    Softmod [email protected] PE quem fez ou sabe fazer entra ae
    Blz pessoal!
    Bom, to aki com minha X800PRO VIVO querendo fazer o mod, mas surgiu algumas duvidas:
    Quantas vezes tem que flashear a bios? 2 ou 3x?
    Com quais bios?
    Como faz pra ver a temperatura da placa?
    Bom galera, toda a ajuda é bem vinda...
    Agradeço antecipadamente.
    Recebi minha Gecube X800Pro VIVO ontem e já fiz o MOD @ XT PE, 101% OK e funcionando uma maravilha!!!...UAhuHAUhUHauhUhA
    Resultado do 3DMARK 03, com P4 2.8Ghz padrão, sem overclock.
    X800ProVIVO (475/450) 12 pipes => 9950
    X800ProVIVO @ XTPE (520/560) 16 pipes => 11867
    Para fazer o MOD, basta seguir o procedimento que peguei no OCFORUMS, qualquer dúvida é só falar.
    => http://www.ocforums.com/showthread.php?t=312063
    OBS.: Essa BIOS "x800xt.rom" que eles passam, tem o clock dela a 525/573, eu acabei pegando outra BIOS da ATI X800 XT PE BBA cujo clock é o padrão 520/560
    Coleção de BIOS da ATI
    => http://www.techpowerup.com/bios/
    ATI TOOLS
    => http://www.techpowerup.com/atitool/
    This is a list of everything you will need:
    * An ATI Radeon x800pro (with succesful pipemod) or pro VIVO (which seem atm to need no hardmod) capable of 520MHz core clock and 560MHz DDR memory clock
    * Flashrom v2.37 (Provided in download below)
    * A copy of the Gigabyte ATi Radeon X800XT BIOS and Gigabyte Flash Utility (Both provided in download below)
    * A copy of your original card type X800PRO bios (ie PRO or Pro-VIVO: both provided in download below or you can make your own)
    * A copy of the final X800XT bios you wish to permanently use (Official ATI X800XT-PE bios provided in download below)
    * TWO DOS boot floppy disks (WinXP dos boot disc provided in download below)
    * A copy of ATI-tool 0.0.20 to verify pipes and flash success
    Once you have downloaded the file below you should have everything you need to flash your x800pro.
    Ok, firstly you will need to extract the Gigabyte archive to the first floppy disc, as this is the only flash utility to effect the pipelines. Then you will need to extract the flashrom archive to the second floppy disc, and extract one of the two provided backup pro bios' onto it as well (x8pro20.bin - if your card is a standard PRO with 2.0ns samsung ddr, or - x8pro16.bin - if your card is a VIVO with 1.6ns samsung ddr).
    You now have 2 DOS bootable floppy discs, one containing the Gigabyte flash utility and the primary X800XT bios, and one containing Flashrom and both your original X800PRO bios type (part of the process and as a backup) and your final X800XT bios.
    UNINSTALL ALL ATI DRIVERS BEFORE STARTING THE FLASHING PROCESS.
    However, ensure whatever ATI drivers you wish to use are handy on the desktop - youll need em soon, and install ATI-tool to later verify the number of pipelines.
    We are now ready to begin. Restart your computer with the gigabyte floppy disc in, boot to the dos prompt "A:\ prompt) and prepare to start the flash.
    At this point before we begin the flash, if you wish to backup YOUR OWN CARDS bios instead of using one of my provided backups, swap to the Flashrom floppy disc and use the command -
    " flashrom -s 0 original.bin " at the A:\ prompt.
    PLEASE NOTE: the "0" in the prompt is a ZERO not an 'o'
    Your own original BIOS is now saved to the floppy disk too and you can use this in case of a bad flash.
    Now you are finally ready to begin the first flash. Replace\use the Gigabyte disc in the drive, and using the Gigabyte Flash Utility (NOT Flashrom) use the following command prompt-
    " GVF11 -P -F x800xt.F1 "
    Gigabyte Flash should begin to flash your BIOS and you should see a success confirmation message, followed by a return to the A:\ prompt.
