use the softmod drivers.
    Added support for sending clock/temp. data to MBM
    Added option to log temperatures
    Added overclocking/temp. monitoring support for X600.
    Added temp. monitoring support for 9800 PRO on XT PCB with temp. chip.
    Profile selection is no longer saved on exit, but on change.
    room.x now included in executable.
    Fixed bug where the tray temperature display would get stuck on desktop resize.
    3D detection seems to have issues with DirectX 9.0C beta - this will not be addressed until the final version of DX9.0C is out.
    Fixed bug with temperature detection
    Fixed bug where find max. would try too high clockrates when clock frequency limits are enabled.
    Added warning if D3D Debug Runtimes are active.
    Screensaver will be disabled during 'find max' and 'scan for artifacts'
    Added 'add to start menu' all users/current user
    Tweaked 3D detection, will now work with UT2K4's d3d9 renderer
    Added option to change font/color of temperature in systray
    Added temperature monitoring for ASUS cards, thanks Peter
    Added extra checks to low-level hardware code
    Download.
    http://www.techpowerup.com/atitool/ATITool_0.0.21.exe
    Alguem testa ai porque to no trampo agora
    downloading..
    vo testar, valeu nielsen!
    Membro Avatar de Rubra
    como que eu descubro se minha vga é pcb de xt??
    apl525 here
    Originalmente enviada por Rubra
    Quem quer saber se a vga tem suporte a monitorar temperatura deve ler o artigo do link abaixo.
    http://www.techpowerup.com/articles/...ing/vidcard/94
    q bosta hehe
    com ATITool v0.0.20
    2004-08-16 20:36:49 Detected Chip: R360 (4E4A), 8 Pipelines, 128 MB, Tempchip: yes
    so que se eu colocava pra mostra a temp, nao aparecia nada
    2004-08-20 14:41:01 ATITool v0.0.21 started.
    2004-08-20 14:41:01 Detected GPU Chip: R360 (4E4A), 8 Pipelines, 128 MB
    2004-08-20 14:41:01 Temperature monitoring: chip not detected
    agora nao da nada! hehehe
    Membro Avatar de b4dmind
    Brusque - SC
    aki deu certo!
    O minha ta a 71 graus!
    apl525 here
    Originalmente enviada por b4dmind
    aki deu certo!
    auehuaheaehheu
    Mais um que tá ferrado..
    http://forum.hardmob.uol.com.br/show...hreadid=312069
    A minha deve estar melhor graças ao coolermod, mais num deve estar muito fria não..
    De qual sensor vc pegou, vc viu que tem dois neh???
    Minha esta a r9800pro sem mod pra xt esta a 68 graus, temp ambiente aproximadamente 27 graus
    aki nao mudou nada
    nao piorou tb..
    Brusque - SC
    auehuaheaehheu
    mais a minha ta com over aki
    415/700
    Brusque - SC
    Outra coisa... qual a diferença de temperatura remota e de local?
    Fala ali no ATI tool...
    Alguém sabe?
    A remote ta 72 e a local ta 48! estranho!
    axo bem estranho essas temps pq jah passei 3dmark com over em 480/800!
    apl525 here
    Local acho que é o sensor da GPU.
    E o Remote é o do próprio chip interno do LM63, como se fosse a temperatura da placa...
    Jun 2001
    aqui funfou,70 graus.
    apl525 here
    Acabei de instalar aqui..
    Vejam na SS abaixo..
    Deixei rodando um poko em idle 380/680 e um poko em full 450/780 pra ver a diferença de temp isso rodando o scan for artitacts do ATi Tool..
    68/43 aki
    como faz pra mostrar a velocidade do fan da radeon no MBM?
    Membro Avatar de Gung@
    Gunga
    No ATI tool, aba settings, Temperature monitoring, as duas últimas opções são para isso, vc só coloca o numero do sensor para o MBM.
    Digdin Digdin Digdin
    mas q numero eu boto ali?? deixo 0??
    as temps eu ja coloquei
    qria saber a velocidade fo fan...
    King_of_Sex
    vc deve colocar um valor q nao ja esteja sendo usado, soh abrir o MBM e ver qual nao esta sendo usado, aki por exemplo coloquei em 4 e 5
    Originalmente enviada por [email protected]øn
    King_of_Sex
    funcionou, valeu =P
    apl525 here
    Velocidade do fan num dá..
    A minha aparece aqui porque eu to usando coolermod e liguei o fan de 60mm no sensor da ABIT..Nem liguei esse fan direto na vga, acho que deve queimar..
    PQP 60º idle hj
    Sampa is DAMN HOT
    PQP 60º idle hj
    Sampa is DAMN HOT
    aki tah a 65!
    e eh aquele cooler q vem na sapphire, um poko maior q o da BBA...
    Membro Avatar de Cardone
    Da pra ver a velocidade do fan com o cooler original pelo MBM ?
    apl525 here
    Se vc le-se as respostas ia saber
    ahh entao assim sim !!!
    Membro Avatar de CiB | Sid
    poutz, perfeito... tava precisando aumentar a velocidade do fan da vga mesmo... =D
    64/41 aki na minha 98xt
