    Logitech launches MX1000 Laser Cordless Mouse
    http://www.dvhardware.net/article3003.html
    WOW!!!
    L A S E R !!!!
    20x mais preciso que ótico!!!
    Olha, tem até Barrinha de Nitro...
    pow eu desenho a mais de 10 anos, logitech eh o q ha em materia de mouse/teclado.
    Originalmente enviada por TexTexano
    AUEAHUHUEAhueA*(EUa8euaE*AEhAHUEHUEAHEa
    Meu deus do céu ahueuheauhehahueaea
    Email inválido
    já tem precinho o meninão ai ? meu "logitech" ja ta ficando zuado
    Mar 2001
    uahhuoahaoahoahoaua tinha q ser o TEXXXXX
    hangar rlz =]
    aohuahoaua
    Membro Avatar de NIex
    apl525 here
    Parece ser bem boizão..
    HsiuAOHsuioSioUHASOUIahSIOuhASUOI boa PQP AHsuioASHuiAHSUI
    Logitech has silently launched a new cordless MX-series mouse, the MX1000 Laser Cordless Mouse. This will probably be the successor of the MX700 mouse. The main difference between the MX700 and the MX1000 is that newer one doesn't use an optical sensor, but a new laser which is according to Logitech 20 times more accurate than an optical sensor.
    The Logitech MX1000 has a Tilt Wheel and it uses a lithium-ion battery. The status of this battery can be read out directly from the mouse. Just like the MX700 this one uses the FastRF technology to transfer data from the mouse to the cradle.
    Tweakers reports that the mouse has about the same form as the older mouses, but that it has a darker exterior.
    The advice price in Europe seems to be 79.99EUR, but some shops have it listed for less than 60EUR.
    Tirado do link postado no forum.
    quanto será q custa isso + ou - ?
    Pareçe um casco de cavalo olhando debaixo
    Logitech cavalo's edition devia se chamar isso dai....ateh pq o mouse parece ser grande!
    Originalmente enviada por \\'.O.L.F
    casco d cavalo?
    hauehaiu
    Membro Avatar de Lunatico
    Se o MX700 já custa uns 300 contos aqui, esse virá por 500 reais.
    Eu mal to conseguindo juntar pra comprar o MX500...
    Membro Avatar de DeatH
    GETTUDA CHOPPAH
    Dec 1999
    ktos dpi sera isso ai?
    Membro Avatar de Arraso
    Apr 1999
    Na boa, o mouse é gigante. Peguei num MX500 e não curti. Não serve pra minha mão pequena (e olha que eu tenho quase 2m de altura).
    60 euros... uns 50 dólares
    Não é TÃÃÃÃÃO caro assim.
    To long
    mx700, a perfeição em forma de mouse...imagina esse....meu proximo mouse com certeza!
    BOMsoMITO 2018!
    OBa
    meu proximo mouse tb !!
    minha mao pesa quase 2 kilos e meio !
    Membro Avatar de rocknaveia
    Que eu saiba o Euro vale mais que o dolar, eu tenho um MX500, minha mão eh normal, nao vejo dificuldade nenhuma em usar o mouse, e tem viadinho que acha pesado uheuheheu po, nao vou pra academia levandar 80kg no supino e achar um mouse de 100gr pesado uhdsauhsaduhdsauh
    PS: Muito rulez esse mouse novo
    perai que nao acompanhei
    60 euros - 50 dolares?
    Originalmente enviada por Dale
    Rpz...sabe que eu tb nao entendi essa matematica.
    Euro ta + ou - 3.80 equanto o dolar ta 3.00 uhehueuhe o cara eh o genio da matematica
    Bacana, mas tinha q ter um desse COM fio. Naum adianta, naum gosto de lance sem fio.
    OBa
    se sua mão pesa 2,5kg, imagina esse "rabaum"
    HuohOahEUHauhUoHeihEAHouHauhUaHauhOw!
    Brincadeira Doug
    Originalmente enviada por Ydur
    Brincadeira Doug
    UAEWHAHWHAWUHAWEhaweAHWEU
    zuo
    tipo... mouse sem fio sux...
    mouse grande sux
    mouse pesado sux
    eu tenho 2.03m (jah que geral comento altura aeh) e me incomoda usar mouse pesado durante o dia... chega no final da tarde o pulso jah começa a incomodar... mouse tem que ser leve e anatomico..
    n adianta fazer uma coisa extremamente precisa e pesada e incômoda para o uso...
    outra coisa eh o euro... euro tah mais caro sim.
    eu tenho um logitech aki,, optico.
    funciona direitinho... da pro gasto..
    se for pra gastar 500 reais com alguma coisa aki.. vai ser com dvdrw ou um nobreak... hehehe
    mouse de 500 reais pra mim eh suicidio!!!!!
    BOMsoMITO 2018!
    Brincadeira Doug
    AJeaeuhaeuauhehaue Safado !