    PLEASE NOTE - the x800xt.f1 bios is a TEMPORARY bios to unlock the extra pipes, it is not good for overclocking or stability, a final x800xt bios will be installed later.
    If you experience any problems DO NOT RESTART!! make sure you have the second floppy disc to hand with the backup original bios on it (your own or one of the two provided ones). As this is a dos bootable disk it will allow you to hot swap the floppy disc and reflash to your original bios. If at any stage any of the bios flashes have errors, or it becomes clear that your card is permanently hardlocked, use this method to restore your original bios.
    Put the flashrom floppy disc in and use this command -
    " FLASHROM -P -F 0 (bios name) "
    either " x8pro20.bin " or " x8pro16.bin " depending on your card type (if using provided bios'), or " original.bin " if using your own.
    Reinsert Gigabyte Flash disc and retry, ensuring the command is typed correctly.
    Once the Gigabyte Flash is successful, restart your pc and boot into your OS. Be aware that after flashing your monitor may flicker on and off whilest loading windows. This is normal and your monitor should switch back on within a few seconds. Also when you are installing your video drivers the same thing will take place. Do not worry, this is also normal. Install your ati drivers and reboot. Now launch ATI-tool and check your number of pipes - it should now verify that you have just successfully unlocked all 16 pipes!!! The first stage of the flash process is complete.
    If your card is a basic x800pro and ati-tool still reports 12pipes after this, retry your pipemod and retry the gigabyte flash process, your pipemod may not have been done properly or your card may be unlockable - If it is unlockable reflash to an original x800pro bios using the flashrom method and command prompt above.
    If your card is a x800pro VIVO and ati-tool still reports 12pipes, try the gigabyte flash process again. If you still have 12pipes you may want to consider the pipemod (tho I will not recomend this as it is not undo-able and largely unsuccessful), but it is highly likely that you have one of the newer hardlocked VIVO cards. These are NOT soft or hardmodable at all. As above reflash to an original x800pro vivo bios using Flashrom and the given command prompt.
    Those of you that have been succesful in your initial flash will now have a card that registers as an X800XT Platinum Edition!!! However, in most cases you will now aslo find that your maximum overclock has been greatly reduced. This is now remedied by the final stages of the conversion process.
    Restart your pc with the Flashrom floppy disc in and boot to the DOS A:\ prompt.
    We will now restore your overclock by reflashing to an original PRO bios.
    Put the flashrom floppy disc in and REFLASH to the appropriate X800PRO bios using this command:
    Restart when the flash is finished and returns to the A:\ prompt as before. Boot into your OS again and check ATI-tool - You will now have your overclock back again, but you will still also have the 16 pipelines unlocked!! You now have a 16pipe PRO.
    Now to complete the conversion process, simply restart and boot to DOS A:\ prompt one last time, and flash to your final choice of X800XT Bios to make your card a full fledged X800XT!
    Use the command:
    " FLASHROM -P -F 0 x800xt.rom"
    if you wish to use the provided official ATI x800xt bios (which I have found is the best available for overclocking).
    PLEASE NOTE - If using the provided final bios this file is a .ROM file, not a .bin.
    Reboot to your OS and reload your drivers. Check ATI-tool !
    If you have followed these steps you should now have a fully functional Radeon X800XT Platinum Edition!
    PRIMARY DOWNLOAD HOST - (You need BOTH archives)
    PLEASE NOTE - Primary Download Host has 5gb a day transfer limit
    Archive File 1:
    http://www.bigredwa.com/x800/stage1-gigabyte_flash.zip
    Archive File 2:
    http://www.bigredwa.com/x800/stage2&...rom_pro&xt.zip
    Membro Avatar de MeStRe SpLiNtEr
    Fast tuh tem as Temps?
    tem ideia de qto pode chegar os clocks?
    Originalmente enviada por MeStRe SpLiNtEr
    Consegui ver a temp ta 40º idle, não testei full...
