    Aumentar tensão no AGP pras VIAs?
    É necessario aumentar a tensão no agp para chip7s VIA?
    Eu tenho uma Soyo Dragon KT600 Plus e da pau no AGP 8x
    eu so abrigado a colocar em 4x pra ficar perfeito, alguem sabe se o problema é de tensão?
    Meu PC:
    Athlon XP [email protected]
    896MB DDR pc2100 [email protected]
    Inno3d FX5600XT 256mb 128bits
    VCOM 400w
    $0400000000 Description : VIA KT400/600 series
    $0400000001 Vendor ID : 1106 (VIA)
    $0400000002 Device ID : 3189
    $0400000003 AGP bus : revision 3.0
    $0400000004 AGP status : enabled
    $0400000005 AGP rate : 4x supported, 4x selected
    $0400000006 AGP SBA : hardwired, enabled
    $0400000007 AGP FW : not supported
    de acordo com o riva turner chip7 kt 400 e 600 nao suporta agp8x
    $0000000000 Description : NVIDIA GeForce FX 5600XT
    $0000000001 Vendor ID : 10de (NVIDIA)
    $0000000002 Device ID : 0314
    $0000000003 Location : bus 1, device 0, function 0
    $0000000004 Bus type : AGP revision 3.0
    $0000000005 AGP status : enabled
    $0000000006 AGP rate : 4x 8x supported, 4x selected
    $0000000007 AGP SBA : hardwired, enabled
    $0000000008 AGP FW : supported, disabled
    $0000000009 Base address 0 : e4000000 (memory range)
    $000000000a Base address 1 : d0000000 (memory range)
    $000000000b Base address 2 : none
    $000000000c Base address 3 : none
    $000000000d Base address 4 : none
    $000000000e Base address 5 : none
    naum, mas explica como eh esses bugs q vc falou no icq
