    Membro Avatar de Son of Satan
    5900se , 5900xt ou 5700ultra, qual a melhor?
    Galera, no site da pirainfo, tem essas 3 vga que tão + ou - na mesma faixa de preco :
    128MB Geforce FX5700 Ultra EVGA R$705,00
    128MB Geforce FX5900SE Evga R$775,00
    128MB Geforce FX5900XT CHAINTECH R$729,00
    Qual dessas 3 é a melhor em desempenho e pq?
    n3w
    n3w está offline
    5900se = 5900xt
    o q muda eh a escolha do fabricante em relacao ao nome.
    e nao se engane, xt em nvidia eh pior do q nao xt.
    ao contrario das radeons.
    nao sei se 5900xt > 5700
    nao vi mtos reviews em relacao a estas vgas.
    Membro Avatar de Diablero
    Exorcista
    5900Xt com certeza eh muuutio melhor q a 5700 Ulta(mesmo a Gddr3)
    Pq a 5700 as memos (mesmo 950mzO saum 128 bits
    Todas as 5900 tem memos de 256bits
    E as 5900 tem 8 pipes, contra 4 das 5700
    Pega a 5900 normal se puder, q vc chega facil a clock de 5950ultra...
    Jah a 5900Xt dah pra ir longe... mas naum tanto..
    Eu recomendo.
    Mesmo pq tenho uma :P
    Eu recomendo.
    5700 = 8 Pipes @ 128bits
    5900 = 8 Pipes @ 256bits
    Exorcista
    Poxa, pikachu, achei q vc estivesse mais informado
    Dah uma olhada.
    Mas valeu!
    http://graphics.tomshardware.com/gra...229/index.html
    [img]http://graphics.tomshardware.com/graphic/20031229/images/image005.gif[img]
    e the FX 5600 before it, the 5700 only has half as many pipelines as the top model. That means the chip has four pipes (Color + Z) running at 475MHz. At 365Vertices/s, the vertex performance is on the same level as that of the bigger models. On paper, that makes the 5700 Ultra look like a real performer. In practice, however, the comparatively narrow 128Bit bus prevents the card from achieving its full potential, especially when FSAA and anisotropic filtering are involved.
    NVIDIA has chosen to use DDR2 modules running at 450MHz for the FX 5700 Ultra cards. Since the memory bus is only 128Bits wide, that means the memory bandwidth is only slightly higher than that of the FX 5600 Ultra (14.4GB/s vs. 12.8GB/s). Probably, the standard or non-ultra versions will use DDR1 modules.
    http://graphics.tomshardware.com/gra...8-nv36-06.html
    5900se, 5900xt = same xit
    5700 = 5600 BOMBADA
    5900>5700
    Po então mas essa 5700Ultra é pior do q a 5900xt?
    Originalmente enviada por Son of Satan
    resumo:
    5900(EVGA)>5900(CHAINTECH)>5700
    Old School 2001
    nao seria 4X2? A 5700 ULTRA é pior pq é 128bits 4 pipes
    5900 = 4x2/256bit mem bus
    5700 = 4x1/128bit mem bus
    [BCampeão de supino, categoria leve recorde 130kg! Tirem a bunda da cadeira e deixem de ser nerd por algumas horas e vão malhar! [/B]
    off: qntos kg vc tem?
    Old School 2001
    Originalmente enviada por [Þëññ¥w¡§ë.t¢]
    agora 78 kg antes 74 kg...
    ah tah
    ja tava me sentindo um frango ehehe
    achei q vc tinha em torno do meu peso (69kg), e pegando tudo isso eheh
    Old School 2001
    ah tah
    eu peguei 130kg com 74
    Membro Avatar de Mirage
    Gold member
    praticamente um chester!
    Old School 2001
    Originalmente enviada por Mirage
    é frango!