    Ah, esqueci de comentar, fiz o mod ontem a noite e foi 100%, eita custo/beneficio
    Mó medo de estragar a placa, pois numca tinha flasheado uma bios, mas correu tudo tranquilo.
    O Mestre Splinter me ajudou muito!
    MSI rox
    O cooler que vem na GeCube é padrão do design ATI, não testei muito longe, já tava contente a 525/573 com as temperaturas em 40 em iddle 70 em full load, eu não quiz ir muito além disso.
    Sei que tem gente usando um cooler mais pesado (Artic Silencer 4) chegando nos 580/605.
    rya
    rya está offline
    Fast eu fiz apenas o primeiro estagio de deixar com os 16pipes habilitados e retornar a bios original.
    Depois do segundo estagio fica habilitado medidor de temperatura?
    Minha X800pro gecube vivo nao tem medicao de temp pelo driver.
    To pra fazer o ultimo estagio, ja tesdtei ela com os clocks da xtpe e funciono na boa, mas vo por meu kit microcool pra troca a bios, agora fiquei curioso se ela tme sensor de temp tbm.
    Membro Avatar de andrepmrj
    Originalmente enviada por FastMHZ
    ATI TOOLS
    Use the command:
    Archive File 1:
    Archive File 2:
    sem over voce fez....no 2k3 11867 ????????
    essa placa so vale pelo over mesmo......
    No 2k3 as Nvidia tão dominando... Se ele rodar o 2k5 melhora hehe
    E não sei qual o resto do sistema dele.
    Outra coisa, tem q entrar no ATI tool e colocar o cooler pra rodar mais rapido, ja o padrao da ati e 60% em 80c...melhor era colocar 70c = 100%.
    Falow
    poxa o ATI tool ta bem completo! no meu tempo nao era assim uhahu. da pra modificar voltagem com ele?
    Originalmente enviada por rya
    Os drivers da ATI irão reconhecer a placa como X800 XT PE e irão habilitar o Overdrive, onde vc poderá checar a temperatura.
    Eu, particularmente prefiro usar o ATI Tool para checar a temp e controlar a rotação do fan.
    Isso, não to fazendo nenhum over de CPU, to rodando o P4 a 2.8Ghz mesmo.
    Agora a VGA, pelo fato do mod, existe um over embutido, já que tá rodando @ XT PE (padrão 520/560) com 16 pipes habilitados, quando que no original da X800Pro é 475/450 e 12 pipes.
    Em cima do @XT PE, poderia fazer um overzinho extra, mas do jeito que está, já estou MUITO satisfeito.
    Voltagem ainda não.
    Falow
    Como que se faz isso?
    Falow
    Up pra ver se alguem responde...
    Membro Avatar de Gung@
    Gunga
    Em settings, tem um menu acima escrito overclocking, vc abre esse menu e vai em fan control, vc ativa a opção "override fan speeds" e depois " dynamic based on gpu temperature"
    Em settings>fan control, vc ativa a opção "override fan speeds" e depois " dynamic based on gpu temperature"
    Bah!!!
    Kra eu to cego ou tem algo errado aki...
    Não achei a opçao "Fan Control"
    Ajuda ae...
    Ps ATITool 0.0.22
    Originalmente enviada por AMEF1
    Bah!!!
    Ajuda ae...
    Ps ATITool 0.0.22
    Valeu ae [email protected], agora o cegueta aki achou...
    Abusando da tua boa vontade [email protected], aparecem dois indices de temp...O que é a segunda que aparece?
    Gunga
    Um é temperatura da GPU e outro do PCB ao redor.
    Asy
    Asy está offline
    Membro Avatar de Asy
    NinaAgdal>All
    Tah vindo uma dessas pra mim
    Nao sei se fico com ela ou se vendo
    Nem sei quanto vai ficar ela, mas :/
    Fica que a placa é muito rápida e a chance de transformar em XT é grande.
    Qdo chegar,olha nos dois lados do pcb nos chips BGA.
    Se for GC16 nos 8 chips vc ta feito hehe.
    Abraço
